Question about Holux GR 213 Sirf Star III GPS Receiver
Holux usb driver
How install recieiver no cd
I cannot install the canon iP1200 printer
hi there.
for this, to make it work, you need to put the cd driver into your cd/dvd rom first and install the driver into your machine, then wait for the installation will ask you to connect your iP1200 USB device or printer. turn the printer on first before you connect the usb driver
if the installation process didnt ask for the cd and is completed then after you install the cd driver just connect the USB of your printer while its on and that should do it
Feb 21, 2011 | Canon PIXMA iP1200 Photo Printer
Need a gps driver for gm1-86 sirf star
hi, i have just bought the gps. so i have the drivers, ive upload them to 2shared. http://www.2shared.com/file/-L-t-rNF/USB_GPS_Driver.html on the bottom off the page you are able to download it. Best regards, Jeff
Jun 13, 2010 | Holux GR 213 Sirf Star III GPS Receiver
Hai mr.igot problem when i install usb bf-810 iwas isntal driver but when i plug the port inthe PC it's show"USB devivice not recognice"can u solve my problem
Before you start installing the driver, please don’t plug your USB TO Serial Adapter into the USB port of your computer.  Follow the steps below to install Windows® 98 or Windows® ME driver 5.1 Turn on the power of computer and make sure the USB port is enabled and can working properly. 5.2 Insert the driver of USB-SERIAL ADAPTER into CD-ROM drive. Select “Install Products - USB-SERIAL ADAPTER - Install”. 5.3 Select the “Next” to install.
Before you start installing the driver, please don’t plug your USB TO Serial Adapter into the USB port of your computer.  Follow the steps below to install Windows® 2000 driver 6.1 Turn on the power of computer and make sure the USB port is enabled and can working properly. 6.2 Insert the driver of USB-SERIAL ADAPTER into CD-ROM drive. Select “Install Products - USB-SERIAL ADAPTER - Install”. 6.3 Select the “Next” to install.  Before you start installing the driver, please Don’t plug your USB TO Serial Adapter into the USB port of your computer.  Follow the steps below to install Windows® XP driver 7.1 Turn on the power of computer and make sure the USB port is enabled and can working properly. 7.2 Insert the driver of USB-SERIAL ADAPTER into CD-ROM drive. Select “Install Products - USB-SERIAL ADAPTER - Install”. 7.3 Select the “Next” to install.
.1 Driver Installation (MAC OS X) 8.1.1 Power on your computer and make sure that USB port is enabled and working properly. 8.1.2 Insert the USB adapter software driver into CD-ROM driver. 8.1.3 Click "USB-SERIAL ADAPTER\DRIVER\MAC\OS X " folder run on "PL2303_1.2.1r2.dmg", it will auto run the program and appear "PL2303 driver" folder in the desktop. 8.1.4 Click on "PL2303 driver" folder , execute "USBSerialOSX1.0.9b6.pkg" will auto install, you may change the driver directory that you want to install. 8.1.5 System will demand restart computer. 8.1.6 Plug in the USB-Serial adapter into USB port. 8.1.7 To make sure that your computer can use the device, you have check the "Apple System Profile"-"Device and Volumes". It will show the USB Device.It will show in USB port "USB-Serial Controller". 8.2 Driver Installation (MAC OS 8&9) 8.2.1 Power on your computer and make sure that USB port is enabled and working properly. 8.2.2 Insert the USB adapter software driver into CD-ROM driver. 8.2.3 Click "USB-SERIAL ADAPTER\DRIVER\MAC\OS_89" run on "PL2303_OS9_v136b1.hqx",it will auto run the program and appear "ProlificUSBSerial" file. 8.2.4 Copy "ProlificUSBSerial" file into "system folder"-"Extension". 8.2.5 Plug in the USB-Serial adapter into USB port. 8.2.6 To make sure that your computer can use the device, you have check the "Apple System Profile"-"Device and Volumes". It will show the USB Device.It will show in USB port "USB-Serial Controller". Follow the steps below to install driver of USB-Serial adapter:
hope that helps you
May 29, 2010 | BafoTech BAFO BF-810 Serial Adapter
How do I install my Phillips USB phone on my Vista PC?
You would have got a Drivers CD with your Phillips USB phone. Place the drivers CD in your CD/DVD rom drive and when the CD window opens you will get a drivers folder or else install or setup file. double click on it the driver will start installing on your PC. In each window click next tab and atlast click at the finish tab. your usb driver phone will be installed with the normal settings. Atlast, if the installation wizard asks you to start the computer please restart it so as to ensure that your USB phone works accordingly. Then whenever you like to connect your USB phone to the PC just connect the USB cable of the phone to the USB port and then in your phone if it prompts any connectivity options select the connect PC option.
Sep 12, 2009 | Computers & Internet
Can't install driver for Vista for a GR-213
I'm not sure if this will help. I have had more than a few problems with Vista not installing drivers. One solution is when the installition cd in loaded in the drive, right click on the cd icon in Computer. Choose open, search for the setup.exe file and double click on it. After and If it installs, you may have to right click on the shortcut icon to and under the compatibality tab, check the box for run in compatilibity mode for XP.
Jun 30, 2009 | Holux GR 213 Sirf Star III GPS Receiver
PROBLEM DRIVERS
Go to the Holux support website at:
http://www.holux.com/JCore/en/support/downloadCenter.jsp
NOTE: All quote marks are added by me for emphasis only.
Under the "Select products Catagory" dropdown choose "GPS Receiver/Data Logger".
Under the "Select products series" dropdown choose "Mouse Type GPS Receiver" and
click on Submit. A new page opens showing various receivers. Scroll down to the GR-213u
GPS Receiver and see the one called "GR-213u Driver Program-Vista Driver". It is of a type
of file compression called "rar" which may require a unzip program. I use a free program,
"Secure Zip for Windows". Click on the little yellow box at the far right of the "GR-213u
Driver Program-Vista Driver" line. It will be labeled "9618869.rar". Save the file.
It should be found by clicking on the Vista START and then your user name & should be in
the "Downloads" folder as "9618869.rar".
Creat a new folder for the actual unzipped file by clicking on the the Vista START Icon
& then "Documents". Click on the "Organize" tab & then on the dropdown "New Folder".
Name the new folder "Holux Vista Drvr" & then open it.
Now back at the "Downloads" folder open (Unzip) the "9618869.rar" file. Copy the new
folder "GR-213u Driver Program-Vista Driver" to the "Holux Vista Drvr" folder you created
in "Documents", so that you can later delete all those files that may have built up in
"Downloads"folder from doing lots of downloading.
Open the "GR-213u Driver Program-Vista Driver" folder & see the setup file
"PL2303_Prolific_Vista_3301.exe". The size should be about 2724 KB. Open it to start the
driver install. Now you are almost done.
After Vista has done its driver install, go to "Control Panel" & open "Device Manager".
Now plug in your Holux GR-213 & the "Device Manager" should now show a new entry
called "Ports (COM & LPT). Click on the little + sign to expand it & you should see
"Prolific USB-to-Serial Comm Port (COM#)". The # represents your Comm Port number
used by the Holux. Right click on "Prolific USB-to-Serial Comm Port (COM#)" & click on
the dropdown "Properties". Click on the tab "Port Settings"at the top of the "Properties"
window. Change the value in "Bits per second" from 9600 to 4800 & click OK.
Hopefully you have installed the Holux Utility "GPS Viewer" with a shortcut on the
desktop. Open the "GPS Viewer" & click on "Scan". A new window "GPS Scanning" opens
showing GPS found at the same Comm Port # that shows in the "Device Manager". Click on
OK & the scan window closes now showing the same Comm Port#. Click on "Open GPS" &
then on "Cold Start or Warm Start" & all the satellites found should show up. You can close
the "GPS Viewer" & all the other open windows. If all went as described any software you
used with Win XP using GPS should work OK now with Vista.
Now run your software (MS S&T or whatever) & make sure its GPS Settings show the same
Comm Port# as in "GPS Viewer" & baud rate of 4800.
Jan 17, 2009 | Holux GR 213 Sirf Star III GPS Receiver
Compatible units
Hi check if your changer connects to the amplifier with a single ribbon cable. if this is the case then the unit is not compatible with anything else.
If it has its own mains cable and a couple of RCA connectors on the rear, then anything should be fine
Jan 02, 2009 | Kenwood CD-404 5-Disc CD Changer
Driver usb edimax ew-7318USg
please I need to driver edimax usb ew 7318USg becouse Im lost instal CD thenx George
Jul 02, 2008 | Edimax WRLS ADAPT| USB EW-7317UHG RT...
Holux GR 213 Sirf Star III GPS Receiver Logo
29 people viewed this question
Top Holux GPS Experts
Are you a Holux GPS Expert? Answer questions, earn points and help others
