Question about New Home HF-2022
Sewing machine jammed while sewing
I have a New Home HF-2022 sewing machine that hasn't been used for years, or even a very much in about the ten years my mother had it. She used it for a couple years, then put it away when she upgraded. It has been taken care of (oiled and dusted) periodically. It recently jammed while I was sewing. I could hear the motor still trying to work. I cleaned out the hook area, dusted all around; there was no mess of thread or anything visibly obstructing performance. My mother thinks it's a timing belt issue. Any thoughts? I also would like to fix it myself, so I am researching for such a repair.
  • Lisa Schmidt May 11, 2013
    :) I have an instruction manual. It says very little about my problem, other than take it to a repair shop. I'm stuburn and think I might be able to do it myself.
    Top Expert:
  • New Home Master
  • 49,948 Answers
Go on line, google for- new home hf-2022 sewing machine and down load pdf manual for machine
Posted on May 11, 2013
  • Bill Boyd May 11, 2013
    Go to google ,type in-repair manual for new home HF-2022 sewing machine. Find you listed machine. Just follow-to order instructions- pay particular attention to the
    part in shopping cart that states instruction manual or service manual and Any questions before you place your order
    ring the number provided E-mail -contact us, or, ring the number(929) 704-6926 .
    You want the service manual. Site www.sewusa.com\sewing
    machines is the one you want
4 Suggested Answers
  • 323 Answers
SOURCE: Threading my sewing machine
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} all machines thread the same. TTN tension, take up, needle.
Beginning with the spool, guide the thread through the thread guides to the tension assembly. Pull the thread through the tension assembly and test it to make sure the tension is working correctly.
(To do this test, adjust your tension setting to normal or medium or 5 or something in the middle. Raise the presser foot and pull the thread through the tension. It should pull easily!! Lower the presser foot and pull the thread. It should pull noticeably harder.) If it passes this test, continue up through the take up lever,then down through the thread guides to the needle. Make sure your needle is fully inserted and turned the correct way.( If you load your bobbin case from the left side,the needle rule is normally FLAT to the RIGHT is RIGHT. There are some exceptions. If you have a newer style drop in bobbin or your bobbin case loads in the front then the rule is FLAT to the BACK.
Sewman7
Posted on Aug 27, 2008
SOURCE: New Home sewing maching, using
1.put new spool of thread on
2.watch the thread on the take up lever,make sure it doesn't come off
3.check the tension disk for loose threads, if there are threads pull out
4.check needle for being bent or blunt --if so replace
Posted on Jul 29, 2010
SOURCE: new home sewing machine model MS3015 parts
try ebay for the parts you need
make sure the needle is the right one for the fabric being sewed
make sure the top thread has not come off the thread take up lever
try a different bobbin---make sure it's turned the right way in the
bobbin case--and if it's a front or side loading bobbin,,make sure
the bobbin case is inserted correctly
if none of my suggestion help then I suggest having the machine
checked for a timing problem.
Posted on Dec 05, 2012
Stiches form loops below the work
it's possible that the machine needs to be checked at a sewing machine shop for the timing
May 12, 2012 | New Home HF-2022
Need manual and what type of bobbins to use
what is the name & model number of machine?
Feb 10, 2012 | New Home HF-2022
Janome Decor Excel 5018 Sewing machine Feeder dogs won't come up when trying to sew Help
I just had the same problem tonight for the first time. Does anyone have a solution? I need to finish making Halloween costumes!
Aug 28, 2011 | New Home HF-2022
Can you tell me how to replace a needle on the New Home 4018? Something keeps getting it out of alignment.
the needle goes in with the flat side toward the back of the machine
make sure to use the right needle for the fabric & thread
make sure the needles are inserted all the way in the needle clamp
Nov 19, 2010 | New Home HF-2022
Hi. I need a new bobbin case for a New Home Model
Standard type bobbin case that can be bought on ebay or any sewing machine shop
Jun 16, 2010 | New Home HF-2022
New Home HF-2022 Logo
94 people viewed this question
Top New Home Sewing Machines Experts
Tally Girl
Tally Girl
Nava Hirshenson
Nava Hirshenson
Level 1 Expert
Are you a New Home Sewing Machine Expert? Answer questions, earn points and help others
