Question about True Technogym Excite Run 700 Treadmill
Tgs key a treadmill ask tgs key and i don't have . what can i do?
I have a centaurus treadmill CF9010 and i don't know where to put the safety key to make a calibration of a treadmill. Can anybody help me pl?
downlod the instr. manual and see how to start. go to
www.fitness.manualsonline.com
normally the safety key, is in the display board down in the midlle at panel.
God bless you
Dec 10, 2012 | Exercise & Fitness
Nordictrack 5.7 buttons don't work
Call the 800 number on the front of your owner's manual (downloadable at iconservice.com) for service. Most likely your console is shot. It is easy to swap out, but costs a little bit. Also, make sure your safety key is on. Consoles do not operate without that little red key in the front.
Dec 01, 2012 | Nordic Track Nordictrack T 5.7 Treadmill...
Elu tgs saw wont start up flip over
i have no clue what you're talking about
Aug 01, 2012 | E-Machines W3107 (RBW3107) PC Desktop
Treadmill buttons don't work right. TV won't turn off. Treadbelt won't run.
1) Try to reconnect the plug between console and pcboard very well.
2)Clean the contacts with special contact cleanear( radio schack or computer store) with carefully only the buttons, if you can open the cover better.
3) adjust the Sensor SWITHC.
4) Look for any wire loose, or making bad contact, or break wiring( continuity) test the fuse and breaker.
If after you did those steps, and the problem persist, the console board is faulty.but first change the sensor switch, you must be shure after adjustment.11_18_2011_12_23_17_am.gif
Nov 17, 2011 | Exercise & Fitness
I plugged it in and it will not start. It was working fine yesterday but now nothing.
Did it possibly blow a fuse in the treadmill? Also, Check your circuit breaker as well, and see if a circuit blew that was dedicated to the outlet.
Read the user manual of your treadmill to find the elevation motor. The treadmill fuses are located inside the elevation motor. If you don't have the manual, contact the manufacturer of the treadmill and ask if it can send you one or if there is one you can download online.
Turn off the treadmill and unplug it. If you have recently used it, let it cool down for one hour before opening.
Place the treadmill on its side and use a screwdriver to unscrew the lid off the elevation motor. Carefully remove the fuses. Some treadmills have easy access to internal parts where you don't need a screwdriver. If this is the case, simply lift the lid off.
Take the faulty fuses to a hardware store to make sure you purchase the correct replacement fuses.
Insert the new fuses into the elevation motor and close the lid. Plug in the treadmill to see if it works.
Sep 06, 2011 | Sears Exercise & Fitness
Is it possible to operate a Nordic track A2550 treadmill without the key? If so, how?
First thing I'd try is just using any magnet. I'm sure that's all the key is normally. If that doesn't work, no you cannot use a treadmill without a key. It's a safety measure created by the company.
Here's the key for sale on amazon that goes to your treadmill.
http://www.amazon.com/Pro-Form-Treadmill-Safety-Key/dp/B002YP4KQE
Hope this helped!
Jun 18, 2011 | Exercise & Fitness
I downloaded MS Office 2010 Home & Student Trial version in my laptop and recently decided to find a trial version for Outlook 2010. i found one and have downloaded the outlook.exe. However, when...
If you just click next past the key, you can continue the trial with no trouble. It asks you for the key ahead of time because some people have already purchased it before downloading. Hope this helps!
Jun 02, 2011 | Computers & Internet
My Bowman treadmill 7 series stopped working. It just shows 2 words: safe out. Please help.
Make sure the magnetic safety key ('safety pull' or 'emergency stop magnet') is in place. SAFE OUT indicates that the safety key is not in position or is otherwise not working properly.
For more information consult the following manuals:
http://download.dfxi.com/supportdocs/OM/Bowflex/BFX_TM3-5-7_OM_RevD_web.pdf
http://www.pdfstock.com/bowflex-3-5-7-series-treadmills-assembly-manual-pdf.html
May 05, 2011 | Bowflex Treadmill Series 7
Key STuck Error
The key pad is not functioning properly thus this error is flashed you will need to replace key pad. Since I don't know where you are then the place to get the part is from precor directly the will ask Model & Serial #s
WORLD HEADQUARTERS20031 142nd Avenue NE
P.O. Box 7202
Woodinville, WA 98072-4002
T: 425-486-9292
T: 800-786-8404
www.precor.com
Jun 30, 2010 | Precor C954i Experience Treadmill
The treadmill does not incline. Motor runs when the button is pushed but no movement.
Try Re-Calibrating 1st, here's how.
With the Treadmill off, press and HOLD the SPEED UP & STOP
keys, while holding the speed up & stop keys insert the Safety key (Magnet) release the speed up & stop keys. now press and release the stop key. now press the "incline up key" let the treadmill go to max incline,after it stops press and hold the "incline down key" let it go to minimum (completely lowered) you should now be re-calibrated.
Dec 23, 2009 | Epic 425 Mx Treadmill EPTL88105 !
True Technogym Excite Run 700 Treadmill Logo
23 people viewed this question
Top True Exercise & Fitness Experts
John Ritchie
Level 1 Expert
Tom Chichester
Electro Med Services...
Are you a True Exercise and Fitnes Expert? Answer questions, earn points and help others
