Question about Dryers
60932990 Kenmore ELITE won't dry!! It turns on just as normally as any other day. It will...
Run a whole 80 min cycle but at the end of the cycle nothing is dry
  • 636 Answers
Most likely the element is burn out. Fairly easy to change
Posted on May 12, 2013
oldTech2332
  • 2341 Answers
SOURCE: how to change a heating
This video will show ya how to replace that heat element
Posted on Sep 17, 2011
  • 35 Answers
SOURCE: Kenmore Elite Heavy Duty King Size Capacity Quiet Pack II Dryer shuts off
If the venting is clogged this will happen. And that is a good thing because it is a safety measure built in to prevent fires. There is a thermostat that can tell when your dryer is over-heating,(usually caused by clogged venting by lint) and this devise tells the heating element to turn off so as not to create a fire. Clean out venting, inspect thermostats and element, replace if neccesary. You may only have to clean out the venting.
Posted on Dec 09, 2007
  • 163 Answers
SOURCE: Kenmore Elite HE3 Dryer clothes not dry after cycle
it sounds like a clog in vent.if yours vents up thru roof you may need to have a chimney sweep come out and sweep vent.check and make sure the vent hose is net kinked or full of lint.
Posted on Mar 06, 2009
SOURCE: kenmore elite 110 62974100, it heats up and the
kenmore dryer elite he model 110- runs but has no heat
Posted on Oct 08, 2009
blueextc3221
  • 15935 Answers
SOURCE: Kenmore HE4T elite: Incomplete F 06 error
The error is an indication a motor speed problem. You will need to check the following:
- Check the wiring harness. Verify all connections between the Drive Motor, Motor Control Unit (MCU), and Central Control Unit (CCU).
NOTE: The MCU is a circuit board located in the vicinity of the Drive Motor on the bottom rear of the washer. To access the MCU, you will need to remove the back panel of the washer.
NOTE: The CCU is the main computer for the washer and is located behind the wash tub. You will need to remove the top panel to access the CCU. This is accomplished by removing the three screws in the back of the washer that hold the top in place. Once the screws are removed, the top panel will slide back, then lift off.
- Check the Drive Motor. Perform a continuity check of the Drive Motor windings. Remove the connector plug and check across pins 1 to 2, 2 to 3, and 1 to 3. All readings should be approximately 6 ohms. HINT: You can also take this reading by removing connector 2 from the MCU and measuring across pins 1, 2 and 3. If the readings are good, this will also prove the wiring and connector good.
- Check the MCU. The connectors are numbered 1 to 3 (L to R). That is, with the MCU installed, connector 1 is on the bottom, followed by 2 in the middle, and 3 on top.
Connector 1 - is the serial communications link between the MCU and CCU and has three wires. At the opposite end, this will be the 2nd connector from the rear on the left-hand side of the CCU.
Connector 2 - is the link between the MCU and the Drive Motor. Pins 1, 2, and 3 on this connector are the Drive Motor windings. Pins 4 and 5 are for the tachometer.
Connector 3 - is the primary power connector. Pins 1 to 2 should read 120VAC with the door in the locked position. Pin 3 is ground. At the opposite end, this is the 4th connector from the right on the front of the CCU.
NOTE: All the connector pins are numbered R to L.
If your continuity readings are normal for the Drive Motor and you have verified all connectors, replace the MCU.
If any of the Drive Motor windings indicate readings higher that 6 ohms, replace the Drive Motor.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 23, 2010
My kenmore dishwasher doesnt heat during drying
The heating element is burned out or the heating circuit is fubar.
Sep 08, 2016 | Kenmore Dishwashers
Why won't the buzzer alarm go off at the end of a drying cycle
Search Results
    Why does my Kenmore dryer model 417.94802/94862 end ...
    www.shopyourway.com > Manage My Life > Questions
    Why does my Kenmore dryer model 417.94802/94862 end of cycle alarm go off ...washer/dryer unit I do see that it is normal for the end of cycle buzzer to go off ...Why won't my Kenmore dryer model 110.86872100 shut off at the end of the ...
    Why won't the buzzer shut off on my Kenmore 80 Series ...
    The buzzer won't stop buzzing after the load is complete. ... or turn on the timer and the dryer will start just by selecting a cycle and closing the door. ... The dryer should continue to run and at the end the buzzer should only stay on as long as ...
    FIXED The Buzzer At The End Of The Dryer Cycle Comes On But Won't ...
    www.applianceblog.com/.../21739-The-Buzzer-At-The-End-Of-The-Dry...
    Dec 11, 2010 - 10 posts - ‎2 authors
    My maytag dryer has operated wonderfully until today. All of a sudden the buzzer that goes on at the end of the drying will go on but will not shut off unless I open the door.... To test it: by-pass the push-to-start switch and see if when you turn the timer on and close the door, the ... VERY annoying dryer End of Cycle Signal
    Jun 29, 2012
    Maytag DE8410 electric dryer - End of cycle buzzer stuck ...
    Mar 27, 2011
    Kenmore 80 series, buzzer won't shut off
    Sep 10, 2005
    More results from www.applianceblog.com
Feb 08, 2016 | Whirlpool Dryers
I have a Kenmore elite dishwasher M#665.13419k701, when you run the cycle it shuts off after about 10 seconds and the normal wash light blinks. what can i check??? Thanks. Israel
Hello, welcome to FixYa.
I understand by reading your post which indicates it is a Kenmore dishwasher you appear to have a concern with the cycle interuopting and the "normal" light flashing.
I'd suggest you first try entering a diagnostic/test...to do so is as follows. Press the following buttons in this sequence...
HEATED DRY - NORMAL, HEATED DRY - NORMAL, HEATED DRY - NORMAL
This diagnostic may take approx. 15-20 minutes to complete. Let it proceed through to completion and let me know what happens and we can go from there.
Regards,
Macmarkus :)
Aug 19, 2011 | Kenmore Dishwashers
I also have a Kenmore Elite Smartheat quitepak 9 HE4. It takes forever to dry in the Auto modes and it still leaves them damp. However the Manual modes dry great. I suspect the Auto modes has some kind...
if its a condenser dryer for some unknown spastic reason we have come across some where 80% of the settings didn't dry the clothes we then found out this how they were suppose to work (dont ask me why still havnt figured that i think it was something to do with ironing and not needing to use steam because they are already damp yeah i know doesnt really make a whole lotta sense to me eitha), you need to look up what cycles actually do what as i found only manual and 1 other setting actually completely dyed the clothes
Feb 09, 2011 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite HE4 Electric Dryer - heat but not drying
you have thermistor failure/ located inside machine reason for premature heat
Oct 07, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore elite model 110639101
check for blocked vent tube.You should have a very strong flow coming out.If it is weak it will run badly.It is a common call.If its not weak air flow than run the dryer for at least 20 minutes.Open the door and if has no heat inside .......change the split coils. Please Rate This !!!
Sep 15, 2008 | Kenmore 62602 Electric Dryer
Dryers Logo
Top Dryers Experts
Dan Webster
Dan Webster
