Question about Acer Computers & Internet
Stop error 0x0000007e
Acer blue screen and says try to change video adapter error (0c0000007E)
Consultapro
  • 23 Answers
SOURCE: blue screen of death
Not exactly sure, but it seems that you should uninstall and reinstall you sound drivers. They may have become corrupt or it may point to hardware failure.
Posted on Jul 17, 2008
efs_perpends
  • 1996 Answers
SOURCE: blue screen when trying to install o/s from cd.
Not a lot of help here, other than to suggest it's caused by some hardware or driver conflict, but see this ms article. You could try then, this link to stop error codes, and these MS links here and here
I suggest you google "0X0000007E + pci.sys" and read the forums to see if someone out there has a solution...
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on May 04, 2009
  • 9 Answers
SOURCE: Balance - Blue Screen during shut down stop error 0X0000007E
check your hardware settings it could be the codes for the hardware that cannot recognize of your systems. it could be change with the wrong specs. if you cannor configure it out. you better set the bios configuration to default setting and try to repair the system using your operating system cd installer. thanks
Posted on May 11, 2009
SOURCE: having a blue screen issue, boots to windows
Have you tried to boot in Safe mode? Well if not then press F8 as the PC starts and select safe mode. If it works, then select the 'system restore' option which will appear and restore the system to as far back as it worked very well. Your files will be intact. Well if safe mode those not work, then since you cannot change your boot order to boot from CD/DVD, then you would have to take out your hard drive and connect it to another PC and follow this tip of mine: http://www.fixya.com/support/r3766678-booting_bootable_windows_cd_dvd_fresh
All the best.
Posted on Jan 14, 2010
jcfs259
  • 177 Answers
SOURCE: starts with disk drive 0 seek failure. hit f1to
I have had this problem and had to reset the CMOS. Simply removing the CMOS battery is not always enough. Shut off your computer and disconnect the power. Then find the CMOS jumper, usually near the battery, and remove it, taking careful note of the pins it connected. Move it to the far pins and wait a few minutes. Then move it back to its original position, plug your computer back in and restart it. You may need your Windows disk to get everything working properly again.
Posted on Feb 18, 2011
Error blue screen when installing
http://www.wiki-errors.com/wiki-errors.php?wiki=0x0000007e I hope this helps :)
Oct 11, 2013 | Dell Dimension Computers & Internet
Aspire One netbook BSoD
Those error codes don't really mean very much to the general consumer, but blue screens of deaths are caused by bad RAM memory in your computer, not viruses. I'm going to take a guess that your computer is either several years old and/or it constantly get quite warm? Heat can shorten the life of computer components by quite a bit. You may need to get one of your RAM cards replaced to solve this issue.
There's a free program called Memtest86 that you can run to determine if this is the case. It will scan all your memory and look for bad sectors. You can download it here: http://www.memtest86.com/ and burn it to a CD. What it does is create a bootable CD that will execute the program as the computer turns on to scan all the memory. There are full instructions on their website. The process can take an hour or two depending on how much memory your computer has, and if it turns up any bad sectors then you know what your problem is.
A computer can run with bad sectors in the memory, but it makes it unstable that it will keep bluescreening, so if you have bad sectors in your memory it might be better just to replace the RAM. Luckily, this isn't too expensive. For instance, if your computer has 4GB of memory, it probably has 2 2GB RAM cards installed. You can get a 2GB replacement notebook memory for, I'd say $30 or $40. Installing RAM is very simple, and if you're willing to install it yourself, it won't cost you more than that.
Dec 06, 2012 | Acer Aspire One Netbook 8.9" Notebook
BLUE SCREEN ERROR STOP 0x0000007E(0xC0000005,0x80688B8E,0xBACC357C,0xBACC3278)
This error may happen due to following reasons,
1) OS file corrupted
2) RAM
First you need to re install the operating system and mostly this will resolve the problem. For this all you need is an OS installation CD.
If the problem persist again then you need to change the RAM to check this error.
Note: Please don't use two RAM on this situation. Different RAM frequency may cause this error, remove one RAM if you had two.
Jan 20, 2011 | Computers & Internet
I am having a acer laptop, while i was rebooting my system suddenly i got the blue screen with below error STOP: 0x0000007E (0xC0000005, 0x80536268, 0xBA4CF3B8, 0xBA4CF0B4)...I cant even boot with the safe...
This might help you.
Otherwise I need more information:
When did it start - after install, after update, after changing some components or something else? Does the message state in which driver did the error occur?
Oct 14, 2009 | Microsoft Windows XP Professional
May 11, 2009 | Computers & Internet
Blue screen when trying to install o/s from cd.
May 04, 2009 | Gateway GT5220 PC Desktop
0x0000007e error code in acer motherboard of win
hi,
Some users experienced similar problems when SP2 was released, so this could be the problem. If the user sees a stop error code of 0x0000007e, this first issue is likely the reason why the computer does not boot properly.
The second issue will only occur on systems with certain acer motherboards. This error manifests itself with an error code of STOP: 0x000000A5. It is unknown how to fix this problem other than by installing a USB storage device, or even possibly removing a USB mouse and replacing it with a PS/2 port compatible version.
If that is not enough, Microsoft MVP Jesper Johansson reports that there seems to be a third, less common problem with SP3 computers, this time on Intel. Some may receive a 0x00000024 stop error, which he believes may be due to an issue with either the NTFS file system being corrupted, or a faulty video driver.
go to microsoft .com under solutions page and type in the information code error they have been working on a dowload patch to correct this . go there http://support.microsoft.com.
Mar 30, 2009 | Acer Computers & Internet
I get the Blus screen when trying to install a fresh copy of XP on my nx8220
If you are installing a fresh copy, you should boot from cd, and not start it from windows. It is less error prone.
Oct 27, 2008 | HP Compaq nx8220 Notebook
Computers & Internet Logo
27 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
