Question about Fisher Price Power Wheels Barbie Jammin' Jeep
Power wheels Front tires are not straight. Both are bowed out.
    Novelist:
    Scholar:
  • 134 Answers
If the wheels are bowed out it is usually caused by the steering linkage being damaged. Power Wheels vehicles have a long metal bar that runs between the two front wheels on the vehicle, on either end of the long bar is a plastic bracket. The bracket is riveted to the long bar and sometimes that can become loose or bent.
Remove the battery and flip the vehicle over, inspect the linkage and also the front axles to see if they are bent or damaged. If any parts are they need to be replaced, also make sure the tires themselves are not damaged.
Here is a link to the parts you will need for the repair.
Linkage: http://www.mendingshed.com/powsteerlin7.html
Tire: http://www.mendingshed.com/jeepb7659.html
Front Axle: http://www.mendingshed.com/b7659axle.html
Axle Cap: http://www.mendingshed.com/noname4.html
Let us know if you have any questions.
Posted on May 14, 2013
I got a 1989 big bear it pulls to the right i put new tie rid ends and upper and lower balk joints in pulled cv axel it seems to be ok steering bearings seem fine also anyine have any ideas
Try aiming the handle bar straight and pull some kite string across the rear wheel , lightly touching the sidewalls of the tire. With the length of the string pulled across the front tire, adjust the outer tie rod so as to make front tire lightly touch the string. That should square the front tire to the back tire. Once the front and rear are squared, adjust tie rod in 1 turn for a slight negative toe. Do both sides while making sure to keep the handle bar straight during string and adjustment. That should help.
May 25, 2017 | Cars & Trucks
What could be wrong with my tire if it bows in
Bows in at top or bottom? More than likely
you need your suspension aligned. The tire just follows the suspension. Misalignment can cause tire wear and handling problems. Front wheel drive cars need 4 wheel alignment to insure the back isn't steering the front. Other causes are shock/strut or control arm bushing wear or failure. Tie rod ends or idler arm wear can cause tire wear as well.
All parts should be tight and serviceable before alignment.
Jan 13, 2016 | Cars & Trucks
One of my tires is straight and the other one is pointed outwards. the steering wheel is sideways as like im turning
The easiest way to do this is straighten the steering wheel first Brandon. Next is to walk to the back of the truck and eye ball the left front tire from a looking from the side of the back tire. If that one is straight ahead before or after you adjust it, Now check the passenger side the same way.When both look straight, now take a tape measure and measure the distance from the center tread on the right front tire to the center of the left front tire.Say its 61", now do the same behind the front tires. It might say 58". You want to end up with the front measurement being 1/4 of an inch smaller then the back.
Feb 01, 2014 | 1999 Ford F150 Regular Cab
What are the different types of bows?
Mainly there are 7 different types of bows, the Recurve bow, the Reflex bow, the self-bow, the Straight bow, the Longbow, the Composite bow, and the Compound bow.
Jul 30, 2012 | Archery
It road walks from side to side like the front end is loose. Have checked the steering gear box and tie rod ends and neither are loose.
make sure it is tracking right that is that the back tires are straight behind front tires try turning front wheels straight and get a string put it on the side of front tire and run it back to the rear tire string should be straight if not then the tracking is off
May 24, 2010 | 2002 Jeep Grand Cherokee
Noise when the car is at speeds above 40mph. kind of a waaa waaa waa noise.07 Compass 2weel drive. has 70,000miles and has used two set of tires, drives straight,tires wear straight but in the center.
if tires are wearing in the center it says that they are over inflated,the noise you hear could be tire tread hum or it could be front wheel bearing hard to tell without actually seeing your tires.
Jan 18, 2010 | 2007 Jeep Compass Limited
Rear end has problems tires are bowes out bad
sounds like your problem is a bad bearing
May 01, 2009 | 2000 Ford Focus
2000 sable...right front tire bald?
It could be wheel bearings/hub, ball joints, bent a-arms, or a-arm bushings. Good luck
Dec 03, 2008 | 2000 Mercury Sable
Fisher Price Power Wheels Barbie Jammin' Jeep Logo
1,062 people viewed this question
Top Fisher Price Toys Experts
Bill Boyd
Jennifer Rock
Jennifer Rock
NOEL
NOEL
Are you a Fisher Price Toy Expert? Answer questions, earn points and help others
