Question about Refrigerators
Ars2365a i have a Amana side by side model ars2365a. the freezer won't freeze, just gets cold. and the ice maker dosent work. a repaorman says i need a commressor but will cost 700+ so reccaamends we buy a new one. So, 2 questions, does that soulnd aaccuarte? and what is the cu. ft. capacity of this model. i cannot find it in the owners manual or anyhere. so just trying to figure that out to comparte when looking at a new one. thanks in advance for any help.
  • 42 Answers
SOURCE: Our refigerator is not cooling .
Hello Laura,
If you look at the rear wall inside the freezer compartment down low and find a bunch of frost on that wall, you have an automatic defrost system failure. The most likely part that has failed is the defrost thermostat. It is located on the top of the freezer coil, clipped onto a piece of tubing. It will have 2 wires coming out of it and it is about the diameter of a quarter and about 3/4" tall. To test this part you would need a test meter and enough skill to check if the contacts are closed when the thermostat is frozen withing the specifications stated on the thermostat. I believe yours would close at 25 degrees F and opens at 47 degrees F. Part # 5303918214
I hope this helps you. supertechks
Posted on Mar 28, 2008
mikedurland
  • 481 Answers
SOURCE: Maytag Refrigerator Ice Maker
  • first make sure the metal arm to the right of it is lowered, this turns the icemaker on.
  • then you can check the water supply to make sure it is turned on, sometimes when houses are vacant they turn the water off as a precaution. the valve may be behind the refrigerator or under the sink in the kitchen.
  • then...
The refrigerator has a duel water valve, one for the ice-maker and one for the water dispenser (if equipped). The valve that the ice-maker relies on may be bad, or it could be the ice-maker itself.
Another thing that could cause it would be the temperatures in the freezer. The ice-maker will not call for water until it reaches under 15 degrees. In addition, check the water tube behind the ice-maker to make sure it is not frozen, blocking more water from entering. The water does not go to the ice-maker or thru the filter unless the ice-maker turns on the water valve.
Posted on Jul 04, 2008
rpbuice
  • 161 Answers
SOURCE: Ice build up in freezer
Defrost system failure.
Defrost timer, heater, therma disk, any one could be bad.
You could manually defrost and this would get the Ref back to working for a couple of days before it iced up again. Remember there is a lot of ice build up on the cooling coils in the freezer that you can't see so, a little extra time with a hair dryer is needed to do a complete manual defrost.
Posted on Jan 21, 2009
mastatech
  • 478 Answers
SOURCE: freezer does not make ice
You need to check and see if ice maker has any water init. if not check the fill tube that goes thru the back wall for stoppage while you have it out rin the maker thru a harvest mode and listen for the sounds of the solonoid opening. If tube is full you'll need to replace the slow leaking valve a common problem. for parts call 704-819-6557
Posted on Mar 14, 2009
SOURCE: ice maker on Admiral HMG 62165 side by side
check the lever in the ice bin. if it is stuck in the up position it thinks the ice bin is full and will not make ice. Just wiggle it to the down position.
Posted on Apr 23, 2009
My Emerson ice maker, will make the 1st round of 9 ice cubes, then it fills back up with water and makes a clicking noise and won't freeze anymore cubes I'm so sad, I don't have money to buy a...
If it won't freeze the cubes that because the freezer section is not cold enough to freeze them. the ice maker itself dose not have any cooling in it. it all comes from the freezer. sounds to me like there may be a problem with the ice maker and it may need to be replaced.
Aug 05, 2013 | Refrigerators
Freezer won't make ice cubes, but does provide cold water.
The water and ice maker are two seperate water control valves built onto the same. Your water control valve for the ice maker may be defective and require that you change the set. Fill ice maker with tap water and allow the water to freeze. If the ice maker dumps the ice into ice bin and then does not refill then this points to the water control valve. If the ice maker does nothing after water freezes then the problem is the ice maker. Send me a model number and I will look up the part numbers for you, Thanks, Sea Breeze
Jul 08, 2012 | Frigidaire Refrigerators
Ge psc25pssc ss
Ice maker - don't work anymore. Ice cubes are small and wet. Water running down the sides of the freezer. Water in ice maker won't freeze.
Apr 20, 2012 | GE Profile 25.6 Cu. Ft. Side-by-Side...
Freezer on side by side won't freeze ice creasm
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Aug 06, 2011 | Amana 22.6 cu. ft. Side-By-Side...
GFreezer is cold, suddenly won't freeze
Hi, make sure the evap coil and the condensor coils are clean. make sure there is no ice build up on the evaporator located in the back of the freezer. It could also be a bad t-stat or low on refrigerant. Call a tech if it still does not work after you clean and make sure that both coils are clean and ice free.
May 19, 2011 | Amana ARB224RCC Bottom Freezer...
My freezer seemed to have quit so I cleaned it out made sure the air flow was good and de-iced everything. Now the bottom of the freezer freezes but the top does not nor does the ice maker work. What do...
open the freezer door,do you hear the fan blowing around?it sounds like the evap fan motor isn't running and that's why it's cold on the bottom and not the top,you have to repair this fast or you'll loose your food in the fridge,the fan is what blows the cold air from the freezer to the fridge section.
May 07, 2011 | Amana ARS266ZBS Side by Side Refrigerator
I have an Amana side by side refrigerator, model SXD22S2E. The ice maker does not work. It freezes Ice but it does not dump the ice into the ice bucket. -- Suggestions?
Check temp of freezer (10 degrees or better)
If it is then you probably need a new icemaker.
If this was helpful please rate me.
Leo Ponder Appliance-Tyler,Texas
imufo2@sbcglobal.net
Aug 08, 2010 | Amana Refrigerators
Hi, My Amana Refirg is about 30 years old-refrig on bottom freezer w/ice maker on top. The ice maker was skipping and would not stop by raising the arm. Consequently is ceased, now however the freezer is...
do you see alot of frost on the rear panel of the frzer if so it has failed to defrost and repair is req or do a manual defrost until a tech can get to you if no frost sorry sounds like you have a weak tired compressor or leak of freon and being 30 yrs old it is not cost effective to repair this item....
Aug 19, 2009 | Amana Refrigerators
Freezer is partially freezing
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Jul 12, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Amana Side-by-Side refrigerator hot spot
hi tanks for the question there are heaters at the spots you said were hot and those heaters are there to prevent moist air from hitting cold surface and create warer droplets from forming on those surfaces i would remove the back of the fridge and vacuum it out that should solve your problem thanks the appliance doc
Sep 18, 2008 | Amana 22.6 cu. ft. Side-By-Side...
Refrigerators Logo
41 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
