Audiovox aom55 backup monitor system - Computers & Internet
The UPS in this office is out of order, message that appear on screen is 'UPS V OUT LIMITS' and 'Battery critical'
follow this steps and fix it. God bless you
Plug the battery backup into a working electrical outlet. If the battery backup turns on when the power button is pressed, then the problem may be that the previous electrical outlet is faulty. Proceed to step three. If the battery backup doesn't turn on, proceed to step two.
  • 2 Reset the circuit breaker on the battery backup. APC battery backups have a labeled circuit breaker button located on the unit near the phone line, fax line, USB, network and coaxial cable inputs. Press the button to reset the circuit breaker. Power on the battery backup by pressing the power button. If the battery backup powers on, proceed to step three. If the battery backup doesn't turn on, proceed to step six.
  • Read more: http://www.ehow.com/how_7266444_troubleshoot-apc-battery-backup.html#ixzz2lwOvPO75
  • 3 Determine if the battery backup is charged and providing battery power. With the battery backup on and plugged into a working electrical outlet, plug a computer monitor into one of the battery backup outlets labeled "battery backup plus surge protection" on the battery backup. (APC power supplies have some outlets that provide only surge protection while the other outlets provide surge protection plus battery backup.) Turn the monitor on. Unplug the battery backup power cord from the wall outlet. If the monitor remains on, the battery is holding a charge, supplying electrical power and the battery backup is working properly. If the monitor goes off, proceed to step four.
  • 4 Charge the battery. Plug the battery backup into an electrical outlet and allow the battery to charge for 16 hours. This will fully charge the battery.
  • 5 Test battery charge. Once the battery is fully charged, repeat step three. If the monitor stays on when power is interrupted to the battery backup, the issue is solved and the problem resulted from an incompletely charged battery. If the monitor turns off when power is interrupted, the battery within the battery backup is faulty and needs to be replaced.
  • 6 Replace the battery backup unit. The unit itself is faulty. If the battery backup is under warranty, contact APC to request a replacement.
  • Nov 28, 2013 | MGE NOVA AVR 1100VA Tower UPS 81111 UPS...
    Can't control sound ...Gets LOUD.... Audiovox not helpful to date
    actually there would have been some short circuit in the connections...
    that would have affected the sound system...
    so only you get the spikes.....check for the affected parts and replace them
    Apr 11, 2008 | Audiovox VOH1502 15 in. Car Monitor
    Need aservice manual for a audiovox 350 back -up camera for a car or owner manaul
    If you don't find what you need, you might consider the truly wireless QuickVu(TM) Wireless Backup Camera. The camera has absolutely no wires, so it is easy to install. Buy direct from the manufacturer!
    Oct 16, 2013 | Audiovox Acam350 3.5 Inch Lcd Rear-view...
    Looking to buy touch screen faceplate
    Try audiovox.com. You should be able to find a way to contact them there. Audiovox now owns Jensen.
    Oct 04, 2012 | Jensen Uv10 7" Lcd In Dash Car Dvd Monitor...
    I purchased a second hand vehicle equipped with what i believe is an audiovox alarm system. The alarm likes to go off at random times and i cannot figure out what is causing it. The car is a 97 vw gti vr6....
    It probably needs to replaced. Audio Vox has several models that have window breakage sensors. These sensors are notoriously unreliable and do this quite often. I would replace the alarm itself.
    May 14, 2011 | Audiovox Car Audio & Video
    How do i buy a remote
    try audiovox.com. audiovox owns jensen.
    Jun 14, 2010 | Jensen KVM-64 Car Monitor
    Jensen VR187 radio/backup camera observation monitor won't work
    In the manual look on page 10 step 10. You have to use a ball point pen and straightened paper clip (better) to reset the unit. There is a small hole at the lower left of the Volume knob. That's where you insert the paper clip.
    Aug 09, 2009 | Audiovox Jensen JTFT-250 2.5 in. Handheld...
    Audiovox DVD overhead Monitor
    the power supply amperes might be too low try using car batt as your power source
    Nov 09, 2008 | Audiovox VOH8512 Overhead LCD Monitor Car...
    Audiovox car alrm
    what model is the audiovox alarm system? If the alarm is not remote start ready, then you will need to install another alarm system or a stand-alone remote start system.
    Sep 11, 2008 | Audiovox Car Audio & Video
    BATTERY
    It's the inside battery. The backup battery has been depleted. So you need to replace it. It can be charged, Only replaced. Now I prefer you to make a hardware reset. If you still have that message. then the battery is the problem.
    Mar 26, 2007 | Audiovox PPC 4100 Pocket PC
    Computers & Internet Logo
    48 people viewed this question
    David Payne
    David Payne
