Question about Euro-Pro 6 Slice Toaster Oven Black W/ 12 Pizza Bump - To1612
My wire is overheating after a few minutes - Euro-Pro 6 Slice Toaster Oven Black W/ 12 Pizza Bump - To1612
    New Friend:
It means that you need to replace it with another one with thicker one from inside the toaster, are you using an electricity connect if yes get a good one or do the first option
Posted on May 11, 2013
Is preheating this toaster oven necessary? How do you preheat?
Preheat is helpful when you're not cooking for more than a few minutes. If you're going to cook for 20 minutes or more, then most likely you don't need to pre-heat.
To pre-heat, simply turn your toaster-oven on 10 minutes before you put the food in.
Feb 27, 2016 | Toaster Ovens
The door spring came off of hamilton beach 31100
The door of the Hamilton Beach Model 03008 or similar toaster oven does not stay closed when the door return spring or the hook it connects to breaks. The repair is very simple and takes just a few minutes!
The door spring is about 1 inch long and connects to a small clip on the inside of the left side panel of the unit. To see the small clip and the door spring, you simply remove the left side panel of the toaster oven which is done by removing just one screw.
The mounting clip on the side panel for the door return spring is located about half way up the side panel near its front edge.
The other end of the spring (its bottom end) connects to a metal hook. If the spring is not connected on its bottom end then the wire hook is broken. This is a simple repair that only requires a few inches of metal wire.
The other end of the metal hook (its bottom end) is connected to the bottom of the door hinge where it inserts into a small hole in the left side mounting hinge of the door.
When the steel hook breaks on either end then the spring cannot function, so the door does not stay closed.
To fix this problem, you simply get a piece of steel wire that is about 1/16 inch thick and a few inches long.
Bend the wire to make a hook at one end that the spring will connect to.
Then insert the other end of the wire into the small hole on the left side mounting hinge of the door. Then bend the wire on the inside of the hole to make a U or hook so the wire stays mounted in the hole of the door hinge.
Then adjust the position of the bend on the other end of the metal wire so the spring will have good tension when it is attached to the hook and to the clip on the side panel.
To do this you make the U shaped bend on this end of the wire to be about 1/2 inch from the end of the open end of the spring when the top end of the spring is attached to the mounting clip on the side panel.
To attach the spring to the wire hook, first remove the spring from the mounting clip. Then hook the spring onto the hook (bend) you made at the top end of the wire, then just stretch the spring to connect it to the mounting clip. The door will now stay closed.
Nov 10, 2013 | Hamilton Beach 31197 120 Watts Toaster...
Bravetti euro pro microwave convection oven stops working
follow this steps and fix it. God bless you
  1. Main control boardIf your microwave runs for a few seconds and stops, the first thing to check is the main control board to ensure that a shortage has not occurred. If the part is defective then it will need to be replaced to prevent continual shut offs. If this is not the issue, the next step would be to check for a faulty touchpad.
  2. Touchpad/Control panelIf the control board is not the issue and your microwave continues to shut off after running for only a few seconds, the next thing to check is your touchpad, which is also known as a control panel. Although uncommon for this issue, symptoms are usually that the display and some buttons are working properly; however, when selected some buttons are not functioning. If this is the case the touchpad will need to be replaced.
Read more: http://www.appliancepartspros.com/repair-help/microwave-repair-help.html#7#ixzz2hPnOVle4
Oct 11, 2013 | Toaster Ovens
How do you set the delonghi convection toaster oven to cook chicken nuggetts?
Try this:
Thermostat knob - Toast/ broil
Time - 18 minutes
Wire Rack Position - Upper
Turn after 10 minutes.
For other recipe programs, you can download owner's manual at http://www.delonghiusa.com
Regards.
Jun 16, 2011 | DeLonghi EO1251 Toaster Oven with...
What should one do if the toast in oven catches on fire? please respond.
Switch the over off at the wall and unplug it first. Remove the burning toast with steel tongs or something similar that wont burn you and place toast in sink in water to extinguish flames if there are any
Your oven should be okay to use again under the following circumstances
  1. The toast was simply left in there too long, hence it caught on fire
  2. There was only smoke or a very small flame and the interior of the oven was not blackened
If in doubt or the flames were of reasonable size, or the interior of your oven has been blackened with smoke, do not reuse the oven without getting it checked over by a licensed electrician. There is a risk that you may have overheated and melted some of the wiring.
May 10, 2011 | Black & Decker Toaster Ovens
I need an owner's manual for toastmaster convection oven/broiler model #7091 A do you know where i can get one
This was very difficult to find, but I found it just for you! Please make sure you rate my answer 4 thumbs up! Thanks so much for understanding, it would be a huge help to me. I would be forever grateful if you could do this for me. To view the manual you will need adobe reader, which you can get for free from http://get.adobe.com/reader/ You probably already have it though, please try opening the file first and find out. Here is the manual / guide please give it a few minutes the file is quite large:
http://dl.owneriq.net/4/45f59970-8886-4599-8625-bcdf04ca1ab3.pdf
Oct 15, 2010 | Toaster Ovens
Can you cook a stuffed turkey in the roater oven
Yes, similar timewise to a regular oven. But it depends on the size of the turkey, if stuffed you definitely want to check the fit- you need about an inch all around including the top to get good cooking. Any place it touches the sides it will tend to overcook.
The Rival manual suggested 375 for pre basted or 350 for fresh 9-14 minutes per pound. In my experience this is too hot. I use 325 for 4 to 4 3/4 hours at 325 for an 18 pound unstuffed turkey; a 21 pounder takes about 35-45 minutes more. The USDA now uses 165 as the end point temp (down quite a bit from a few years ago), but if you stuff, that has to be in the middle of the stuffing, and the turkey will overcook somewhat while it gets there. It adds about 1-2 minutes per turkey pound if stuffed.
All experts agree that turkeys cook better and safer if unstuffed, so considering that you will have to make an extra pan of stuffing to have it for everyone, you would be well advised to cook your turkey unstuffed and use some of the drippings to flavor the pan of stuffing while the turkey rests.
Nov 21, 2009 | Hamilton Beach Toaster Oven with...
Does not heat up.
Mine worked for awhile, then started overheating. I (former appliance repairman) found that the fan needed oiled. While I was checking it with the outside covers removed, I saw that two of the connections on the top heating element were arcing and burning! This accounted for a strange smell.
Jul 06, 2009 | Toastmaster TUV48 UltraVection 1400 Watts...
Timer switch on Dualit 89100 1500 Watts Toaster Oven does not work so oven cannot be used. Any advice?If you turn timer all the way to 120 minutes and hold it the light in the oven will go on but no heat.
The timer switch is likely bad. Small convection ovens are notorious for this problem and switches may be difficult to find. Try smallapplianceparts.com or search "small appliance parts" for a few places that sell parts. You will need the make and model # of your oven.
Feb 22, 2009 | Dualit 89100 1500 Watts Toaster Oven with...
Euro-Pro 6 Slice Toaster Oven Black W/ 12 Pizza Bump - To1612 Logo
57 people viewed this question
Top Euro-Pro Toaster Ovens Experts
Dave
Dave
eyecam
Are you an Euro-Pro Toaster Oven Expert? Answer questions, earn points and help others
