Question about Tribest Green Power Portable Air Conditioner (9000 BTU)
Gree 3 in 1 12000BTU Portable Air Conditioner, Electronics Randomly Switch Off & On
Gree 13-04582 Electronic Buttons randomly switching settings and modes on and off. How can I fix?
How do i recharge the gl-pac-08e4
needs to be recharged by a trained technician
Aug 04, 2014 | Soleus Powered by Gree Powered by Gree...
My gree mini split 2400 heat pump air conditioner does not turn off at the set temperture when cooling
I am not sure about your specific model. However most A/C units I have worked with have a fan switch. The switch allows you to choose to have the fan on all the time or only when the unit is cooling. Some of these switches are behind the front panel, behind the panel or out in the open it should be close to the other controls. Hope this was helpful.
May 24, 2014 | Gree 24,000 BTU 18 Seer Ductless Mini...
My gree air conditioner turns off and turns on automatically during most of the time. what kind of problem is this? how can i solve it? in the owner's manual is not written anything like this...ca
its obvious that its the timer , some one has played with the timer settings , and now it switch on and off on the time set , i have this problem too, you need to turn off the timer , i dont know how to do it , this is the nasty thing about the gree AC's
Aug 05, 2012 | Heating & Cooling
My new gree air conditioner split system has an E1 error
My greewall mounted has a e1 prblem.how van ifixor what is the problem
Feb 09, 2010 | Heating & Cooling
Camera turns on randomly and buttons stop working
hello
try to switch off you mobile and try not to keep shortcut keys on left or right.
thanks,
May 29, 2009 | Lands Phones
Pioneer SA-9500 Extremely Loud Crackling
The volume control and tone controls are dirty as well as the selection switch. This is common for older units. These controls and switches need to be cleaned with an electronic switch cleaner which should be available from an electronics store. Spray each control/switch and work them (turn repeatedly). Repeat this procedure a number of times and the accumulated dust/dirt will be cleaned and the unit should no longer have the problem.
Please note that it is possible that there is a transistor or 2 that are breaking down that can cause this as well. If the cleaning does not resolve the problem, let us know.
Dan
Dec 19, 2008 | Audio Players & Recorders
Some times AC blows hot/warm air
Not sure which model you have but i would check your indoor and outdoor temperature sensors  and also it could be your overload kickin the compressor off
Jun 11, 2007 | Sanyo STW0923H2 Thru-Wall/Window Air...
Tribest Green Power Portable Air Conditioner (9000 BTU) Logo
167 people viewed this question
Top Tribest Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
Are you a Tribest Heating and Cooling Expert? Answer questions, earn points and help others
