Question about Garden
Ryobi trimmer manual
Hex bolt to secure trimmer head to drive shaft - how long should it be ?
AlmostBob
  • 550 Answers
SOURCE: Gas/oil mix ratio for Ryobi Trimmer
50:1
Posted on Oct 10, 2008
SOURCE: I NEED A REPAIR MANUAL FOR RYOBI 725R TRIMMER
Hey go here http://safemanuals.com/user-guide-instructions-owner-manual/RYOBI/725RE-_E
it's free...
Earl
Posted on May 08, 2009
SOURCE: how do I wind trimmer line on double spoools for ryobi
Okay, so the good news is that YOU are probably not stupid. If you have a Ryobi trimmer like I do, it might have taken you a while to figure out the "secret" on how to rewind the line. If you only had to learn the lesson once, you are smarter than I am. (I'm leaving myself a note for next time).
If you wind the line the wrong way, you go through line really fast until it clogs up inside the bump head and you are forced to try again. The trimmer has an arrow on the spool for the direction to re-wind the line. Think of it this way, TURN THE SPOOL IN THE DIRECTION OF THE ARROW! Don't do what I did and rewind the line in the direction of the arrow, that would be wrong.
Whether this is a "mistake", a way to sell more trimmers/parts/line, or simply bad tranlation from Japanese to Engrish, it really doesn't matter. You don't need to buy anything with the exception of new line.
Good Ruck,
Mark
Posted on Aug 18, 2009
nova2nv
  • 197 Answers
SOURCE: Ref: Stihl FS46 string trimmer. Broken Flex shaft.
Remove orange sheild,remove single screw holding head in shaft then grab head with pliers and twist side to side until complete head is free.You should then be able to grab part of shaft.On power head loosen screws {about one turn each} that hold two white case halves near trigger,I think there are four,then there is a single torx screw on the bottom of lower case half in the middle that must be taken out to allow tube to be removed.Romove flexshaft from top.Check 4 plastic burnt to flexshaft,if there is you must replace tube liner as well,usally around bent part of tube the liner will go bad.
Posted on Nov 28, 2009
  • 4044 Answers
SOURCE: I cannot remove the head
Being new, I'd return it if the the head flew off. When you say head I see the Engine head coming off and the engine be a total mess. What part are you actually talking about. Is it plastic or aluminum? Here is a link to PDF doc that you can download. If your talking about the part with the string that cuts, which I think you are, you need to screw it back on and make sure you have a something that is locking the screw in place while you screw it down. You can use the special tool that should have been included with the weed eater or use a Phillips head screwdriver in the locking hole to hold that mounting bolt steady for you. I found a pretty good picture of the process in the manual I found here :
http://www.filemeta.com/preview.php?url=687474703a2f2f6f647265662e636f6d2f7064662f52796f62692f383930722d6f776e6572732d6d616e75616c2e706466&fname=393536312038393072206f6d2028656729&country=ca&filetype=pdf
Posted on Jul 05, 2010
How to replace the spool head
Once you remove the spool cap and the spool, you cannot remove the head from the motor. It is not a replacement part.
Ryobi P2002 Cordless String Trimmer Parts
Aug 31, 2014 | Ryobi Lithium Ion 18 Volt 18v Cordless...
Weedeater repair
Its possible that the drive shaft is broken or the end of the shaft is worn where it hooks into the gear head. The trimmer head has a hex fitting that meshes with the gear assembly in order for it to turn, its possible the hex is worn on the cutting head from usage, which would require replacing the outer spool assembly. Here is a link to a parts breakdown. http://www.partstree.com/parts/?lc=troy_bilt&mn=TB70SS+41ADT70C711&dn=769014720002
Jul 18, 2014 | Troy Bilt Tb70ss Gas Trimmer
Ryobi plt-2543y engine runs okay but head will not
Ken it sounds like the shaft isn't going in to the spigot on the engine. Make sure that the head is on properly and that the shaft is in the spigot itself. If there has been any movement with the head creeping down slightly the shaft will no longer go into it. Try and straighten the shaft slightly to give a couple of millimeters more to the shaft.
Sep 24, 2013 | Ryobi Garden
Ryobi grass scorpion rct2800a head keeps coming off. Is there a screw or bolt to hold the head in the housing?
I see the spool shaft on the spool and not the drive cable. ALL my trimmers were designed for the line spool to come off the shaft (usually by removing the plastic bump feed nut). Your drive shaft appears to have a groove in it about 3/4 toward the top. I surmise that notch is where a broken/missing set screw or "c" clip would most likely hold the shaft to the drive cable. If you find it to be true, a factory part would not ne needed to find a replacement part to lock the shaft and drive cable.
Apr 10, 2013 | Garden
Ryobi Reeleasy line trimmer head PROBLEM
sounds like the clip isn't engaging properly. For a bump and feed they have steps that lock when enough cord is set out. If the head is not locked when its on it will recoil in. Try to make sure its not sitting wrong.
Apr 20, 2017 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
I broke the flex drive shaft but can't remove the head to get out the broken shaft piece. I got the big part of the shaft out from the top. the bump head has been replaced by the kind that you cut 2 pieces...
The flex shaft drive you are referring to is only sold as a assy that I am aware of. You can try www.partstree.com for the replacement shaft assy. you are refering to, however you may find out by the time you buy a new shaft assy you may be money ahead just buying a new trimmer.
Sorry
Aug 08, 2009 | Ryobi Garden
Engine/shaft stopped working. Need to fix Ryobi trimmer.
Hi, I have a Ryobi brush cutter and the engine has a tendency to move up and down the shaft. It also rotates around the shaft
May 16, 2009 | Garden
Head will not drive. Can feel it slip between nut and motor.
inside the shaft is a flexible drive cord, at each end is usually a hex or torx head fitting that slides into a sleeve, theese can sometimes strip or even snap off and need replaced. remove one end of the shaft (either the engine or the spool) and the cord should slide right out easily. inspect each end for stripping and to make sure it didn't snap off inside the sleeves.
Sep 24, 2008 | Ryobi 15" Electric Factory Reconditioned...
Ryobi TP30 straight shaft line trimmer convertible - drive shaft disconnected from motor
check both ends of shaft, they're usually a hex or torx head. sometimes the can strip or even snap off. if you find noticable damage replace the shaft
Jun 30, 2008 | Ryobi 15" Electric Factory Reconditioned...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
