Question about Ovens
Timer won't stop going off. St.George Grillmaster
I cannot seem to stop my oven timer going off on a very old St.George GrillmasterI oven, two small dials and one larger which has the clock and timer. Have tried pushing the knob in and turning, it stops for a few minutes then starts again. It's goes and goes at all hours please help I do not have a manual.
  • Barb Coward May 12, 2013
    When you push the clock/timer dial in to turn the hands and the timer dial the buzzer stops, but then out of the blue a cople of minutes later it starts again, even though the timer never ever gets used. Cannot seem to permanently get it to stop going off. I can only delay it if I move the timer hand around.
2 Suggested Answers
SOURCE: turn off the timer on an old imperial st george
I have this exact same oven and this "feature" annoys me no end. To turn it off ... turn the clock dial to PAST the time that the timer dial shows. EG: If your timer dial is showing 6, turn the clock dial so that it rolls past 6 o'clock. This will pop out the timer dial and thus turn off the timer, allowing you to use the oven normally.
To stop accidentally pushing/turning that timer dial, I removed the knobs. Good luck.
Posted on Oct 03, 2010
My St George Electric oven keeps turning itself off.
Possible checking the power switch, the timer control unit and also if there is any power trip in the circuit.
The most possible chance could be related to the timer unit, so reset the timer control , try setting to higher levels and see if the power holds on.
Jul 09, 2015 | Ovens
Replaced EOU43002X element, clock/timer now dead
Make sure there is power to the timer. Should be a fuse somewhere.
Mar 19, 2014 | Electrolux Ovens
I have an old Simpson fabulous 300 bench top stove in our beach house. We are unable to get the oven to work at full power. We have fiddled with the timer dials in the past and always get it going but it...
First of all, thank you very much Lindsay for choosing FIXYA today for your online technical support needs.
I'm Joe, and I will be more than happy to assist you with your service request.
Unfortunately a User's Manual for that particular SIMPSON appliance is no longer available.
However the problem is most likely that your TIMER has been set to AUTO which will prevent the oven from functioning. The timer needs to be set in the MANUAL mode.
Here are a few links to some other online resources which describe the various procedures for setting the clock and switching the timer mode which may help with your particular problem:
http://reviews.ebay.com.au/Things-to-check-if-your-electric-oven-won-apos-t-heat-up?ugid=10000000001213735
http://john.daltons.info/appliances/Simpson%202001%20Instructions.html
http://product.electrolux.com.au/Public/File/14880 (SELECT OPEN FILE)
http://www.simpson.co.nz/FAQs (SELECT ELECTRIC COOKING FOR APPLIANCE TYPE)
http://www.ehow.com/how_7382695_set-timer-simpson-wall-oven.html
Just use your mouse to click on the links, which are the underlined and blue highlighted sections of text just above. This will open a new web browser page automatically for you and allow you to view the information at the websites indicated.
I truly apologize Lindsay for not being able to provide you with the exact support documentation that you requested, but unfortunately on occasion the desired material is simply not available online.
I still hope this was at least somewhat helpful to you.
Good luck and take care.
Joe.
Jan 15, 2012 | Stoves Ovens
I have a New World Twinline 4000 double oven which is approx 15 years old. The progammer has developed a fault and I cannot set the clock, therefore the oven won't switch on. Is this repairable because...
You need to take the timer out of the circuit (you will only be able to run the oven without timer).
1. Switch off the mains or disconnect the oven from mains.
2. Pull out the 5 buttons of timer. Might need to apply a bit of force but they should come out fairly easily.
3. Pull the two temperature adjustment knobs out.
4. The glass decorative plate is attached with some sort of clamps so if you pull it off the oven it should come off as well.
5. Take out the 3 screws on top of the oven above the wireing. You should be able to bend the metal panel up a bit.
6. Take out the 3 screws that secure the side panel by the front panel. You should bend the panel out here as well.
7. Now you should be able to see inside behind the timer unit. There are two clamps on each side of timer that keep it in place. From behind they can be pressed in so the timer can be pulled out towards the front.
8. Once done take a look at the wires that go into the timer unit. There are four: A, B, C, D. Disconnect all but make sure you mark them which is which.
9. You will not need wire A and B so put insulating tape on the metal connectors and let them hanging loose. The are the power source of the timer.
10. Cut the connectors off of wire C and D, and solder them together. Then put insulating tape over the bare soldered wire. The timer is now cut out of the circuit and can only be switched on/off by the temperature adjusting knob.
11. Tuck the wires back into the appliance making sure they are loose and well placed, possibly far from the oven side.
12. Lock the timer back in place if you want. It is going to be a dead weight doing nothing so it is not necessary to put it back.
12. Assemble the coverings in reverse order as described above.
You should be a working oven now with the annoying bit removed and being better off a few hundred quid.
Jul 21, 2011 | Ovens
I have an old electric oven. Somehow after touching the timer settings the oven will now not work. What do I need to set the timer options to. The timer is adjusted using knobs - one for the clock and...
The timer must be in manual mode for the oven to work. Turn the oven ON. With the oven turned on make adjustments to the two knobs. These are generally stop/start timers. These turn and you can also normally press them in. Be patient. When the oven indicator light comes on it will be fixed.
Mar 02, 2011 | Ovens
Hotplate won"t turn off st george cc-600 cooktop
I have a St George glass cooktop with temperature sensor light.It takes forever for the light to go out when I use the main element and that section often feels like it is still heatinglong after it has been turned off.Can there be power leakage through the switch for the main element
Aug 21, 2010 | Ovens
Hi the temp on our st george oven, model ueo-8 has become unreilable?
if digital the replace the oven control / if dial then the dial is at fault . mm
Jul 12, 2010 | Ovens
Turn off the timer on an old imperial st george
Jan 23, 2010 | Ovens
MY 24 INCH BUILT IN SINGLE WALL OVEN DIGITAL TIMER
turn power off at main box the back on retry st set clock . if it won;t set / replace it . it has gone bad .mm
Dec 09, 2009 | Maytag 24" Built-In Single Electric Wall...
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
