Question about Toshiba DR4 DVD Recorder
VHS to DVD-R
Error message "Copy Protected Tape Is Used" appears when I copy a "home-made" VHS to a DVD but what is strange is that this always happens when the dubbing occurs approx. 30 minutes into the dubbing. I've tried different VHS tapes and even different brands of DVD-R but all with the same results as above. Any suggestions before I place the D-VR4X in the recycle bin? Thanks .... theallde
  • theallde Aug 31, 2007
    Hello Dyllan:
    "Home made" refers to vacation, family outings, backyard BBQ's, etc. transferred from camrecorder to VHS many years ago.
    None are purchased movies, etc. that are copyrighted.
    Sergeant:
  • 279 Answers
You say "home made" - not sure what you mean by that. If it was a copy of something that was originally retail, it's possible the Macrovision encoding copied over with it - in which case your DVD recorder is working as it's supposed to to prevent illegal copying of disks. I'm a bit wary of getting into this in any depth, as it treads the lines of legality. If I found a way for you to bypass this copy protection, it would allow you to pirate movies freely. I'm not going to discuss my own feelings on that, but I will say that I'm not going to support such actions on a public forum. That being said, if for some reason your totally legitimate home made tape managed to get something that's being interpreted as Macrovision coding on it, you may want to do a google search for digital video stabilizer. That will point you in the right direction.
Posted on Aug 30, 2007
  • John Goodman Aug 31, 2007
    Unfortunantely, this isn't going to be something that can simply be fixed. For whatever reason, something on your tape is being interpreted as copyright coding. I've seen that happen before, and it's a real pain in the neck.
    You could filter that out, however, with a digital video stabilizer. It's a workout, not a fix, because the only fix would be to disable Macrovision protection, and they design these things not to allow for that.
    For more information on Digital Video Stabilizers, and where to order one, look here:http://www.checkhere22.com/stabilizer/
    I know, this is not an ideal solution. If there was an ideal solution, I would give it to you. It sounds like a case of an overly sensitive copy protection system - and that's built into the hardware and can't be disabled or adjusted.
Sorry it is D-VR610 made by toshiba
I think that the tape is copy protected, I remember this error.
Sep 27, 2016 | Sony Televison & Video
Will this model record from the vhs tape to the dvd?
You don't state the manufacturer or model number in your question, thus we cannot answer. I will say that many do, but there is a caveat. If the the VHS tape is a commercially made movie, chances are it has copy protection on it. Most machines will sense this copy protection and will refuse to copy the protected VHS tape to DVD. This was done to prevent piracy. Home recorded tapes and non-protected tapes will usually work ok. Do not confuse write protection with copy protection however. Write protection is merely the tab on the tape that prevents re-recording of the tape. Copy protection is recorded right onto the tape itself and is read by the machine during playback.
Nov 19, 2015 | Televison & Video
Daewoo DVD-T "copy not possible - this media cannot be copied" when trying to copy from VHS (tape is not copy protected) to blank DVD-R and +R media. Same problem with all DVDs and VHS tapes
You can only copy non-commercial VHS tapes that you have recorded yourself to DVD. You can\'t make copies of most commercially made VHS movies due to copy-protection.
Dec 29, 2013 | Daewoo DV-6T955B DVD Player/VCR
VCR DVD Recorder not dubbing
I called the manufacturer and realized I was using the wrong type of recordable DVD disc to dub to. Non copy protected VHS tapes dub just fine as long as I'm using the proper disc.
Jun 03, 2009 | Sony RDR-VX530 DVD Recorder/VCR
Copy Protected VHS
Yes. Generally protected VHS tapes can be copied to DVD.
Feb 08, 2009 | Philips Magnavox DVD/VCR Dual Player
Says tape copy protected
There is a hole at the top of the cassette kind of square and they are on left and right side place a piece of tape over it and they should work .
Feb 06, 2009 | Samsung DVD-VR375 DVD Recorder/VCR
VR5940 DVD Recorder/VCR-Thinks a regular VHS tape is copyright protected
Don't know your machine, but is it possible that it's seeing your source tape as write protected (missing tab) and so assuming it should not be copied to the DVD?
Jun 14, 2017 | GoVideo VR5940 DVD Recorder/VCR
VHS to DVD - D-VR4XSU
have u tried the seting on the vcr, you know how u can change the lenght of recording on the vhs
Mar 29, 2008 | Philips Magnavox DVD/VCR Dual Player
Panasonic DMR-E55 Won't Let me Record my own VHS
Hi
This is probably caused by an irregular magnetic encoding pattern being generated by the tape itself. If the DVD recorder does not fully recognise the code, it may incorrectly interpret it as copy protected. If there is any tape flutter or there are tape edits, these can contribute to the problem. In addition to this magnetic imprinting can occur on old tapes that have been stored for a number of years without being spooled. basically wrong bits of the tape get magnetised. You can sometimes hear an echo on old tape recordings caused by imprinting.
You could try the following:
1) If available, try using a different video machine to play back and record from.
2) Whatever video machine you use, put your tape in, fully fast forward and rewind a couple of times, then try your recording again. This is particularly important if you haven't used the tape for some time.
3) If it fails again, check to see if it always fails at the same point.
4) If it does, try winding forward a little and then try to resume recording.
5) If you can record it means that a short section of tape is giving a spurious code to your dvd recorder and confusing it.
6) Use a re-recordable dvdrw to make a master. You won't keep wasting discs if the recording stops. You will also be able to produce another dvd from your master and edit it if your recording ends up in a number of segments.
7) Always use the highest quality setting possible when producing a master.
8) If all else fails, if you have a friend with another dvd recorder, maybe try that.
Have fun....
Jan 21, 2008 | Panasonic DMR-E55 DVD Recorder
Trying to Copy Home VCR tape and keep getting copyright message.
Try replacing the tab on the VCR tape-which may have been removed to prevent VCR eraure [?]
Aug 27, 2006 | Toshiba D-VR4 DVD Recorder/VCR
Toshiba DR4 DVD Recorder Logo
145 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
