Question about Garden
Burnt wires on Lesco mower
Don't know where the two burnt wires go.
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 40 Answers
Broken parts however soon after scertainmen may be reinstalled with new functinning parts by ex[perts. find tools also with exerpts locations assitance negotiate timing to work o n brokent parts .
Posted on May 13, 2013
To who ever can HELP !! This is a electric junction block on a Chevy 4wd 1990 -95 with a 5.7 !! I would like to know where they go , color code's ect ect !! New harness , Old one burnt ! I "Don't want
If the new harness is an oem match then you can just go to autozone or where ever, and get a haynes manual. It has the wiring diagrams with color codes in the last section. Good luck.
Feb 04, 2013 | Cars & Trucks
Resistor going to my pto clutch burnt out
Your going to have to call the factory/customer service and find out what the resistor size is.Got Radio Shack and get a couple of them and solder one in.You don't want to run it strait without the resistor,could burn up something MORE important.Like the clutch.You can get Husqvarna online help too.Try Husqvarna.com.This new stuff can be a pain at times,but gotta havit.Rigger
Aug 28, 2012 | Cars & Trucks
Thermo fans won't work
if fan works at battery but doesn't when installed check for shorted out wire (grounding out) between switch and battery or possible the switch is burnt out or not making or braking contact (bad switch replace)
Nov 12, 2011 | Cars & Trucks
The 3.3 engen overheats but the fan doesn't kick in. I have changed the thermostat but that didn't help the over heating. I hot wired the fan and it will run. ???? Is there a fuse some place i...
Try unplugging the temp sensor located on or near the thermostat housing. This will cause the fan to come on, if it works. If the fan does not come on then check for burnt wires near battery and fuse box. You may need to squeeze and manipulate these wires to find burnt area. I have seen coolant temp sensors, faulty fan motors, and burnt fuseible links cause this. When unpugging the CTS the check engine light will come on, don't worry about it.
Sep 01, 2011 | 1991 Dodge Caravan
I have a 2001 mitsubishi mirage and the low fuel indicator light doesn't come on anymore. i don't know whats wrong with it.
your low fuel indicator bulb must have been burnt or the fuse in the box has been burnt, and needs to be replaced!
Aug 26, 2011 | Mitsubishi Mirage Cars & Trucks
I have a coleman central electric furnace model 3400-815 and a wire that connects the sequencer to the element burnt out. I'm not sure what caused the burn out so I don't know which part needs to...
The wire was probably loose on the terminal. This is very typical. Replace the wire end with a new spade clip. Make sure it pushes on to the terminal real good and tight and you probably won't have another problem.
May 14, 2011 | Heating & Cooling
Garden Logo
120 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
