Question about Clarion APA4320 Car Audio Amplifier
After 7 yrs of use, it just stopped working
I've checked the fuses. They're fine. I took amp out and put another amp in its place in my car and the other amp works. Something is wrong with my APA4320 Amp. It looks brand new, not a blemish on it. Its never been dropped, nor received any moisture. I need help. Is there something inside this AMP that is possibly blown? The lights power on showing that the amp turns on, but there is no sound. Again, I've replaced the amp to make sure it wasn't my power wires, speaker wires, or RCA wires. With the temporary replacement amp, I can listen to music. I just don't want to use this "other" amp as its really outdated.
    Scholar:
    New Friend:
  • 103 Answers
I agree that It could be one of the other reasons listed here.....
But, I had the same problem with a 1,000 watt Kenwood amplifier and it worked like a boss for the whole two years that I had it and then one day the box that I had my subs in somehow came apart and after I changed out boxes the amp quit working. It came on but it wouldn't work anymore except for when I turned it a certain way or sat it against something.. Anyway it ended up being a loose female port plug on the inside where the auxilary cables plug up.
Hope it helps.
Posted on May 12, 2013
4 Suggested Answers
KaeZoo
  • 156 Answers
SOURCE: Protection light and nothing. ??
How about the speaker itself? This problem can be caused by a blown or defective speaker. If you disconnect the speaker wires from the amp, do you still get the protect light?
Posted on Mar 15, 2007
lostinfamily
  • 149 Answers
SOURCE: clarion apa4320 amp power light pulses
There is not enough power coming from you radio to power the amp. You might want to look in to a capacitor. What this will do is it will pull in the power and maintain a steady output for your amp to operate
Posted on Mar 18, 2009
etirbynnor
  • 655 Answers
SOURCE: Amp doesn't come on
Hello rheabarb,
You did not say whether or not you checked the wiring going to your subs. Many times, a shorted or grounded speaker wire will cause an amp to fail. And if the amp powers up OK with the subs disconnected, I'd suspect one or more of the wires.
Hope this helps.
Posted on May 20, 2009
Battery issues
Have you checked to see if the alternator is charging the battery when the engine is running ?
Jul 21, 2013 | 1995 Jeep Grand Cherokee
I took my cruise control fuse out and my stop fuse out. one is a 10 amp and the other is a 20 amp. I don't remember which one is which now.
look on the fuse box cover to see if it tells you the amp of every fuse fitted or look in your books that come with the car and it should tell you in there. tbh i wouldn't worry too much and put them in where ever since its only 10amp difference
Feb 12, 2013 | 2006 Chevrolet Colorado Crew
My turn signals don't work and I've checked the bulbs, fuses & flasher.
About all that is left on the list is the turn signal switch.
Do you have power in and out of the switch ?
Feb 04, 2013 | 1995 Buick Skylark
I have a 87 Cutlass Ciera. 2.8 engine. I've had
Check this link out.Here's how to replace,if this doesn't work,take back for refund..
Dec 03, 2012 | Cars & Trucks
Mighty Max Brake Lights, Stereo & Clock all stopped working at the same time. Any suggestions?
you may have a bad ground, or a short in one of the wires. pull out the stereo.
Aug 19, 2012 | Mitsubishi Mighty Max Cars & Trucks
I have a 2000 chevy silverado 1500. 3 nights ago, my truck started up just fine with no problems and has never had a problem starting up. The next morning, I tried to start it and the dash lights and radio...
do you have remote start on that truck? if you do, it has a hood safety switch that will keep it from starting if hood is open. That hood switch is quite easily identifyable. Look for it on the drivers side, either close to the firewall or right at the front of the fuse box.itsa worth taking a look
Aug 12, 2011 | Chevrolet Silverado 1500 Cars & Trucks
Hello, I have a Ford escort 1.8 55D van. A few months back I fitted a new indicator stalk unit for the MOT as the high beam use to flicker on its own, all then fine. A couple of weeks ago the indicators...
typical UK reg motor they corrode like ?-?-? ,i suspect that your horn has stuck up with corrosion and the indicators is the hazard light warning switch faulty .But i could be wrong and often am but check it out anyway.I try not to repair UK or northern europeon vehicles anymore as i spend more time cutting off rusty bolts and seized bits than whats the cars worth compared to spanish vehicles that can be 20 yrs old and i just whistle and the bits come undone
Jul 18, 2011 | Ford Escort Cars & Trucks
I'm a novice at using a multi-meter but want to check my volkswagon beatle for a short, one circuit at a time. After battery is charged up, it goes dead after a few weeks. Worse in colder temperatures....
you would be measuring current
you would set the meter to maximum current setting
Then place the leads between the terminals of the fuse for each circuit. with the fuse removed.
so if you have a ten amp fuse you would expect a current either below 10Amp or at 10 amp.
maximum setting of current is in case short circuit to ground causes a huge current drain. To prevent blowing up amp meter of multimeter.
You may wish to put a fuse on the lead of the multimeter to safe guard your meter from blowing up in case you encounter a high current it can't handle.
if via the battery disconnect one lead and put a fused meter lead on the battery and the other lead on the battery cable. look for current drain while car switched off.
Jun 01, 2017 | Gardner Bender GB Electrical GMT-19A 19...
I have a 2004 Chevy Cavalier. A couple of months ago, just after starting the car one day, the 'check engine' and 'trac off' lights both came on. I immediately shut off the car, waited approximately 5...
Well it's temping to put in biggfer fuses as the problem gets worse but the size of the fuses are to keep you from burning things up so you've from your probem with a 30 amp smoke test. The raditor fan wire is melted somewhere in the wire harnes to the wire for the trck lock or even key on circirts. the likly place to look is inside the stering collum. It takes the skills of removing the steering whel and the lcok plate and even then thats does'nt have to be where the problem is. You need to look under the dash after you remove the covers and use you nose to smeel for the burnt wiring and open up any thing the smells like it's been hot and anything the appers melted together. once a harness is found melted you need to seragete all the wires in the loom but don't cut the wires justy seaparte them. once you think you've got then all pulled apart so no bear wires touch each other or any meal parts put in the correct size fuses and see if you can connect the battery with out a spark. if you can you may then start checking to see what works and what does'nt.. This all sounds like too much work or too hard to do then you'll need to pay someone theat knows alot about car wiring problems to do it for you. I'll been doing this kind of work for the last 20 years and a'm alawys finding new things that are fried and burnt up. We all charge by the hour to do this work so the most experieced mechanic that works on cars like yours will probly find and fix the problem the fastest. therefore they may charge more per hour but their likly to get it right quicker and it'll stay fixed after they fix it.. This is the most likly kind of work to go sour after it's fixed cause they might miss a circuit that you use and they did'nt try. and as soon as it burns again it's back to the drawing board and if big fuses are use the fire can take the whole car.
Apr 26, 2011 | 2004 Chevrolet Cavalier
Clarion APA4320 Car Audio Amplifier Logo
43 people viewed this question
Top Clarion Car Audio & Video Experts
xxxxxx xxx
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
