Question about Cardo Systems Inc Cardo Scala Rider G9 Headset-Motorcycle
Scala rider It does not start when I connect the device to mi PC via the USB cable
Scala rider connects to phone 1 and phone 2 and after 10-15 seconds it shut down
give it back. I also have problems with my Scala rider Q1 system. I would not pay R 200 FOR THIS TYPE OF RECEPTION and i have payed R3000. Bad deal.
Oct 29, 2013 | Scala-Rider Cardo Scala Rider Q1 TeamSet...
The scala rider Q G A won't pair with my I Phone it keeps saying swich your scala on
The scala rider Q G A won't pair with my I Phone 4S it keeps saying nothing
Nov 10, 2012 | Radio Communications
I HAVE LOST THE INSTRUCTION MANUAL & WANT TO USE THE SCALA RIDER WITH MY garmin nuvi sat nav
Please find here a link to google search where the first 2 results are for the scala rider headset
http://www.google.com/search?q=scala rider user manual
Jun 20, 2011 | GPS
My tom tom rider cnt find my cardo scala headset even tho it is on, can you solve, thanx
i have the tom tom rider 2 its a great bit of kit but i disconnected the scala cardo headset for helmets so that i cold try a different bluetooth headset for use in a car and it didnt work i then tryed to recconect it to my tom tom and it cant find it when searching for it what do i do ? what have i done?
Aug 06, 2009 | Tomtom RIDER GPS Devices
Volume
I had a similar problem when I first connected my Cardo Scala Rider set to the helmet. First off, make sure that the volume on the Zumo is set to 100% for BOTH guidance and mp3 functions. Then click the upper control on the Cado Scala to maximize the volume of the headset. When you've accomplished those two electronic hurdles, adjust the location of the speakers in the helmet - if location of the speakers is not optimized nothing you do with the electronics will have much effect. I typically run the mp3 volume at 20% and the GPS at 50% with the headset volume at halfway. My Cardo Scala unit is a Teamset and I sometimes have problems hearing my rider scream that I'm going too fast. I haven't bothered yet to tell her to keep the microphone closer to her lips.
Aug 07, 2008 | Garmin zumo 550 GPS Receiver
Help!
Turn on your garmin out of the car, connect to a PC via USB cable and see if the battery indicator goes away. If it does then the USB to PC cable is working and charging the unit. To test the car adapter, you can unscrew the tip of the plug to examine the fuse. Most Garmin car charger units have a light on them that ilimunates when you plug it in and turn the ignition. It could be that the plug is just loose in the socket. The picture shows the unit running on battery. If you plug in the usb cable and this indicator goes away, then it should be charging.
Jul 25, 2008 | Garmin StreetPilot c550 GPS Receiver
Cardo Systems Inc Cardo Scala Rider G9 Headset-Motorcycle Logo
Top Cardo Systems Inc Radio Communications Experts
eradiostore
eradiostore
Are you a Cardo Systems Inc Radio Communication Expert? Answer questions, earn points and help others
