Question about Hampton Bay 24750 Huntington III Ceiling Fan
Hampton Bay ceiling
A handiman took down my fan from a remodeled room. I am trying to move it into another room. The fan has a black wire, a white wire, a blue wire, and a green (ground?) wire. My light fixture has a white, a black and a copper (ground) wire. What does the blue wire attach to?
  • 196 Answers
When I've installed these fans in the past, the blue wire was for power to the light kit. If you don't have a light kit, just tuck it out of the way.
Posted on Aug 12, 2007
Just installed a new Hampton Bay 36" ceiling fan.
I suggtes recheck your wires, could use this wiring guide (click image for zoom)... support/t9590572-hunter_fan
Jun 29, 2011 | Hampton Bay 24002 Ceiling Fan
I need a wiring diagram of the Hampton Bay fan with light. The fan is black and white and the light has a blue wire. I believe the blue should be tied to the black, am I correct. Thanks
Twist the bare conductors together tightly, matching the black and blue ceiling fan wires to the black power wire, and the white ceiling fan wire to the white power wire, don't forget the green ground !!
Sep 10, 2010 | Hampton Bay 24002 Ceiling Fan
How to install a ceiling fan
very simple make sure power is off take old one down and hang new one hook up wires black to black white to white and ull have probably a blue wire from light hook it up to the black wire also then screw fan to the electrical box and lastly put on blades and sometimes u have to balance it with lil weights this is a pain and tedeous but usually dont have to do this turn ur power on and check
Feb 24, 2010 | Hampton Bay 24002 Ceiling Fan
Wiring light kit to ceiling fan
connect the white wires from light kit filter to the white wire labeled "for light" from fan. then connect black wire from light kit filter to blue wire from fan. use wire nuts to make the connections
Jan 17, 2010 | Hampton Bay 24002 Ceiling Fan
Wall switches do not control fan
Some fans will not operate without the remote, however, I'm not sure if the Hampton Bay brand is one of these or not. Below is how you will bypass the remote if the fan will operate without the remote.
You can try disconnecting the receiver in the canopy of the van (the cover that fits snug to the ceiling) once you have shut off the power source remove the canopy and find the remote receiver.
Most likely it will be a rectangular box with white, black, and blue or red wires attached. Disconnect all wires from the receiver and lay it to the side.
Now reconnect the wires directly to the fan, white to white, black to black, if you have a red wire (or a second black wire) in the ceiling box connect it to the blue wire from the fan.
If you do not have a red wire (or second black wire) in the ceiling box, connect the black and blue wire from the fan to the single black wire in the ceiling box. This method will require you to pull the chain to operate the fan separately.
Dec 12, 2008 | Hampton Bay 52 In. White Redington...
Ceiling fan wiring
blue would be your earth.
black and white are phase and neutral.
for the wiring in your roof you need to call a local sparky. just ask which is which and connect them appropriately.
Sep 01, 2008 | Hampton Bay 24002 Ceiling Fan
Need Wiring instructions
no problem just wire the black to black and white to white. connect the ground and cap off the blue wire, its used only for ooptional light assy
Apr 03, 2008 | Hampton Bay 73554 Antigua Ceiling Fan
2 many ceiling wires
ok lori connect the fan wires like this-----white from fan to both white wires---blue from fan to red---black from fan to both black wires then copper wires to a ground.let me know.
Jan 15, 2008 | Hampton Bay 46056 Callaway II Ceiling Fan
Hampton bay Windward III
Green and copper are the ground wires and I believe you can connect both these to the green wire from the fan (I only have the copper wire in the actual ceiling box). Black and Red can be treated as both black and both can be connected to the black wire from the fan (this is what I did in all my fans and it worked). White is the neutral wire and can be connected to the white wire from the fan (this is what I did in all my fans and it worked).
My ceiling box has the copper, red, black, and white wires. The ceiling plate for the fan I bought had a green wire. I connected the green wire from the ceiling plate and the copper wire from the ceiling box to the green wire from the fan.
Dec 29, 2007 | Hampton Bay 52 In. Black Huntington III...
Installing ceiling fan with two switches AND a remote
in your ceiling box should be three wires. a red goes to the three way switches, a black goes to the hot and the white is the neutral. the fan wires are black, blue and white. since you have a remote, connect the [fan] blue & black together with the [line] black. connect all white wires together. the remote will now ramp up your lights from off to full on and the fan remote will let you choose lo med high and off. just tape up the red wire in the box.
Aug 17, 2007 | Hampton Bay 04383 Calibre Ceiling Fan
Hampton Bay 24750 Huntington III Ceiling Fan Logo
194 people viewed this question
Top Hampton Bay Dryers Experts
Steve
Craig Butler
Craig Butler
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
