Question about Garden
718k grasshopper bad oil leak at back of motor under clutch any ideas
jdlipscomb41
  • 157 Answers
SOURCE: I have a Grasshopper zero turn mower that uses
yes just reguler hydralic oil it wont hurt a thing. but dont use atf its for transmissions in vehicles
Posted on Oct 26, 2009
wireguy212
  • 1627 Answers
SOURCE: has a bad oil leak coming from under the car . The
The oil pressure sending unit screws into the engine block so you will need to look between the oil pan and the head.I suggest that you try tightening your oil filter first.
Posted on Dec 21, 2009
wracefans24
  • 1985 Answers
SOURCE: leaks oil on the exaust.smoke comes up from back
the tapping is probably from low oil level,you need to keep it full untill you repair the oil leak
Posted on Dec 28, 2009
  • 209 Answers
SOURCE: oil leak
It could be the valve cover gasket that is out
Posted on Apr 07, 2010
junk9
  • 150 Answers
SOURCE: 2000 go tracker bad oil
It has to be an oil pressure sending unit. There are two of them on that SUV but they are in different places depending on your engine cord. If you go to Advance Auto parts or O'Riley, they will tell you exactly where to look.
Posted on Nov 19, 2010
I have a grasshopper 718k and the clutch(operating blades) will not engage.
check for a blown fuse. then check for a bad pto switch and then check your circuit board ( i am leaning towards this )
Oct 10, 2013 | Garden
Oil leak around electric clutch
they do float there is grease in the pulley no oil most of the time there is oil in the area its leaking from the lower crank seal
Apr 19, 2012 | Craftsman 20 hp 42 in. Deck Yard Tractor
85 hilux 4x4 have no clutch when checking found fluid leaking from rubber boot at the arm pretruding from gear box how do you repair this? cheers roger
bad slave cylinder possible. may even be a bad clutch master cylinder.was leaking from firewall? not bad clutch mastercylinder. was leaking under car on passenger side at front of tranny, but in between motor and tranny where motor bolts to transmission? most likely, bad clutch slave cylinder. having to add brake fluid to clutch master cylinder? having to pump the clutch pedal up to shift gears? either you have a bad clutch slave cylinder[leaking under the car between motor and tranmission] or leaking on firewall [the wall that under dash and under the front window] you may even need a clutch replacement.3 if you need further assistment,repost your question to fixya.com
Dec 26, 2010 | 1985 Toyota 4Runner
Just bought my truck its leaking kinda bad under the fan clutch cant tell were any ideas?
If i had an idea of what truck you have, engine size, year and what is leaking I might have an idea.
Nov 11, 2010 | Ford F-250 Cars & Trucks
My Kenmore Elite washer spins to slow cauisng the
If this is occurring mostly on heavier loads your clutch may be slipping. If you take a flathead screwdriver and push down the lid switch so the washer will spin with the lid up, grab the inside of the drum. If you can easily stop the drum its most likely a bad clutch. If you tip the washer back and see oil underneath then its probably your transmission leaking oil onto the the clutch causing it to slip (in which case you need transmission and clutch assy). If you see oil I would probably not bother calling a tech it would be a pretty expensive repair.
IF the problem is with the clutch only it may be worth repairing but to replace the clutch you will have to remove the pump, motor, transmission, and the clutch mounts on top. The other less common possibility could be a bad drive block under the inner tub. hope this helps. _MJ_
Jan 28, 2010 | Kenmore 15864/15862 Top Load Washer
Leaks oil on the exaust.smoke comes up from back
Dec 28, 2009 | 1995 Honda Accord
Washer wont spin heavier loads
If this is a basic top load, direct drive washer, that can be caused by a badly worn clutch slipping under load. An easy way to check is to use a object to depress the lid switch actuator, and operate the spin cycle with the lid open, if the motor is running but the basket is not turning, reach in and give the basket a little help. If the basket starts to spin with assistance, you need to replace the clutch. Also check if the gearcase is leaking oil, if so, replace both, as the leaking oil can contribute to the clutch slipping.
Nov 20, 2009 | Whirlpool Washing Machines
Whirlpool washer won't spin
most likely just clutch ck for oil or water on it if oil most likely top seal gearcase is leaking ..remove agitator cap remove bolt in middle of agitator ..remove console screws remove clips under console holding cabinet on remove cabinet ..lean washer back remove pump then motor remove the 3 bolts holding gearcase in remove gearcase clutch is silver disk on top of gearcase with band inside ..band is actual clutch may try cleaning it but not hopeful about it being a permanet fix
Nov 12, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Garden Logo
56 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
