Question about Gateway DX432001e Microtower Desktop
Removing Left Side Panel (If looking from the back side)
How would one remove the left side panel on from the back side of the case. I have removed all six screws anchoring it to this side but it seems the part that is still there is connected to the plastic part on top. In dire need of help.
  • Gateway Master
  • 7,627 Answers
Look for a thumb screw half way down the right side. Try here for a User Manual: http://support.gateway.com/product/default.aspx?modelId=2285
Posted on May 11, 2013
3 Suggested Answers
  • 233 Answers
SOURCE: how do you remove the cover to clean the inside
Get a can of compressed air. You can buy it at any computer store. Blow through the front cover from inside the computer. That should get the dust out. Make sure to blow through the fins on the heat sink that sits on the processor. Blow out all the fans inside the case and on the power supply unit. Don't use a vacuum cleaner. You might **** up some small piece like a jumper on the motherboard which would cause you more problems.
Posted on Jan 18, 2009
joecoolvette
  • 5660 Answers
SOURCE: i need to replace the small fan on back of gateway sx2801-01e, how do I get it out after removing side panel?
Hal,
You're going to have to help me out here. I don't see it,
http://blog.itechtalk.com/2010/review-on-gateway-sx2801-01e/
Scroll the page down to the bottom, and the photo that shows the Side Panel removed.
All I see is the Processor fan, and the fan for the Power Supply.
That is the metal case with the odd shape, at the bottom right of the computer view.
Rear view of Gateway SX2801 series of Desktop PC's,
http://support.gateway.com/s/desktop/2009/gateway/sx/sx2800/SX2800rv.shtml
If this is the fan that is not working, replace the Power Supply.
Inside that Power Supply are Capacitors.
A capacitor is designed to slowly build up a charge, then release it all at once.
There are cameras that use them for their flash units.
A crude example would be a large swimming pool, filled up by a garden hose; then one wall of the pool is taken down all at once.
Even after the Power Supply is unplugged from power, those 'Caps' can hold a charge for weeks, months, a lot of times over a Year.
If your fingers, accidentally touch the terminals on the bottom of a capacitor, the charge can be released to YOU!
If your fingers accidentally complete a circuit, that one, or more capacitors are in; the charge can be released to YOU!
Shock ranges from BAD to FATAL.
[The Input Stage uses Capacitors that can hold a charge, of Up To 100 Volts ]
For additional questions please post in a Comment.
Regards,
joecoolvette
Posted on Mar 26, 2013
Removing ASUS CG8350 cd drive
Facing the front of the computer is how you determine the Left side, and Right side.
The Left Side Panel removes.
Two screws to loosen. One towards the Top, on the back edge of the left Side Panel; one towards the Bottom.
(Screws should no remove all the way, unless clip is missing from screw)
There's a Fingerpull formed out of the back edge, of the left Side Panel. Pull back, remove.
There should be plastic clips formed out of the Front Panel, that when depressed, or gently pulled out on; will enable removing Front Panel.
WATCH as it may NOT just be a cover.
The Power On LED light (Asus), plus Power On switch, and Harddrive activity LED light, may be attached to the Front Panel.
This is a different Asus desktop computer case, but allows me to show you the clips I am referring to,
http://pctuning.tyden.cz/hardware/pc-sestavy/22300-asus-rog-tytan-seriova-kraska-za-60-tisic-korun?start=5
Scroll down to the photo of the open computer case.
See the three dark plastic tabs on the Front Panel?
One towards the Top, one in the Middle, and one towards the Bottom.
For this type the clips are gently eased out. (They are PLASTIC)
I could be wrong, but I imagine the blue round looking 'knobs', on the side where the optical drive bay is; turn to the Left to remove.
I think the blue round part is a screw head.
Could be wrong. May be they are just gently pulled out on, to release the optical drive. (CD/DVD drive)
Power unplugged to computer.
Anti-Static Procedures -> FOLLOWED
Regards,
joecoolvette
Apr 07, 2013 | ASUS Computers & Internet
How do i open the acer al5100
From Acer Support,
"Opening the computer:
Remove the screws on the chassis. Slide the panel off"
Yeah, okay Acer.
To convert this computer to a tower position. there is a Stand.
Does the computer just sit in this stand, or are there screws that hold it to the computer case? If present they would come up from the Bottom. Remove.
Looking at the back of the computer case, with the computer standing up; it appears there is a Triangle shape, coming off the LEFT Side Panel.
Appears to be about halfway up.
Looking at the Front of the computer, the Left side.
Looking at the computer from the Back, it's the right side.
Triangle shape coming from middle of left side, has the 'top
cut off. Remove/loosen the single Philips head screw.
Pull BACK of the Side Panel.
Regards,
joecoolvette
Feb 20, 2013 | Acer mb.sa409.002 - Al5100 Vl410 Desktop...
Remove hard drive from tower case gateway 815 gm
http://support.gateway.com/s/PC/R/4190/4190nv.shtml
Looking at the rear of the computer;
A) Two thumbscrews to loosen, then remove the Left Side Panel.
B) Two Philips head screws to remove for Right Side Panel.
(Designation of left/right Side Panels are looking from the Front, of the computer)
Pop the Front Cover off. WATCH the wires so they do NOT get disconnected from the motherboard!
Slide the right Side Panel back about an Inch, then lift out, and off.
Click on - Gateway Computer User Guide - in blue.
Now remove the 1 or 2 Philips head screws on the right side, that hold the Harddrive into the harddrive bay.
Regards,
joecoolvette
Aug 06, 2012 | Computers & Internet
How to open gateway 300c desktop
There are several casings. You'll just have to pick one that fits your computer. Before you begin anything. Turn off your computer and remove the power cable. New Midtower Case 1 Look for a release handle on the top of the new midtower case. 2 Push the release handle inward. 3 Swing the case down from the top to open it. Microtower Case 1 Lay the computer down so that the left side is face up. 2 Locate two cover release levers on the back of the case toward the middle of the left side panel. 3 Squeeze the release levers together, then lift the panel up, swinging it away from the back of the case. Old Midtower Case 1 Lay the computer on its side, so that the left side panel is face up. 2 Remove any retaining screws along the left side of the back of the case that are holding the panel in place. These screws may be removed with your fingers. 3 Locate two release levers at the top and bottom of the back side of the case, and push them away from each other. 5 Swing the panel up and away from the case to open it while holding the release levers.
Jan 01, 2011 | Gateway 300 C PC Desktop
How do you take apart the tower
Turn the computer off.
Disconnect the AC power.
Look at the "back" panel.
You might see thumb-screws that hold the side-panels in place,
or you might see Philips-head ("cross") screws.
Or, you might see plastic "locks" -- slide them 1/4 inch to "unlock" the side-panel, and lift it off.
Or, look at the side-panel -- there may be a "lever" (like a "tab" on the top of a pop-can) that can be lifted to release the side-panel.
Or, older towers had a "one-piece" cover (like an upside-down "U") that needed to be unscrewed, pushed slightly towards the back ot the case, and then vertically lifted off.
Aug 29, 2010 | Gateway GT5220 PC Desktop
Need to remove the dash on a 1998 lincoln town car to replace heater cord
Removal & Installation
  1. If equipped, turn the air suspension service switch to the OFF position before raising the vehicle.
  2. Drain the cooling system.
    1. Remove or disconnect the following:
    2. Negative battery cable
    • Front seats
    • Carpeting
    • Rear airflow duct
    • Heater hoses
    1. Remove the driver’s side air bag module by removing or disconnect the following:
    2. SRS module-to-steering wheel bolts, from both sides of the steering wheel.
    • SRS module and disconnect the electrical connector
    • Horn switch electrical connector
    1. Remove the passenger’s side SRS module by removing or disconnecting the following:
    2. Open the glove box and disconnect the glove compartment isolator
    • Push inward on the 2 glove box door tabs and lower it
    • SRS module’s electrical connector
    • SRS module-to-instrument panel bolts and the module
    1. Remove the instrument panel by removing or disconnecting the following:
    2. Speed control servo nuts and move the servo aside
    • Bolt and disconnect the left side bulkhead connector
    • Left side bulkhead connector from the dash panel
    • Windshield washer fluid reservoir screw, and position the reservoir aside
    • Blower motor electrical connector
    • Air conditioning pressure cut-off switch electrical connector
    • In-line electrical harness connector
    • Electronic Automatic Temperature Control (EATC) variable blower motor controller electrical connector
    • Right front wheel
    • Right front fender splash shield bolts and move the shield away from the cowl
    • Wiring harness from the evaporator case
    • Wiring harness from the cowl
    • Right side instrument panel lower insulator pushpins, disconnect the power point electrical connector, remove the courtesy lamp from the socket and remove the insulator
    • Unseat the wiring grommet and feed the wiring harness through the cowl
    • Cowl side trim panels and the windshield side garnish moldings from both sides
    • Locking clip and the Electronic Crash Sensor (ECS) module electrical connector
    • Antenna connector
    • Ground wire bolts from the right side
    • EATC hose at the evaporator housing
    • Bolt and disconnect the bulkhead connector from the right side
    • Pull the door weatherstrip seals away from the instrument panel on both sides
    • Tunnel brace trim cover
    • Climate control head vacuum harness connector
    • Instrument panel tunnel brace nuts and the brace
    • Ground wire bolts from the left side
    • Wiring harness connectors from the left side
    • Parking brake switch electrical connector
    • Pry out the instrument panel defroster opening grille, disconnect the electrical connectors and the remove the grille.
    2. 3 upper instrument panel screws
    • Instrument panel cowl side nut from both sides
    • Instrument panel cowl side bolt. From the left side
    • Instrument panel
    • Windshield wiper mounting arm and the pivot shaft
    • Electrical connector and remove the upper cowl extension screw and the extension
    • Vacuum hoses and the wire harness connector from the evaporative emissions canister purge valve
    • Evaporative emissions purge valve nuts and the valve
    • Cowl side nut
    • Right side rear fender apron screws and reposition the apron
    • Evaporator housing nut and screw
    • Vacuum hoses and the wiring harness connectors
    • Plenum chamber’s lower flange nuts
    • Plenum chamber’s upper flange nut and the plenum chamber
    • Heater core cover-to-heater plenum chamber screws and the cover
    • Seal and the heater core
  • May 26, 2010 | 2000 Lincoln Town Car
    Cover removal
    On the back of the system case are an green knobb, puch it downwards and the HDD lid on the right side pops open.
    Push it upwards and the left side panel opens up.
    Regards
    HobbyData
    Feb 10, 2010 | Dell OptiPlex SX270 PC Desktop
    How do i remove the cover of a Gateway MFATXPNT NMZ 500SE
    I found this:
    "Facing front of computer you need to remove the left side cover. cover release is on top of the computer in center of side panel. Press in on button and p[ull top of side cover away."
    Don't know if it's useful. If not let me know and I'll keep looking.
    Mar 16, 2009 | Gateway Computers & Internet
    Cant open the case to my HP pavilion 700
    First, turn off the PC, remove the power cord from the back of the PC to remove the 115 volts then push the power button for a second or two so the capacitors will discharge. This is important because the residual charge can cause Motherboard damage especially when changing the RAM. You should follow this process ANYTIME you enter the PC case to make changes, etc.
    To remove the side panel on a Pavilion 700x series:
    Only one side panel allows access to the inside of the Pavilion case, the left side if looking from the front of the PC. The left side panel has knurled thumbscrews, not machine screws. Loosen the thumbscrews, they are designed to stay attached to the side panel, place your hand on the middle of the side panel and with inward force push the panel towards the back. The panel will slide and inch or two and you can pull it free. This proccess is easier if the PC is unplugged (push the power button on the front of the PC after pulling the power cord to dischard the capacitors) and the right side of the PC laying on the floor. This allows easy access to the left panel and allows light to enter the case from above to change/add the RAM you want to install.
    Apex44
    Mar 03, 2009 | HP Pavilion (PN153AAR) PC Desktop
    41780042990 Kemore electric dryer
    you would need to "punch out the metal" , youl also need to remove the fron tof the unit(2 screws approx 3-4 inches down form inner panel, holding front panel on, ( youll need to remove the top of the dryer( a few screws across the back of unit.) andthen disconnect the dryer belt(easiest acess through a small acess panel on lower rear of unit, pull the dryer drum out and youl see the existing ve, just a matter of attaching a 90degree elbow and running vent out the side instead of out the back. DISCONNECT POWER TO UNIT FIRST!!!!!!!!!!
    Oct 26, 2008 | Frigidaire FEQ332E Electric Dryer
    Gateway DX432001e Microtower Desktop Logo
    75 people viewed this question
    Top Gateway Computers & Internet Experts
    Prashant M
    Prashant M
    Matthew Spark
    Matthew Spark
    Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
