Question about Neff B1691 Single circotherm super Stainless Steel Electric Oven
Neff oven SHOWS FAULT -5-
3 Suggested Answers
SOURCE: neff oven U1661 shows fault code -5-
We have a similar Neff Oven - it is a child proof lock that you have activated. To deactivate - turn the left hand dial that selects the mode of cooking - three times to the left and back (turn it from 12 oclock to 11 oclock and back) in quick succession.
Posted on Nov 01, 2008
fionamcaslan
Have had then problem for 8 months and took your advice and it worked .Thanks ! I now have 2 ovens to use again !
Posted on Apr 25, 2016
NEFF OVEN B1593. I have an oven neff b1593 and it's been locked.i don't how to unlock it.
Unplug the Oven from power for 5 minutes and see if it resets and the door unlocks.
Oct 24, 2016 | Neff Ovens
I have a neff double oven - When i try to use the top cooker the functions light up when selected then go off. The display shows -5- & the temp does not show on the screen when i turn functions on.
although it looks like a five it means safety activated or to be more precise child lock to switch off turn oven selector switch quickly 3 times off and back on between off and light only this will turn child lock off.
May 25, 2016 | Neff Ovens
How do the controls on a Neff Oven B1920W0GB/02 work?
NEFF B1320A2GB Manual Page 5
just click the arrows at either side of the pic to scroll from page to page,the link starts at page 5.
Sep 05, 2014 | Neff Ovens
Neff u17 built-under causes fuse to blow on all the kitchen electrics a few seconds or minutes after the bottom oven is turned on. No problem turning top oven on. Have changed element in bottom oven with...
There could be a fault in the lower oven , or it could be overloading the circuit. add the watts of the two elements and divide by line voltage, this will give amps , now check the fuse rating amps , it must be higher than the oven. If that checks out ok the fault is in the oven.
Jan 03, 2018 | Neff U1721 Double circotherm Electric Oven
My neff oven error -5-. How do i turn this off?
I also had an error 5 on my Neff B1691 cooker. This indicates that a child lock has been set. To unlock you just push and hold the central control button in for about 7-8 seconds. Do the same again to set the lock again...
Mar 21, 2010 | Neff B1421 Electric Single Oven
Neff U1721 repeatedly trips RCD. Have replaced lower element 4 times in last 18 months am I likely to have an underlying earth fault, or are "cheap" elements more prone to failure
Sounds more like the power supplying the oven is at fault. Need to make sure that all power is correct from stove to box. Very unusual for that many elements to be going bad.
Feb 04, 2010 | Neff U1721 Double circotherm Electric Oven
The fan system does not heat up the oven
Hi.
If the fan is working o/k, then you need to fit a new oven element. Very common fault on Neff oven's.
Please rate my solutrion.
Thanks.
Jul 19, 2009 | Neff Ovens
Neff faulty Fan
Hi.
I would not think that both fan and element are faulty, although it is possible.
if it has a timer make sure that it is on manual and not on auto, as this would stop the oven working.
Other possible fault is faulty main oven selector switch.
Hope this helps. Please do not for get feedback .
Thanks.
Nov 23, 2008 | Neff U1661 Double circotherm super...
Neff oven U1661 shows fault code -5-
Sep 17, 2008 | Neff U1661 Double circotherm super...
Neff B1691 Single circotherm super Stainless Steel Electric Oven Logo
24 people viewed this question
Top Neff Ovens Experts
ashburton
Hjalmer Lamminen
Hjalmer Lamminen
Samyfam
Samyfam
Are you a Neff Oven Expert? Answer questions, earn points and help others
