Question about Home Security
Safetron safe question
My safe is open now , but im afraid to close it because i cant remember the code, can i reset the code now that the door is open, or do i have to buy a new safe.
joboo1
  • 257 Answers
SOURCE: get new combo on senry dial safe
Hi, There is only one way, and that is to send a letter with the serial number to Sentry and if the info matches who is supposed to own it, they will send you the factory default combo to open it. Good Luck!
Posted on Feb 14, 2009
SOURCE: Sentry Safe (DSW3607 Model) Won't Open
I finally ignored the poorly-written instructions for programming a personal code and simply entered the factory code first and then pressed the prog/enter code button.  The safe opened.  The instructions tell you to push the prog/enter code first and then enter the factory code or personal code to open the safe.  Wrong!  Do it my way should this problem happen to you.
Posted on Mar 23, 2009
  • 3 Answers
SOURCE: s3517sentry safe need to reset
Press: Program 2x, enter a digit user-code (green led remains on), enter the 5 digit user pin (of your choice except 00000). After 5 digits entered, the green LED turns off.
Posted on Feb 02, 2010
loxmith
  • 21 Answers
SOURCE: Sentry Model 1610 Won't Open
here is the customer service phone number for you. I am sure they will be able to help you. 800-828-1438
Posted on Jul 24, 2010
micromatikal
  • 2777 Answers
SOURCE: I cannot close the opened
You can't close the opened door and lock it? Usually this just means the batteries need to be replaced in the keypad. Have you tried replacing the batteries in the keypad?
Thanks Tim
Posted on Oct 02, 2010
Mother just past away,luckily safe was open at time,but dont know combo to keypad or we haven't found a key,how do i reset code to sentry10 gunsafe
To reset the combination on a Sentry safe, open the door of the safe, delete the existing codes, press the PROG or P key and enter the factory code. Finally, enter a new five-digit number as per individual preference, which is the new user combination.
It is always prudent to reset the combination on a Sentry safe when the door is open because it prevents the user from being locked out. To open the Sentry safe door, type the five-digit factory code given in the owner's manual. This factory code cannot be altered.
To delete the existing codes on newer models of the safe as of 2015, press the P button. Then, type the factory code and follow it up by inputting "00000" into the safe. On older models of the Sentry safe, press the PROG button and type the factory code two times.
After deleting the existing codes, press the PROG or P key and then enter the factory code once again. Within five seconds, type a new five-digit number, which is the new user code. To verify if the user code is working, retype it and then close the door of the safe. The user code is the primary code for opening the safe, and users can reset it as often as they want too
Mar 21, 2017 | We Home Security
Brinks Home Security Safes
i think with this kind of safe it comes with 2 keys, one which requires the code to be entered, and a master key that will unlock without requiring the code.
if you have the master key, just use that.
after you have opened the door you can reset the code by pressing the reset button (a pin / paperclip required to press)
on the back of the door.
Feb 15, 2017 | The Computers & Internet
How do i change the code on a s25e digital safe i cant find the book
if its like my old woolworths one, open the door and press a red reset button on the inside of the door, close the door and dont lock, put in the 4 numbers u wish a press a A button on the keypad, or whatever ur enter button is, then lock it, then press the 4 numbers again and the A button or enter, a light should stay on and unlock :)
Feb 21, 2011 | Safe International Electronic Gun Safe...
I forgot my safes password
call a local locksmith he can help, if it can not be opened you may have to bust it open, call some one with many tools they may help. I recommend an angle grinder this will cut through steel. If you can remember where the pins are that hold the door closed you can grind through the side and cut the pins with two cuts. would take ten minutes to open with this method. There is probably an upper and lower pin.
Apr 01, 2010 | Safe International Digital Electronic Safe...
I cant remember my passcode how do i reset it
According to what I found, as long as you can get into the safe, all you do is press the black reset button on the inside of the door, then enter the combination of choice, followed by the # sign. If you cannot remember the code and the box is locked, there is supposed to be a manual override key hidden somewhere on the safe. Good luck.
Jan 04, 2010 | Honeywell Safes 2054D Fire Safe with...
I need help unlocking security code
Try using this as your security code
IMEI: 351953036226061 Security Mastercode: 3523746434
If this mastercode doesnt work, then im afraid your handset will have to be reset using a Nokia service box.
This will cost around GBP£5 - £8
Dec 21, 2009 | Cell Phones
Can't open safe . changed batteries. green light comes on but still can't open safe
I remembered that I put an important binder in the safe and had a hard time closing the safe. When I put in the code the safe was making a noise as if it wanted to open so I got a Mallet hammer and tapped the door with it, put in the code again and the door opened. I think that the binder was the problem .Needless to say, I took the binder out and the door has been opening. just fine.
Irene
Oct 03, 2009 | Sentry Fireproof Safe
Need to reset the electronic code to open the safe.
are you the manager user of the safe?if yes,you can reset a new code by yourself.
Apr 06, 2009 | Safe International Digital Electronic Safe...
Cant reset Z error at Printer Ricoh Aficio 1018D
Im assuming that you are referring to the Z as the jam light. In that case the operation panel will tell you what part of the machine is jammed by displaying a diagram and a letter that corresponds to a chart that you will see when you open the front door. make sure to open all the doors then close them to reset jam code (there is a hidden door on the right lower side called the A door) Good luck
Apr 05, 2009 | Ricoh Aficio 1018D All-In-One Laser...
Home Security Logo
133 people viewed this question
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
