Question about Refrigerators
I have a Whirlpool GX5FHTXTS Stainless Steel Bottom Freezer French Door and the fridge has stopped cooling. The freezer is fine. Its running as usual. I've tried unplugging it but still nothing. Any ideas?
  • 2 more comments
  • wweatheringt
    wweatheringt May 15, 2013
    Yes. It is freezing the coils. When I defrost the coils it works again but within three days its frozen again!
  • joshdonhardt May 15, 2013
    Does it defrost with its heaters or do you defrost it manually?
  • wweatheringt
    manually
  • wweatheringt
    I assume since it isnt defrosting....
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 31 Answers
Is the fan in the freezer running?
Posted on May 14, 2013
  • 66 Answers
SOURCE: Handle to freezer on french door fridge
if the butter fly clip is brroken . you need to change the door. other than that you can replace the handle only. with the butter fly clip. parts cast only 100.00
Posted on Feb 07, 2008
burzerko
  • 254 Answers
SOURCE: Whirlpool Gold Conquest side by
sounds as if you have an ice buildup restricting the fan from moving airflow to the freezer. Inside the freezer take apart the lower shelf and see if this area is full of ice, if so clean it and defrost it.
Posted on Jun 12, 2008
  • 4 Answers
SOURCE: We have Maytag 25 cubic feet stainless steel
There is a defrost problem. Ice builds up between the ref and frz sections and wont allow coolo air through. You can also check to see if the damper is stuck closed
Posted on Jun 13, 2009
jeffbvegas1
  • 520 Answers
SOURCE: LG French door fridge freezer not freezing
hopefully you looked out back ...rear lower panel and checked little white condenser fan running...it really needs too to keep temp stable across the condenser coils and no overheat condition to the compressor.hopefully you wont need the $300 circuit board like I just bought
Posted on Jun 26, 2009
MNTECH
  • 1543 Answers
SOURCE: GE GFSL6KEXLS Stainless Steel (2585
look for a small hole on one side of the handle. There should be a set screw there you can tighten. (the handle attaches to a ball shaped peg under the handle, and does not attach from the inside of the door)
Posted on Nov 28, 2010
Fridge is not cooling, fridge is working fine
Hello Dan, Is Your Fan in your freezer compartment on ? sometimes the evaporator coils will freeze up not letting the air cool the refrigerator
Dec 25, 2013 | General Electric GFSS6KKXSS Stainless...
Water is being found under the frige and a iced up puddel in the inside of the frezzer
There are two causes for this problem which are
1. That the defrost element is no longer working; in which case it will need to be replaced; or
2. That the sump hole underneath the evaporator plate in the back of the freezer has bocome blocked and therefore when appliance goes into defrost mode, any ice melted off the evap plate has nowhere to run but into the bottom of the freezer.
Jan 27, 2011 | Whirlpool GX5FHTXTS Stainless Steel Bottom...
Freezer works, fridge doesnt!
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 26, 2011 | Maytag MFI2568AES Stainless Steel Bottom...
Whirlpool stainless french door refrig...need to take handle off bottom freezer door so I can move it out of house. Is this possible without taking off the whole door?
it is much better to remove the complete door instead of handle . there are 4 screws inside that will release the complete door . if your want to do the handle use a credit card and insert it between the handle and door to release . but if stainless it some times leaves marks on door . i always remove the doors as one door is ever and i mean very costly.. mm hope this helps mm feed back pls ..
Nov 08, 2010 | Whirlpool GX5FHTXTS Stainless Steel Bottom...
My refrigerator has stopped cooling - though my freezer is still cooling just fine. Please help!! Model # is Maytag MFD2561KES
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
heatman101
Nov 01, 2010 | Maytag MFD2561KES Stainless Steel Bottom...
I have an ge french door bottom freezer model gfss6kkxass. it has started collecting water under the vegtable drawers and leaking down front of freezer
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
heatman101
ll
Sep 26, 2010 | General Electric GFSS6KKXSS Stainless...
My freezer is freezing with ice just started when clean it it start right back
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
heatman101
Aug 28, 2010 | Whirlpool GI5FSAXVY Stainless Steel ...
Refrigirator does not cool and bottom freezer works fine.
<span style="FONT-FAMILY: 'Trebuchet MS'; FONT-SIZE: 10pt; mso-ansi-language: EN" lang="EN">Hi,</span><br /> <span style="FONT-FAMILY: 'Trebuchet MS'; FONT-SIZE: 10pt; mso-ansi-language: EN" lang="EN"><br />Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling<br /><br />Refrigerator not Cooling or Fridge not Cooling<br /><a href="http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not" target="_blank">http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not</a><br /><br />How to Defrost Refrigerator Defrost Timer Problem <br /><a href="http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer" target="_blank">http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer</a><br /><br /><br />Water Running in efrigerator from Freezer<br /><a href="http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from" target="_blank">http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from</a><br /><br />heatman101</span><br />
Aug 26, 2010 | GE Profile PGSS5PJXSS Stainless Steel...
Ice maker not functioning
ck for frozen waater inlet tube ( verry common .. de ice with hot water / may have a water valve leaking through . if so replace it .. ( the valve ) mm
Aug 09, 2010 | Whirlpool GX5FHTXTS Stainless Steel Bottom...
We have Maytag 25 cubic feet stainless steel double door fridge with pull our freezer on the bottom. The fridge as stop being cooled but the freezer works fine?
Jun 13, 2009 | Maytag MFD2560HES Bottom Freezer French...
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
