Question about Polaroid Televison & Video
Power board TC18813F- parts list needed
Need to know specs for large capacitor in slot HS2 on the board.(ie:uF/V)
SOURCE: Philips PLASMA TV 42PF9956/37 42" power board 3104 313 60173 relays clicking TV does not turn on
The capacitors for 2533,2540,2541,and 2508 should be replaced. They are all 100uf 16v surface capacitors. Those capacitors are sold on amazon.com http://www.amazon.com/Rubycon-Electrolytic-Capacitor-IMPEDANCE-Continuous/dp/B0015A8U9M/ref=sr_1_2?ie=UTF8&m=A6Q8GCHJGURD6&s=industrial&qid=1225140147&sr=1-2
Posted on Oct 27, 2008
  • 4 Answers
SOURCE: sk-19h210s won't turn on even after 'repair'
Are you sure you got the polarity right when you installed the capacitor? On the one I fixed the negative lead went to the outside of the circuit board but check the diagram underneath.
Posted on Sep 19, 2009
SOURCE: what Uf & voltage capacitor do i need for my
the defective caps in general will be blown upwards there heads will not be flat the value will be indicated on the defective capaciter you must respect polarity .
Posted on Jun 10, 2010
budmrtn
  • 11361 Answers
SOURCE: R5 Resistor blown. Cannot find specs, or where to
Is it the surface mounted resistor? Pictures will help. budmrtn@aol.com
Posted on Jul 22, 2010
SOURCE: Polaroid TLX-03210b with power supply TC18813F no
I believe it is r16 which is a 10 ohm surface mount resistor. It is the closest thing in parallel to r55 (.47 ohm @ 2w)
Posted on Jan 12, 2011
Error code 42 I need to replace the electrolytes capacitors. Can you provide the part code
What caps where? There are capacitors on various boards on those sets. Does the code 42 tell you what board they are located on?
The values are indicated on the caps themselves and the values vary all over the place with regard to uf spec and voltage.
Sep 08, 2015 | Televison & Video
If you wish to get more details, surf the following link. There are over two thousand and four hundred posts. All are related to television and other domestic electronic equipment service help. You can get a solution there. Type in the brand name to your device to its search box, can be located at the top right of the display window.http://electronicshelponline.blogspot.com/
May 10, 2013 | Polaroid TDA-03211C 32 in. LCD HDTV
Capacitor on induction blower
How many uf is indicated on the capacitor.It will show a number ie 10uf. If the rating on the capacitor is more than 5uf or less than 3 uf then the capacitor is failing. 10% variance is acceptable. Most electrical wholesalers sell capacitors and cost is around $20.00 or so.
Mar 26, 2013 | Power Acoustik Pcnc3.0f 5 Farad Digital...
Panasonic viera capacitor
look closely on the board and the part. you will see a part number.
Feb 25, 2013 | Panasonic TC-32LX70 Television
My tv wont turn on
The main cause of this power up problem are bad capacitors on your power if the capacitor is bad. See more bad capacitor image
Now, if your TV set is still under warranty I would suggest to use it and let the professionals handle the problem for you.
Now lets talk about the specs, capacitors hold 3 important value:
1. The capacitance measured in uF(micro farads) (ex. 2200uF), 2. Voltage (ex. 10v), 3. Temperature (ex. 105°C)
Important Notes:
TV power supply capacitors has 10v installed on the board and it is attached to a 12v bus which is causing to bulged. (I'm not a Electrical Engineer but I do know if you put too much on something, its going to get bigger or burst. And that's why our TV sets end up with bulged or leaked capacitors)
Look at the bad capacitor and get the right information from it, remember uF, voltage and temperature. Mine, I only change 2 capacitors. It needed two 2200 uF, when I first saw my power supply it was really easy to spot the bad caps. Some TV owners did went ahead replace all the capacitors on the power supply to make sure. Now if you're like me, an inexperience solder, I would not recommend changing all the capacitors because to me it was time consuming
Few things to take note, always make sure you have the right polarity. Negative part is where the colored stripe on the capacitor. If your looking at the image above, it would be the copper colored stripe. And if you are looking at the two connector wire of the capacitor, the negative wire is the short one. On placing it on the board make sure negative to negative and positive to positive. By this time you will be ready for soldering.
Hope this help in solving the problem.....
Oct 12, 2010 | Mitsubishi CS-40503 TV
I have a Mitsubishi VS-4543 that has no power at all.
The main cause of this power up problem are bad capacitors on your power if the capacitor is bad. They are always bulged or leaks capacitor.
Now, if your LCD set is still under warranty I would suggest to use it and let the professionals handle the problem for you. But for the rest of the LCD TV owners that their warranty had expired and want to save some money, this would be the best route.
Here's what you need for this problem to be solved ,Screw driver, Soldering iron(40watts+), Desoldering braid, Soldering wire, and capacitors.
Important Notes:
power supply capacitors has 10v installed on the board and it is attached to a 12v bus which is causing to bulged. its going to get bigger or burst. And that's why our LCD sets end up with bulged or leaked capacitors)
Look at the bad capacitor and get the right information from it, remember uF, voltage and temperature. Mine, I only change 2 capacitors. It needed two 2200 uF, when I first saw my power supply it was really easy to spot the bad caps. Some LCD owners did went ahead replace all the capacitors on the power supply to make sure. I would not recommend changing all the capacitors because to me it was time consuming
Oct 01, 2010 | Mitsubishi VS-4543 45" TV
My union color television is dead only power red light is on.
Swollen, Bulged, Bad Capacitor The main cause of this power up problem are bad capacitors on your power if the capacitor is bad
What you need for the opening of the television is Screw driver, Soldering iron(40watts+), Desoldering braid, Soldering wire, and capacitors.
Important Notes:
Flat panel Television power supply capacitors has 10v installed on the board and it is attached to a 12v bus which is causing to bulged.
Look at the bad capacitor and get the right information from it, remember uF, voltage and temperature. Mine, I only change 2 capacitors. It needed two 2200 uF, when I first saw my power supply it was really easy to spot the bad caps. Some Samsung LCD owners did went ahead replace all the capacitors on the power supply to make sure. Now if you’re like me, an inexperience solder, I would not recommend changing all the capacitors because to me it was time consuming for a noob(newbie) like me ^_^.
But if otherwise, the power supply board is bad, you can try websites Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Hope this helpout...
Aug 08, 2010 | Televison & Video
Fan stopped running. no power to the fan (ie, no
You may find the parts that you need at the following web site...http://www.eceilingfans.com/
They have all of the capacitors there. All you need are the number of wires and the capacitor micro-farad ratings.
Dec 03, 2009 | Patton (PX400UC) 20IN Extreme...
TRUTECH PLV16190 Capacitor replacement what type
I take it there is a bad capacitor on the inverter?The board that powers up the lights for the screen.Any bad ones on the power board as well?The two PLV16190 I fixed had bad capacitors on both boards.Usually the tops,and or bottoms bulge out when they go bad.When you do go to replace them,you can get ones with a higher value on both specs,but not lower.For example,if there is a 10V 1000UF,and a 16V 1000 UF,you can replace them both with 16V 1000UF,and it will work perfect.You can also use different heights as well,as long as there is enough room.The type you want are called Aluminum Electrolytic.I hope this helps.If you have any other questions,please let me know.Thank You very much!
Tyler
Feb 23, 2009 | TruTech PLV16190 Television
HPvs19e
Ken:
Here is additional info requested, the hardest part is cracking open the monitor case. Prior to working on this you should check to be sure the capacitors are discharged. A good way to do this is to connect a 12V light bulb across the terminals and when it goes out the cap is dicharged. You can also have a look at this page ( http://ezinearticles.com/?The-Right-Way-To-Discharge-Capacitor-In-Switch-Mode-Power-Supplies&id=64778 )
Spec is:
Cap Xon, 1000 uf 10V, KF 105 deg C, P602 vent
(3) capacitors identified on the board as: C822, C823, C824
They are the 3 right above where the multi color wiring harness plugs into pwr supply board shown in lower right of pic.
John :).
Nov 21, 2008 | Computers & Internet
Televison & Video Logo
42 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
