Question about JBL PB12 Subwoofer
JBL PB12 standby WAY too sensative
I listen to classical music that tends to have a very wide dynamic range. At lower volume levels this amp turns off, or even worse, flickers on/off very rapidly. Just turning the music up is not possable unless I want my house to rumble to the DJ's voice after the piece is over. Is there a way to disable this standby? Or better yet, is there a way to lower the threshold or extend the time before it goes to standby? Like 5-10 minutes after threshold is met, unless it is again exceeded. Like a how a screensaver works on a PC. Great sounding system, have had it for about 6 years. Thanks for any solutions. And a shaking of the fist for any bad news. :P
  • hermesvs Aug 12, 2007
    UPDATE
    The woofer still has the sensative standby problem but now is very distorted. I was hoping my problem was different then the countless others I've been seeing, but this appears to look more and more like a bad amp. Needless to say it is unplugged until I find, or can afford, a solution.
    Please prove me wrong with an easy (or at least cheap) fix.
Capacitor C42 is bad. You should have a 15 minute pause before going back into mute mode. If the cap. is really bad it will distort the sound and cause cutoff.
David S.
Linacrepairman@yahoo.com
Posted on Feb 12, 2009
    Genius:
  • 1,689 Answers
It sounds like there are failing parts in the amp and possibly in the power supply sections. You should contact JBL to find out their service rep in your area.
http://www.jblpro.com/contact/form_dir.html
This unit will not be cheap to service. But, you can start by investigating to know where you are going with it.
Jerry G.
Posted on Apr 28, 2008
JBL PB12 will have loud thump or pop!
First try to find the source of your problem. The easiest way would be to try your sub with a different audio source to see if the problem still occurs but is sounds more like there's a problem with the receiver.
Oct 18, 2012 | JBL PB12 Subwoofer
How do i calibrate my powered subwoofer for my car
OK assuming you are referring to after market sub and amp whether or not added to factory head unit (stereo). #1 start your engine, and have your amp adjusting knobs accessible #2 insert a CD of the most listened to type of music (Rock,rap,classic) #3 adjust your stereo volume to YOUR max preferred db level with your amp levels at the lowest settings possible #4 start by increasing your freq. rang by 2 bands at a time then the same with gain, once you have gotten your bass to the level you like with out distorting or popping try increasing your bass boost (if available) till your preferred sound(may need to back off gain and freq. add bass boost accordingly until you like what you hear.play around with it for a while make sure you do this at the peak volume in which YOU listen to music because if you do it at a low volume and then turn it up you can blow your equipment . side not 8''in is for very fast bass reps, 10''in is for average rock and 12''s 15''s 22''s are for your low long deep bass reps such as rap and R&B anything else just e-mail me
Jan 10, 2012 | Mazda MAZDA3 Cars & Trucks
Pb12 makes thumping sound after warming up
Hello there..Thats normal only if your sub volume and the pre amp is turned up..Your amp is the cause of the speaker jump..Turn amp volume sub level down a few and check your wire from sub to amp..If all of that is good is a normal operation for pre amp warm up in sub if level is turn to max..Try unplugging amp freom sub then turn sub on stand alone(just sub outlet plugged in and no wires from base amp plugged in..If sub stops the its the amp making the problem..If it still is there then the pre amp is either dusty on inside or the outlet plug that it is plugged in doesnt have a good ground..Hope these help to solve your problem..Have a great day...
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_a3369546f8067589
Apr 02, 2009 | JBL PB12 Subwoofer
JBL PB12 Subwoofer Logo
627 people viewed this question
Top JBL Audio Players & Recorders Experts
 Grubhead
Grubhead
Steve Allison
Steve Allison
Are you a JBL Audio Player and Recorder Expert? Answer questions, earn points and help others
