Question about Microsoft Xbox 360 Console
Connect to wireless
Hi i have a xbox 360 and i am having trouble connecting it to my wireless connection, i do not have an ethernet connection connected into the box i have the IP on automatic when i run the detect settings it says network adapter disconnected please can anyone help ont his issue i really want to connect it to my home network and use x box live thanks hadley new zealand
  • 3 more comments
  • Anonymous Jan 22, 2008
    i dont know why it wont do it atomatically
    i hooked it to the back but i dont know what to go into on my pc 2 get the router 2 pick it up
  • ainzee Dec 07, 2008
    cannot connect to ethernet with xbox 360. xbox screen tells me that ip address failed
  • Anonymous Jan 27, 2009
    having
  • bmike54 Jan 27, 2009
    having trouble connecting using the wireless adaptor
  • Anonymous Feb 14, 2009
    my xbox elite wont make a wireless conection to my bt-home hub.which is only 5mtrs away.
    Problem Solver:
  • 4 Answers
Try using a normal ethernet wire and see if it does cuz i had same problem and since i used ethernet wire it works
Posted on Mar 28, 2009
Yes,i have an xbox 360 and im having trouble connecting to my wireless network
Posted on Jan 15, 2008
  • Microsoft Master
  • 12,061 Answers
I believe the X-Box does NOT have Wifi built in? (sic)Surprisingly, the Xbox 360 doesn't have wireless networking built in. If you don?t fancy using the wired Ethernet method, you can invest in a wireless networking adapter. Microsoft has its own adapter specifically designed for the Xbox 360, but third-party Wifi-certified devices will work just as well.(sic) From the below site. http://72.14.253.104/search?q=cache:d7LlkY7Zo1sJ:www.vnunet.com/personal-computer-world/hardware/2147007/microsoft-xbox-360+xbox+360+wifi+is+built+in%3F&hl=en&ct=clnk&cd=2 So that may be ya problem?
Posted on Aug 12, 2007
SOURCE:
How to connect xbox360 to internet with laptop
Hello bernelltaylo,
This is a very simple procedure, but pay close attention.
First, here are the requirements to attempt this procedure.
_____________________
- An Ethernet Cable,
- Wireless Connected Laptop
- Bridged Connection Eligibility
_______________________
1. Get an Ethernet cable, they are commonly blue, or yellow.
2. Plug one end of the Ethernet cable into the back of your Xbox 360 console, and the other end of your Laptop.
3. Log onto your laptop, (assuming you're using Windows), and find the list of your wireless/wired connections.
4. You'll see something like, "Local Area Connection 2", and "Wireless Network Connection 3". Make sure you're already connected to the Wireless Network before continuing to the next step.
5. Highlight both the connections, and right click one of them. Click on, "Add a Bridge".
6. A process will start which will bridge the connections, enabling your laptop to work as a modem for your Xbox 360. This may take as long as anywhere between seconds, to minutes.
7. When it's done, do NOT remove the Ethernet cable, until your desire to disconnect from the internet on your Xbox 360.
______________________________________________________
Hope this helped, see ya' later. :)
Dec 02, 2012 | Microsoft Xbox 360 Console
Do u need a wireless adaptor to set up xbox live??
No, a Xbox 360 Wireless Adapter is not required to access, and set up Xbox Live, but you will need an internet connection. If you are close enough to a modem or router, you can buy an Ethernet cord, and plug it in to both the modem/router, and firmly into your Xbox 360 console. You will either need the Xbox 360 Wireless Adapter, or the Ethernet cord. Ethernet cords are very cheaper, much cheaper than a Wireless Adapter, but the Wireless Adapters are much or easier to reason with. So choose wisely with money.
Jul 06, 2011 | Microsoft Xbox 360 Console
Cant connect to XBOX LIVE through wireless adapter it says to trouble shoot connection
Are you running through a wireless router? Most commonly, if this is a recent problem after purchasing wireless adapter, that your wireless router needs to be reset and it's configurations changed to allow for connection to your Xbox. If you can connect to Live with an ethernet cable, then this is most likely your issue.
Oct 28, 2010 | Microsoft Xbox 360 Console
How to connect xbox to computer with ethernet cable and wireless internet
you can only basiclly cant with only one connection which is either through ethernet or wireless device that you have to buy from any supermarket it s not hard either way to set them up
but with ethernet you need to have the xbox close to the router
wireless connects to your xbox 360 throught the usb then basically scan for your router then put in the routers wep key or wpa psk key
May 15, 2010 | Microsoft Xbox 360 Console
I have a Cayman 3347w wireless router and I am trying to use one of the wired slots to connect my xbox 360 to the internet. the xbox will not connect. is this router xbox compatable?
Please try the following steps below;
To make a router connection to Xbox LIVE:
  1. Before you connect any cables, turn off your router, modem, PC, and Xbox 360 console. (Unplug your modem from its power source to turn it off.)
  2. Connect one end of an Ethernet cable to the Ethernet port on your modem and the other end to the Ethernet input port on the back of your router.
  3. With another Ethernet cable, connect one end to one of the router's Ethernet output ports. Connect the other end to your PC's Ethernet port.
  4. With the third Ethernet cable, connect one end to another of the router's Ethernet output ports. Connect the other end to the Ethernet port on the back of the Xbox 360 console.
  5. Turn on your modem, then your router, then your PC.
  6. Make sure your PC can access the Internet. If not, you may need to configure the router for Internet access. For help configuring the router using your PC, check the instructions that came with the router.
  7. Turn on your Xbox 360 console and sign in with your profile.
  8. If this is the first time you've turned on your Xbox 360 console, see Create Your Gamer Profile to get started with both the Xbox 360 system and Xbox LIVE play.
If you're unable to connect to Xbox LIVE, you can try to diagnose the problem right on your console. Go to My Xbox and open System Settings, then select Network Settings (setup XBOX using Automatic Configuration DHCP), Test Xbox LIVE Connection.
Hope this helps!
Mar 28, 2010 | Netopia Cayman 3347W-Ent Wireless Router
Console will not connect to my wireless network
First off, make sure you have a wireless connector on your console. The new Elites come with one. If you don't you'll need to buy one (100 US dollars or so)
If you have one and it's still not connecting, make sure that your security settings on your network router are set to allow your xbox TO connect. I've found that if you have security settings set up that the 360 tends to have troubles connecting to a wireless network. Either open up your settings, or use a direct connect Ethernet cord, which bypasses the wireless security, to connect directly to the router
Nov 13, 2009 | Microsoft Xbox 360 Console
How to hook your xbox360 to laptop to get on xbox live
wel if you have wireles internet you can get a wreles adapter for your xbox and conec it that way
Oct 25, 2009 | Microsoft Xbox 360 Console
Cannot connect to Gateway
Lots of people seem to be having problems with wireless adapters, I don't know about ethernet cables, but I have done some searching for you and if you click on the link below and scroll 2/3's down the page, there is a screen shot of how you can connect your 360 to the net from your computer. (it's not a fix to your direct problem, but it is a short term fix)
http://www.techsupportforum.com/gaming-forum/console-gaming-support/193635-360-wireless-adapter-trouble.html
I hope this helps
Nov 14, 2008 | Microsoft Xbox 360 Console
Xbox 360 to wireless laptop
Make sure ethernet cable from XBOX 360 is connected to one of the 4 access ports on the back of the router.
Mar 16, 2008 | Microsoft Xbox 360 Console
Xbox 360 elite live
It may have trouble recieving the ip addrees from the router, but not sure what switch you are using if you have a router you should connect directly unless its a wireless switch.
Aug 29, 2007 | Microsoft Xbox 360 Elite Console
Microsoft Xbox 360 Console Logo
164 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Ekse
Nathan Hamilton
Nathan Hamilton
Paul Castley
Paul Castley
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
