Question about LG LHB335 Theater System
How to change to region code 0 lg lhb335 - LG LHB335 Theater System
5 Suggested Answers
joeguest2
  • 2080 Answers
SOURCE: tivo code for lg lhb335 volume control
Here is the link to the TIVO question and answer page about programming your remote:
http://support.tivo.com/app/answers/detail/a_id/294
1. If you just finished programming the TV power, volume and mute, press SELECT in response to the prompts until you reach the Remote Control Setup screen. (Or from TiVo Central select Messages & Settings > Settings > Remote, CableCARD, & Devices > Remote Control.)
2. Highlight Part 2:A/V volume, and mute and press SELECT. Use the UP ARROW and DOWN ARROW buttons and the CHAN DOWN and CHAN UP buttons on the TiVo remote to highlight your A/V receiver brand and then press SELECT. The A/V Remote Codes screen appears.
3. Follow the instructions on the A/V Remote Codes screen to enter a code into your remote control. If the first code does not work, repeat the instructions to enter the second code, and so forth, until you find a code that works.
4. Use the TV remote control (not the TiVo remote) to turn down or mute the sound on your TV; once you choose an A/V receiver code, the TiVo remote will control the power on your TV, but not the TV volume or mute functions.
If you have any questions or require further assistance, please comment back on this page and I will endeavour to help you.
If this was at all helpful please click on the 4 Thums Up rating icon above.
Thank you very much.
Joe.
Posted on Feb 15, 2011
muntejaya
  • 10421 Answers
SOURCE: Region Code for LG HT503
Hi, kindly get the code here : www.regionfreedvd.net/ www.dvdripper.org/dvd-region-codes-vs-ntscpal/ www.regionfreedvd.net/players.html
www.dvdreviewer.co.uk/Forums/...region_code/page1
Best Regards, Jay__45dchb
Posted on Feb 27, 2011
muntejaya
  • 10421 Answers
SOURCE: LG HT304SU Theatre system. DVD player will not
Hi there, please get the code here : www.regionfreedvd.net/ www.dvdripper.org/dvd-region-codes-vs-ntscpal/ www.regionfreedvd.net/players.html
Best Regards, Jay_6yfhr5
SOURCE: Looking for the hack to get the LG HX995TZ (home
Hello Maxraez,
1 - On the default (LG logo) screen, with no DVD playing (it does not matter if you have DVDs in the trays) Type "Pause" then "1472". A Prom Setting screen should come up.
2 - Press up on remote till you reach 05 Xe where X is a number (region code) eg. 1e
3 - Type "0" then hold down "5" for a few seconds then release. It should then read as 0e. If it does then press "enter" on the remote. If it doesn't try pressing the number "5" a little bit longer till it does. Then press "enter".
4 - Press the "pause" button again once the above is done. That will exit you out of the Prom screen and back to the default screen.
5 - Power off then power back up the machine. It is now region free.
A word of advice... Make sure you write down all your numbers & letters in the Prom Screen before you change anything. That way you can change it back to what it was in case you changed something else by accident. However, I would caution you NOT to change any other thing.
Posted on Apr 27, 2011
Lg dp132 check region code
1.Switch on the DVD player without any Disc inside
2.The screen should display 'no disc'
3.Eject to open the DVD tray
4.While the tray is open, press the 'STOP' button then hold the 'ENTER' button for 5 seconds
5. A new screen will appear (Regional Management Test Code) which will allow you to change the region code using the up and down arrow keys on the remote control.
6. Change the code to '0' and press the PAUSE key to exit
Dec 30, 2013 | LG Televison & Video
Tip
LG DV582H region free code
Here are the steps to make your LG DV582H DVD region free.
1) Power on (with no disc)
2) Wait for msg "No disc"
3) Open tray
4) Push three times number 0 (i.e.: 0 0 0)
5) A blue screen appears with the code region factory set, and the option to set the new region code
6) Press 0 (zero)
7) Press Pause (A msg say that you have to press de new code and them press pause to confirm....so, is to easy)
8) Close tray
9) Turn off
Works 100% for my LG DV582H region 4, now its region free!!
Good Luck
on Jan 03, 2011 | Audio Players & Recorders
Region free code for LG BH7520
With your set on and without disc in the tray:
1. Press PLAY from your remote control
2. Press the following button sequence: 1590 2379 390
3. Press PLAY again
This will release the region verification in your home theater (region free). However, some DVDs (multiregion in particular) will not play, since they require region detection from the player unit.
Jun 10, 2012 | LG Televison & Video
How can I unlock the regional code of my LG HT355SD?
Switch on the unit, open the tray but don't put any disk on it. press 0 on the remote, regional code info appears on the tv screen, it gives you the current code. Scroll down to change regional code- selct 0 for all regions. hit pause to exit. switch off the unit and wait for a moment. then test.
Oct 11, 2010 | LG Audio Players & Recorders
Changing region code to all on a LG DV550 DVD player?
icon_minipost.gifRegion code hack posted by hackaroto, December 27 2010:
1. Switch off the DVD player in to Stand By mode
2. Open the DVD tray using the remote control
3. Press "pause" in the remote
4. Enter 0, 0, 0, 0 (zero 4 times)
5. The display should indicate the regional code set in the DVD and prompts for the new regional code.
6. Enter the new regional code
7. Press Pause to exit the setup
8. Switch off the DVD using the remote and wait for a while before switching it on again.
works for other LG DV55X players
Aug 03, 2010 | LG Televison & Video
I have a LG HT554PH home cinema and would like a region code to enable it to play region 1 dvds. i have just paid £5 from a website and it is no use my dvd player wasnt on the list. there is a reion...
Hi
To make the player as region free, switch on the LG HT554 Player. Push the eject button to open the tray. Now, press “0” on your player 4 times or until the region code settings shows up on your player. It will show the current region code and will then ask for new region code. Press “0” on your remote to set it as a new region code(0=All Regions). Press Enter key on remote, now restart your player and check the player by playing the DVD’s. It should be region free now.
Please post back for any further assistance. If you are satisfied please do accept the solution.
Daniel
Jul 23, 2010 | Audio Players & Recorders
Lg dvdcombo region codes
I have just hacked an LG 32LG4000 combo tv/dvd. To open up the dvd to multi region, turn on the tv & press the menu/set up button. Next, navigate to the lock symbol but do not open the sub menu. Press 0 seven times. Exit out of the menu, and your 'on board' dvd player will play dvd's from any region!
Nov 28, 2008 | LG 32LG40 32 in. LCD HDTV
UNLOCK CODES
1. Power ON
2. Open disc tray
3. Select- 0-0-0 on remote
4. Select 0 for all regions
5. Press PAUSE
6. Power OFF
7. Wait (about 30 secs)
8. Power ON
9. Watch DVD
May 13, 2008 | LG Televison & Video
I own an LG (LH-W750TA) DVD player that is set for DVD region 4. I am after an unlocking code to allow me to view DVDs from region 1 NTSC.
Open tray
Press PAUSE
Enter 0 0 0 0 0
Region change screen should appear.
Enter region 1 - 6 or 0 for multi-region.
Press PAUSE
Apr 23, 2008 | Televison & Video
LG LHB335 Theater System Logo
43 people viewed this question
Top LG Audio Players & Recorders Experts
jairo sanchez
Are you a LG Audio Player and Recorder Expert? Answer questions, earn points and help others
