Tv won't come on , red light comes on tv shuts off
    Top Expert:
  • Televison & ... Master
  • 74,251 Answers
What is the brand name to your TV? Provide more details please. If you wish to get more details, surf the following link. There are over two thousand and four hundred posts. All are related to television and other domestic electronic equipment service help. You can get a solution there. Type in the brand name to your device to its search box, can be located at the top right of the display window. It will make search easy. More than Nine Lakh viewers cannot be wrong.
http://electrohelponline.blogspot.com/
Posted on May 11, 2013
  • 309 Answers
SOURCE: Toshiba 50hp66 The tv shuts off and the red light
Sounds like a system failure - one of the controller boards may have gone bad. If the unit is still under warranty, contact Toshiba for warranty service. Otherwise you will need to contact one of the authorized service centers or your local TV repair guy to arrange for repair.
Posted on Nov 20, 2009
SOURCE: TV won't turn on.
I say press the input button until you see a picture!.
Posted on Jul 06, 2011
  • 8457 Answers
SOURCE: My TV shut off yesterday
U check the power sourced like the other equipments that plug into that a/c power outlet work?Yes,than tries tv unplug,replug it back like about an hour later by letting the tv to do a resetting itself back to the factory setting.The tv now it should be working again.If the tv still have the same result?Yes,than the tv have a power supply board it is dead.That the board where the power a/c cord plug into it.U have some basic mechanical skills like take things aparts and putting it back togther again?Yes,tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish power suppy board for the replacement.
Posted on Aug 18, 2011
protvrepair
  • 153 Answers
SOURCE: Heard a pop , bulb blew out , replaced bulb , it
3 blinks indicates lamp door is not on or has not been reinstalled properly. This also could mean the lamp door switch has failed itself. Try removing the lamp door and putting back on, if that doesnt correct the problem then I recommend having the switch replaced.
Posted on Oct 29, 2011
Slinteriors
  • 8617 Answers
SOURCE: red light flashing on my tv and won't come on
replace the power supply board. You should be able to get the replacement power board from www.tvcircuitboards.com send them a email customerservice@tvcircuitboards.com if you dont see it listed as they only list a few of the boards they carry
Posted on Mar 03, 2012
Testimonial: "Hello and thank you, I will give it a shot. When I first got the TV it would power on enough to see the POLAROID signature on the screen but would then fade away. I inspected the circuit boards for bad caps and found 2 on the Power Supply board that were bulging. I replaced those caps but in the process I accidentally arched against the power supply itself which caused a spark (with a screw driver). The more I read on working with these circuit boards I have noticed the circuit board are to be handled in certain ways. I read that you can't touch the board but only on the sides and to wear some sort of anti-static wrist band??"
Fujitsu plasmavision won't turn on
How many times do the red light blinks at a time? Count it. It is fault indication. After counting it, click here for details.
Dec 24, 2012 | Televison & Video
My Sony wega tv won't turn on goes into standby red light blinks 10 times then shuts off?
Look at the owner manual as the 10 blinks is a error code or Google the model number to locate that information--Sony error codes are general and often misleading.
I would if looking at the set inspect the lamp first.
Aug 28, 2012 | Sony Grand WEGA KDF-42WE655 42" Rear...
TV won't turn on. red light blinks twice and nothing happens
This is an error code of some fault inside. Kindly call in a qualified service technician.
Jul 25, 2012 | Magnavox 32MF301B LCD TV
TV won't turn on
It sounds that, the memory IC to your TV has damaged. This IC can be located very near to main system control IC. A very small one, with 8 solder terminals. Even though it is very small, function of it while the TV works is great. The work is a semi-skilled one, and you must have some knowledge in electronics to proceed.
Jul 09, 2012 | Akai Televison & Video
** TV won't turn on.** No picture or sound. Please Help !
If the red light won't come on it is not getting power.First,try plugging it in to a different outlet,or unplug one of the gadgets you know is working and plug the tv in there.You are simply switching.If you know that there is power coming from the outlet and it still won't come on then you'll have to check the cord;don't go much farther than that without expert help.
Apr 04, 2012 | Televison & Video
RCA LCD TV red light flasiing tv won't come on
Bad main logic board. Probably won't be able to find it. You can try Encompas Parts. Good Luck to you.
Nov 20, 2011 | RCA L32WD22 32 in. LCD HDTV
Philips 42 in. Plasma shut down
did u cheak the input cables does it do it on dvd input as well as others ?
Feb 01, 2008 | Philips 42PF7320A 42 in. Plasma HDTV
Televison & Video Logo
26 people viewed this question
Top Televison & Video Experts
Electro Med Services...
