SOURCE: speakers
400 watts delivered to 300 watt speakers the only way to do this would be to wire two subwoofers in series so that the power needed to drive them will be 600 watts to max, however this will increase your impedance on the speaker (8 ohms) load so what you can do to compensate is get an 8 ohm 600 watt resistor and put it in parallel with the speakers you will then have 4 ohms of impedance at a total capacity of 600 watts of power In other words the amplifier won't blow these out now.
SOURCE: Speakers
Hi Trim God, I do not reccommend that you push the Pioneer speakers over 100 watts. The jenson will already drown the car with bass through your pioneers so much you will want to turn off the bass boost when playing some low bass hip hop songs. It changes from one venue of song to another, so I just keep the jenson bass boost off and use my head unit to adjsut the sound to fit my listening prefences. I am telling you man, you will be blown away . Hook up the pioneers straight to the Channels,. do not bridge. I put Subs in my truck though. I used the Pass output to send the audio to me Jenson 2 Channel 600W amp. I drive one 10 inch enclosed JBL Class A/B Sub. I bridged the output of the 600 W amp to the 10 inch sub in my Z28. The pioneers never get drowned out. I did smoke my 2 channel Amp one time. and also took out a MTD 10inch sub. I am talk shooting flames and smoked the whole car up. I think if you bride the XA4150 to the pioneers, you will have the flaming smoke problem in no time.
SOURCE: amp getting really hot
If depends on what the amp is rated to run. If it is only rated to run 2 ohms x2ch then it can only run 4 ohms x1ch. If you run it at 1 or 2 ohms that is too low, too much current, and it will get hot and eventually blow up under hard use. Some quality amps can live that way, and it depends on the sub and what frequency you are running it at. For normal use I would not recommend it. Wire to sub at 4 ohms x1 (or 2 ohms x2ch) for that amp if that is what it is supposed to be at, I'm not sure from your description. Also enhance cooling of the amp if you can, I run fans on mine if they have a heat issue. Warm is one thing, hot is another and not good for amp.
SOURCE: JL audio 250/1 not powerful enough for pioneer TS-W307D4?
you should move up to more power....underpowering subs is bad! try not to go under the subs rms by 5o watts?
