Question about Vehicle Parts & Accessories
Car won't start. Alarm light on.
2001 Mazda Miata factory alarm system shutdown car. How to restart car and reset alarm.
  • Anonymous Mar 22, 2014
    Car wont start
    Top Expert:
  • 42,784 Answers
The alarm system is telling you that the CPU has found sensor/s outside set parameters during the checking process. Have the fault codes read before wasting time and money guessing what has failed. Replace with genuine items only as aftermarket units are not always compatible with the settings in the CPU. It has shut down to protect the engine from damage.
Posted on May 11, 2013
SOURCE: Car no Longer resposnding to remote starter or alarm
Did you try checking the battery in the remote?
Posted on Apr 20, 2009
  • 33 Answers
SOURCE: Viper alarm, lights dont flash
Sounds to me like the parking light output wire. They usually have a seperate fuse or the connection is bad. The connection on your vehicle should be behind the pass side kick panel and look for a wire to the white/purple wire and check that with a meter or light to see if it's kick out power. There is a possibility they used the negative trigger through a resister and that would be located behind the headlight switch. That will at least let you know and trace down the problem. Here is a link with that parking light info for yours. Hope this helps and let me know if you have more questions.
http://64.85.6.121/diagrams/printpage.asp?ModelID=17258&MakeID=16
Posted on Mar 02, 2009
jpk528
  • 95 Answers
SOURCE: Car alarm won't reset after disconnecting car battery
you should try to hit the unlock button on the remotes and that should disarm it. Try disarming that, that way and if that doesnt work we will go from there
Posted on Feb 22, 2009
  • 12 Answers
SOURCE: problem with my viper alarm system on my 98' odyssey
first, you need to manuslly disarm the alarm. open driver's door, put key in ignition, turn on ignition, an then within 10 seconds push the valet/program button for a couple of seconds. (it is the little spring loaded push button that they installed with your system. probably in the kick panel or under dash
Posted on Jan 15, 2009
MECP Guy
  • 344 Answers
SOURCE: car alarm keeps going off
ground the pink with white wire behind the drivers kick panel
Posted on Mar 06, 2010
2001 Mercury Sable Intermittent Fuel Pump?
You are right that it could be either component, or something else electrical. The security system will kill the fuel system if the wrong key is used or the system is acting up.
A mechanic would check base fuel pressure with a gauge and also see if the pump is getting power from the relay when it fails to start.
Jun 07, 2013 | 2001 Mercury Sable
I have a 2001 325i bmw won't start because of alarm system how can I reset it? I got the new key today
The key might have to be re-programmed to the car. If not could be an engine problem
Mar 20, 2013 | Cars & Trucks
Mazda miata 2008 -beeping/alarm when car is put into gear
HAS TO BE A WARNING BLEEP YOUR HAND BRAKE SLIGHTLY ON
Oct 11, 2012 | 2008 Mazda Mx 5 Miata
Car starts and runs but alarm won't shut off
Most models with factory alarm system can be reset by locking and unlocking the driver's door with the key.
Jul 13, 2012 | Cars & Trucks
I have an 88 mazda rx7, the factory alarm system has disabled the fuel system, how do i reset it and permanently disable alarm system for good?
the factory alarm doesn't stop the fuel system it only cuts the starter your problem lies somewhere else
Oct 14, 2011 | 1988 Mazda RX-7
2004 Hyundai Elantra won't start, emergency flashers keep blinking, can't shut off, lights dim, can't jump start, clicking from under dash from relays. What could it be?
The 'Keyless Entry & Burglar Alarm System" is activated. You must 'Disarm' the system using the Keyless Entry Remove (Key Fob) to "Reset" the system. The reason the engine won't start is due to the burglar alarm - it has a "Starter Kill" circuit which is activated when the alarm is activated. The alarm must be DEactivated to DEactivate the 'Starter Kill' circuit.
Another way to start the engine is to get in the car, put the key in the ignition and turn it to 'ON" and wait 3 to 5 minutes until the emergency flashers stop/turn off. Afterward, you should be able to start the engine. NOTE: This does NOT reset the burglar alarm. It will go off again when you enter the vehicle without using the remote/key fob.
Sep 06, 2011 | Hyundai Elantra Cars & Trucks
I just bought a 1997 mazda miata with no manual i need to set the car alarm and dont know how?
The car alarm was not part of the car as it left the factory, it was fitted afterwards. You'd need to find out what make and model your alarm system is, at least the make, and google for an instruction manual of that alarm. The make could be on your key fobs, or maybe there are stickers on the windows?
Aug 07, 2010 | 1997 Mazda MX-5 Miata
1997 Mazda Miata button with red light lower left Dash
That toggle switch is for the security system. That year miata never came with any switches for the soft top of any kind. Most likely that is an aftermarket alarm system. Most factory alarm systems do not come with a toggle switch.
Apr 22, 2009 | 1997 Mazda MX-5 Miata
Alarm system
you need to ajust the senceitivete on your alarm that should fix it
Feb 11, 2009 | 2000 Mazda MX-5 Miata
How do I reset factory alarm on Miata?
i have a 2001 626 mazda lx,and i can not find my factory alarm switch to disconnect?
Oct 18, 2008 | Mazda MX-5 Miata Cars & Trucks
Vehicle Parts & Accessories Logo
1,144 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
