Question about Canon PIXMA iP4200 InkJet Photo Printer
Won't Go I haven't used my printer for over 12mths & I just had my computer fixed & now my computer won't recognise it I have looked in all my software disc's & i do not have a disc. what can i do to give my printer life again
    Sergeant:
  • 390 Answers
Your computer being fixed may have new operating system files running that are not compatable with your lexmark now. You need updated drivers for your printer. Go to lexmark on the internet (google it) and choose location or drivers list/link. Also, get them to send you a new disk. You will need some proof that you already have the printer but no disk, look on the back of your printer for the serial number. You will need this when requesting help. Once you have your new dik and drivers, you wil be right again.
Posted on Aug 12, 2007
SOURCE:
I have a Dewalt work light. DC528. I haven’t used it for a while and now that I want to, it won’t work. I’ve charged the battery and bought and replaced new bulbs. Any ideas?
If the battery is really being fully charged the connections are probably dirty but if the battery has been left discharged for a while it could now be faulty.
A faulty battery can often be recognised by the unusually short time charging takes and sometimes an extraordinarily lengthy time.
A voltmeter should be used to check the battery...
Oct 11, 2018 | Dewalt Drills
My MP4 won't charge or turn on and the USB port isworking fine, my computer won't even recognise that the mp4 is connected
You can turn off the Mp4 for a while and re-install the system ,and then you can change if the port is fit the computer ,you can also used a transfer interface to connected the computer .
Dec 11, 2012 | Philips Gogear Vibe 8gb Mp3 Mp4 Video...
My computer won't recognise my USB cable (code 43 error)
Its maybe the printer is not compatible with your computer, will to try several steps to determine a solution,
1 try another USB to see if it recognizes it,
2 download and install the driver from the printer manufacturer
3 try another USB device into the same USB port to see if it recognizes it if it does then the USB on your computer works as it should,
if it does then the fault is either software or the printer compatibility.
4 follow step 2 if the problem persist then the answer is your printer is not compatible and will need to order one that works for your system.
Kronoguy
Aug 18, 2012 | Computers & Internet
Epson workforce 520 won't recognise ink cartidges
When replacing ink on the Epson Workforce 520, Ensure the cartridges have the correct/same number of gold contacts. Ive seen them with 7 and 9 gold square contacts and they were otherwise identical, and the ones with 9 contacts threw an "cartridge not recognized" error on the printer's dispay.
Feb 24, 2012 | Epson Workforce 520 Printer
Why won't my printer scan a document to my laptop?
Make sure the Lexmark OCR scan software is installed on your laptop. The software is available only on the installation disc that came with your printer. If you still haven't installed the software on your computer and you don't have the installation disc, please contact Lexmark Technical Support Center to request for one.
If you were able to scan documents before using your Lexmark printer, it could be just a slight communication issue. A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer (if USB connected)> reboot your pc > unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer (if USB connected). Then try to print again once the computer fully recognizes the USB connection or when the WiFi light on the printer turns solid green (if WiFi connected.).
Dec 01, 2011 | Lexmark X5650 All-in-One InkJet Printer
Installed new 28 and 29 cartridges in lexmark x2550 and it won't recognise the cartridge and won't print at all, very frustrating please help urgently
It could be that your cartridges need some cleaning. On your computer, launch the Lexmark Solution Center. Click Start menu > Programs or All Programs >Lexmark 2500 Series > Lexmark Solution Center. From the Maintenance tab, select Clean to fix horizontal streaks. Your printer will then print a page forcing ink through the cartridge nozzles and clean them. Try to print again.
Jun 29, 2011 | Lexmark X2550 All-In-One Printer
Hp color laserjet cm1312 won't boot up. It tries to, there is a menu bar that tries to progress on the screen, but then stops. Help!!
Hi
Have you tried reinstalling the firmware for the printer. If it is already loaded on your computer then you should be able to reinstall the firmware in order to get it booted.
hope this helps (ie if you haven't gotten it fixed already)
May 16, 2011 | HP Laserjet CM 1312NFI Color Printer
My canon mp220 printer wont work after putting in
Try to press and hold "resume" button for 5 seconds.If this not help the color cartridge may defective.
Oct 09, 2009 | Canon Office Equipment & Supplies
Canon PIXMA iP4200 InkJet Photo Printer Logo
Clive
Clive
old marine
old marine
Ekse
