Question about Canon i850 InkJet Photo Printer
Canon i850 printer is printing striped colors
I have new cartridges in the printer and have aligned the heads (problem shows up on column B/E/G/J/K of alignment test sheet).
Getting stripy print quality-looks terrible.
    Novelist:
  • 85 Answers
HTML clipboardIf you have lots of flashing error lights or electrical problems then it is likely to be electrical.
However, if like most... and your printer has just been left unused for some time?
Then provided it worked OK before a period of non-use? You just need to use a PRINT HEAD CLEANING KIT to unclog the tiny jets.
A Magic Inkjet Flush Kit usually works a treat on those!
Magic is ideal for unclogging the tiny jets on any Canon, Epson HP and removing those horrible white lines which usually appear in prints when dried ink clogs several jets...
So if yours appears to be a clog? all you should need to do is to use the Magic Inkjet Flush kit to soak the print head and you should be printing again like new.
You are covered by a 30 day money back guarantee if not.
Good Luck!
Tinteiros (Ebay)
Posted on Mar 22, 2009
SOURCE:
The black color doesn't print.
I have to ask this question of you, just to make sure this is not an issue. Are you using a factory new ink cartridge?
Please consider the following:
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
If you are using factory new cartridges, then please call the manufacturers Technical Support for assistance with the warranty on the cartridges
Don
Feb 05, 2010 | Canon i850 InkJet Photo Printer
Printing problem
  1. Open the Printers folder.
    • For Windows XP Select 'Start', 'Control Panel', 'Printers and Other Hardware', and 'Printers and Faxes'.
    • For Windows versions other than Windows XP select 'Start', 'Settings', and 'Printers'.
  2. Right-click the printer icon to open Properties.
  3. Click the 'Maintenance' tab and click the 'Print Head Alignment' icon.
  4. The message below is displayed. After confirming the two points below, click 'Print Head Alignment'.
  5. The following message is displayed. Click 'OK'. Print head cleaning starts. The power lamp flashes during cleaning operation. Do not perform other operations. After cleaning has finished, the first head alignment pattern will be printed.
  6. The following message is displayed. After printing has finished, click 'Yes'.
  7. Refer to the printed sheet, and select the pattern with the fewest visible vertical stripes in column A.
    <1> Example of highly visible vertical stripes in the pattern.
    <2> Example of the fewest visible vertical stripes in the pattern.
  8. Enter the selected pattern's number in the Column A box.
  9. Similarly, enter the selected numbers in the boxes for column B to F.
  10. After all numbers have been entered, click 'OK'.
Apr 09, 2008 | Office Equipment & Supplies
Canon i550 not printing any color, Prints in black OK but no color.
Please check nozzle head pattern first. Is your print head pattern printed perfectly?. Be sure that the print head pattern is ok. No missing line or column. If your nozzle colour is not printed at all even just one point,check the print head or try to clean the print head.
e-manualshop
PrinterClinic
Jan 03, 2010 | Canon i850 InkJet Photo Printer
Printing, but not full words Canon i850
Sounds more like the actual print head has become dried out and simply needs to be cleaned. This is a common problem with Canon Bubble and Ink Jet printers.
You should be able to remove the cartridge and then the print head shuttle that moves across the page. Once you have it removed, you will need to get a couple of Q-tip swabs and some DENATURED ALCOHOL, NOT RUBBING ALCOHOL as the water in rubbing alcohol will damage the printer head. Wipe the face of the printer head GENTLY with a moistened swab, you should see the dried ink dissolve, do this a few times until you see no further ink on the swabs.
Allow it to dry for a few minutes and then reinstall it into the printer. You will need to run the alignment function of the printer to ensure that the print is aligned properly. That should do it.
Cheers,
Keith
Sep 19, 2009 | Canon i850 InkJet Photo Printer
Canon i850 printing but pages are blank
I had the same problem after changing the black ink cartridge. I went to Control Panel of my computer, chose Printers, then Canon Inkjet. Chose Properties, then Maintenance, the Deep Cleaning. NOW my printer is working!!
Jun 16, 2009 | Canon i850 InkJet Photo Printer
7 yellow flashes not printing
hi welcome to fixya!
I believe there is no print head failure happening. I experience that one time, it only needs a new ink cartridge. Be sure to replace the right color!
have a nice day!
Apr 17, 2009 | Canon i850 InkJet Photo Printer
Canon MultiPASS MP700
I had the same problem. My 4 year old MultiPASS MP700 started banding magenta stripes across everything I printed.
I suspected the cyan printhead was clogged because the printhead tests showed two of the cyan columns as half missing.
Canon was less than helpful. I went off of my suspicion that I needed a new printhead. I found one from an online supplier for 50 bucks...better price than a new printer! I put the new print head in and it works like new.
http://www.precisionroller.com/print-heads-for-canon-multipass-mp700/products.html
Jan 14, 2008 | Canon MultiPASS MP730 All-In-One InkJet...
Every 4th or 5th line does not print
try running your maintenance program.
go to your printer settings
right click on canon i850
left click on properties
run cleaning or deep cleaning,
then print head alignment and/or nozzle check
Dec 19, 2007 | Canon i850 InkJet Photo Printer
Canon i850 InkJet Photo Printer Logo
257 people viewed this question
Clive
Clive
old marine
old marine
