My G3 1,5tb station does not show up on my iMac anymore. It used to work fine, without any problems and it has only been connected to my iMac. Now it does power up, but the station does not appear on my iMac. Any ideas on how to fix this problem? I'm in bad need of some new files I haven't backed up yet.
  • 1,606 Answers
Check to make sure file sharing is still on at the G3. If it is running a Server app or OS X Server, make sure File Sharing Services is up and running.
Also, check the network connections on both computers. First, open the Network System Preferences pane on the G3 and write down its IP address (Note: you should have IP addresses showing on both computers, and if they use the same router subnet, the first three parts of the IP address should be identical and the last part should be different, but still between 0 and 255. If this is not so, you have a network problem between one computer and the router or other device that provides DHCP services.).
Next, on your iMac, open the Network Utility application (in Applications/Utilities). Click the Ping tab and type in the G3 IP address, then click the Ping button. If the network is good, you should get round-trip time statistics for each ping.
If the Ping test fails, then do the following steps to troubleshoot the network. Check to see if you have link lights on for both computers at the network switch, if not, check the network cable for the unlit port. If they are connected to different switches, also check the uplink port link lights on each switch. Testing a suspect connection is most simply done by trying a known good cable, a different switch port, or another computer with a known good network interface.
Posted on Jun 16, 2013
3 Suggested Answers
kenezz6396
  • 64 Answers
SOURCE: Transferring software and files from PowerPC G3 to PowerMac G4
to mount somthing in a mac is basicly cutting it on for use.
For example if you instal a flash drive or an hard drive via an out side connection, The mac will mount it so you can use it.
Posted on Aug 09, 2009
jerryg50
  • 1689 Answers
SOURCE: Suddenly, my 500GB Seagate external hard drive couldn't mount on my iMac. It was working fine till yesterday. I connected them to the Mac USD port, and the light in the seagate is blinking... Any
I can only comment generically:
I would try to uninstall the drive on the OS. Then re-start the computer. After the re-start, connect the drive and see if the drive re-installs itself.
If the error persists, then the drive is indicating failure. To absolutely verify if it has failed, take the drive to a store where there are MAC computers and try the drive on one of their computers to see if it works.
A continuous flashing LED on most devices where the LED does not normally continuously flash is an indication of a failure of the device. Some devices will flash an error code when designed to do so, and if possible.
Jerry G.
Posted on Aug 14, 2012
Testimonial: "thanks. its a device failure. I had connected it through keyboard usb port, and it seems that the power was not flowing properly to run external memory. "
Magic Jack Plus worked in USB and then Internet on computer stopped working
It's got the wrong gateway setting. Without a gateway (router) to the Internet it can only see local network stuff. I suspect the Magic Jack is still trying to be the gateway but it has no Internet. Stop Magic Jack doing this and it should work.
Feb 27, 2015 | Computers & Internet
Panasonic Lumix and IMac don't recognize each other suddenly
it sounds like its being a webcam.on the camera press the PLAYBACK button/switch so its not a camera anymore
Dec 14, 2017 | Apple iMac Desktop
Cordless logitech mice interference
Hi!
I think what happens there is that both mice is running on the same frequency. What you need to do is to restart the wireless of just one of the mice by pressing the connect button on the usb reciever and on the mouse. That way it would try a different frequency.
I hope this helps.
May 05, 2010 | Logitech Cordless Mouse
I have an iMac 17
Thanks for contacting FixYa Support.
I have repaired numerous iMac G5 17" models for a while now and because I have, I can tell you just from the symptoms you have described, this is potentially a power supply issue.
However, the iMac G5 17" have been known to have swollen capacitors, which can also ultimately impact the power management / performance of your iMac.
If you are able to, very carefully and don't touch them, you can look on the iMac's main logic board to see if you notice any swollen capacitors. If you are not sure what a capacitor looks like, they look like mini batteries connected to the board.
Should you do this and find that the capacitors are ok, then I would recommend for sure, that you look into replacing the power supply.
For your model of iMac 17" provided it is not an Intel-based iMac, the part number you will need to source is part# 661-3627. Below, I have also provided the most inexpensive price for this iMac power supply per this link:
AppleComponents.com
You may find even lower prices for this iMac 17" power supply, if you search online further, but this is one of the better online Apple components vendors. Therefore you should be able to see and compare the prices on this website, with some of the other vendors
advertising the same Apple power supply for the iMac 17".
I hope this helps. If you have any more questions on this subject, simply reply back to this post.
Best Regards,
-Mactechtrainer
Mar 03, 2010 | Apple iMac G5 Desktop
Epson CX4700 printer/scanner won't connect to my apple network
maybe the twin setting chick to twin settings
go to start and you can find the twin setting try it
Jul 06, 2009 | Epson Stylus CX4700 All-In-One InkJet...
Suddenly Pandora Won't Work Anymore on the iTouch
Try removing Pandora and reinstalling it from scratch.
Jul 05, 2009 | Apple iPhone Smartphone
My ps3 wont let me do an update anymore it has a DNS error
your hard disk is damaged and needs to be repaired
Jun 05, 2009 | Video Game Consoles & Games
Mac router compatability Zoom ADSL X6
Remember it takes two to tango, so the issue may just as well be in the iMac as in the Zoom X6... Regardless of that, I had the same problem (PC works fine, iMac and PC both get flaky when the iMac is powered up). Zoom tech support suggested trying RF channels 1, 6, or 11. The router was using channel 10, changing to channel 11 calmed things down. Zoom said there wasn't anything magic in those numbers, but their testing showed those channels worked best with the Apple products.
Dec 26, 2008 | Zoom (5590-00-03) Wireless Router (G66115)
Connection to iMac not working
the easiest way is hard wire a windows laptop and use the CD that came with the router.
Oct 13, 2008 | Microsoft Broadband Networking MN-500...
Wireless Modem don"t connect
well imac G4's don't  have built in airport (wireless internet) included as usual with apple its another item you must buy an airport extreme card  then hook it up to an airport base station another item to buy via wireless internet then hook you airport extreme base station up to your modem via ethernet. whew ok now sync the airport base station to your imac using airport set up application then select your network and type your WEP password and viol internet in about 1 hour if your lucky hope this helped my fingers hurt now LOL.
Apr 07, 2008 | Apple iMac G4 Desktop
Computers & Internet Logo
61 people viewed this question
David Payne
David Payne
