Question about Hotpoint NVL333EY Electric Dryer
Need diagram belt repairclinic
I bought a belt from an appliance store and it seen to be to big for the drum, when I start the dryer the belt slips. they said it was the right belt but its not can you give me the correct belt part number for the hotpoint model nvl333ey. thank you
  • Hotpoint Master
  • 2,699 Answers
WE12X10009 belt part number and it's around 45 dollars
Posted on May 11, 2013
SOURCE: Replacing the Drive Belt
I am not an expert but I do have a Hotpoint 9334 Tumble Dryer which I guess is similar to the 9314.
To replace belt or heater element you must remove the front panel complete with door.
Screws are different sizes in different places so note where they belong as you remove them.
1. Remove 2 screws at rear top which go through the brackets holding the top panel, slide back the top panel a little and lift it off.
2. Pull off the rotary timer knob and remove 2 screws beneath.
3. This is the tricky bit! Remove the the plastic panel which covers the switches etc.. This panel has 5 plastic fingers which secure it to the metal plate behind, locate the ends of the fingers where they pass through the metal plate. Using a metal rod or punch and a hammer, tap the ends of the fingers to push them back through the holes easing each in turn a little at a time to avoid distorting the plastic unduly. (This is a bit scary as you have to hit them quite hard and the fingers look fragile)
4. Open the door and remove the 4 screws then remove 3 screws at the top and 3 screws at the bottom of the front panel. Lift and ease forward the front panel, unhook the door catch release wire, pull off the electrical connectors and put the front panel aside.
5. Lay the machine on its back and remove 1 screw holding the element housing to the top plate and pull off the electrical connectors.
6. Fit the belt around the drum, through the idler pulleys and over the motor spindle.
7. Put it all back together.
Posted on Feb 03, 2008
SyxPak
SOURCE: wiring diagrame for hotpoint gas dryer
E-Mail me and I will send you a copy of my Schematic. It's 2 pics, but they are pretty clear and should help you. I came to the site wher I saw your post looking for a pic of an exploded view of our dryer. Trying to open it to fix the glide bushing. Started makin metal to metal noises lately, so I am assuming it's like a nylon glider for the drum?
SyxPakk@Yahoo.Com
Mike.
Posted on Apr 01, 2008
wmsfarris
  • 22 Answers
SOURCE: hotpoint condenser tumble dryer model tdc30p belt replacement
You will have to unplug the dryer and remove the front panel with the door, mark and remove the wires to the door switch, then there should be two screws on the inside which you will need to remove then tilt the panel out and lift to disengage the tabs connecting it to the main cabinet. Then you should be able to remove the old belt, carefully lift the drum and slide the new belt under it. Then this is where you will need to be a contortionist and take care as there are many sharp edges under there. Locate the motor and tensioner pulley, place the belt around the tensioner and while pushing back against the spring on the tensioner hook the belt to the motor pulley, then move belt on drum so it is aligned with lower pulleys. Turn the drum by hand a couple of times to make sure everything works.
Posted on Apr 04, 2009
dmftrucker
  • 1922 Answers
SOURCE: my hotpoint model NVLR333ETOWB, will not rotate drum
sounds like the belt is loose from a defective idler pulley
Posted on Oct 24, 2009
SOURCE: HOTPOINT DRYER, MODEL DLB1550BDLAD. BELT INSTALLATION.
hotpoint model # DLB2650BDLWH
How do you put a new belt on?
Posted on Nov 25, 2009
Installing belt around drum
There are several helpful dryer belt diagrams that are available at repairclinic.com. Just go to the site and click on "Get Repair Help". Under Large Appliances, select "Dryers". Look for the "Click Here for a Belt Installation Diagram" link. Refer to either diagrams H or K. If you are confused on which diagram applies to your dryer, please post back with your MODEL NUMBER so I can assist you further. I hope this helps you.
Dec 18, 2010 | Whirlpool Dryers
MY MAYTAG DEPENSBLE CARE PLUS DRYER HAS HEAT IT JUST DOESN'T TUMBLE WHAT COULD THAT BE??
Nased on your description, MY MAYTAG DEPENSBLE CARE PLUS DRYER HAS HEAT IT JUST DOESN'T TUMBLE, I have provided some links that may help you diagnose your issue.
1. Drum Belt
2. Drum Belt and Roller kit
3. Parts breakdown and disassembly diagram
4. Belt installation diagram
You will need to provide the model number off the product ID tag located on your dryer to access the links information. Click link number 1 to begin.
1. http://www.repairclinic.com/SSPartDetail.aspx?s=b4a8i529597&PartID=529597
2. http://www.repairclinic.com/SSPartDetail.aspx?s=b4a8i587636&PartID=587636
3. http://www.repairclinic.com/Dryer-Electric-Maytag-Style-Appliance-Diagram
4. http://www.affordableappliance.com/Tips/beltdiagrams.htm
Aug 24, 2009 | Dryers
Maytag Performa PYE G2200 gas dryer, the dryer seems to turn on but the drum will not turn.
Based on the information provided, it sounds like a broken drum belt is at fault. Below is an illustration of the drum belt.
http://www.repairclinic.com/SSPartDetail.aspx?s=t-PYG2200+-%3d%3di529597&PartID=529597
Here is a parts/disassembly diagram:
http://www.repairclinic.com/Dryer-Gas-Maytag-Style-Appliance-Diagram
Here is a belt installation diagram:
Dryers have a drive belt that turns the clothes drum. If the belt breaks, the drum stops rotating. Then you need to replace the belt, and often the idler pulley, because the pulley tends to wear out at the same time.
Click here for a belt installation diagram.
All links courtesy of www.repairclinic.com
Aug 16, 2009 | Maytag Dryers
DRUM WILL NOT SPIN BUT DRYER WILL HEAT IT'S A WHIRLPOOL
I have provided a checklist courtesy of; www.repairclinic.com
They also provide repair parts, disassembly diagrams and procedures.
You can also checkout www.homemanagement.services.officelive.com for other appliance help websites.
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
If your dryer doesn't tumble, check these:
Belt
Motor
Door switch
Belt Dryers have a drive belt that turns the clothes drum. If the belt breaks, the drum stops rotating. Then you need to replace the belt, and often the idler pulley, because the pulley tends to wear out at the same time.
Motor If the dryer motor only hums when you press the Start button, the motor may be burned out. Here's how to test the dryer motor:
  • Remove the belt.
  • Check for obstructions in the blower fan housing.
  • Manually rotate the shaft of the motor.
If the motor is very stiff, or impossible to rotate manually, and the blower fan housing is clear, you need to replace the motor.
If the motor rotates freely, run the motor momentarily with the belt removed and the blower in place. If the motor runs fine with the belt removed, there may be a problem with the idler pulley or the clothes drum. Try to rotate the drum by hand. If it is very difficult to move, correct any problem with the rollers or pulley, and then reassemble the dryer and try it again.
If the motor hums but doesn't rotate on its own even with the belt removed--yet you can turn it freely by hand--you usually need to replace the motor or the motor start capacitor.
Jul 13, 2009 | Kenmore 63942 Dryer
My kenmore dryer won't spin or tumble. The motor runs but no tumbling. I heard a loud bang but didn't know what happened. çould it be the belt?
If the drive motor is still running, the loud bang you heard was either the belt breaking, or slipping off the idler pulley. I will need a model number in order to give you spcific details on how to open the appliance in order to inspect and replace your belt. If you need assistance on how to properly route the dryer belt on to the drive motor shaft and idler pulley, repairclinic.com has dryer belt diagrams listed under their "Special Features" section. Just click on the "Repair Help" link at the top of their web page, to start. You will need either diagrams H, B or K. Its hard to determine which diagram without your model number. Post back with your information and let me know.
Jul 11, 2009 | Dryers
My dryer is sqeaking loudly when running
Squeaking usually comes from drum roller supports and/or the belt idler pulley needing lubricated. If the drum does not have drum roller supports under the drum, it will be equipped with a plastic drum glide the is located around the perimeter of the front drum facing. If this plastic wears down it will cause the drum to scrape against the metal bulkhead and make noise. If equipped, you need to replace the drum glide
The drum rollers (if equipped) can be lubricated with a light weight turbine oil (like the kind you would lubricate some ceiling fan motors with). Lubricate the roller wheels at the axle ONLY. Do not lubricate the wheels. The same is true for the idler pulley. Make sure you don't get any oil on the belt, or it will slip.
If you need instructions on how to reinstall the drive belt, repairclinic.com has dryer belt diagram illustrations under their "Repair Help" section. Look for the "Dryer Belt Diagram" link on the left hand side of the page. If your dryer is a GE model, you would use diagram M, D, or L (depending on the age of the dryer).
If you have questions, let me know. I hope this helps you.
May 06, 2009 | GE 7.0 Cu. Ft. Super Capacity Gas Dryer
Model DE590 dryer needs drum belt replaced. I need instructions on how to do it.
Your complaint is: "model DE590 dryer needs drum belt replaced. I need instructions on how to do it."
This link, http://www.repairclinic.com/SmartSearch/SmartSearch.aspx, provides exploded view imagery, belt routing diagrams, parts imagery and function, parts ordering and shipping information, error code details, just about anything you need to get your appliance up and running again. Just follow the links to navigate through the site. You may need to enter your model number; DE590 to gain access to your information.
This link shows the belt and cost.
http://www.repairclinic.com/SmartSearch/SSPartDetail.aspx?PartID=1246110&PPStack=1
This link shows the belt routing, use diagram E
http://www.repairclinic.com/0079.asp#DiagramE
This link shows disassembly, exploded view directions. http://www.repairclinic.com/0100_18.asp
All service is performed from the front except for the installing the belt back onto the idler pulley. That procedure is done through an 8" removable panel in the rear at the bottom.
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Jul 13, 2008 | Maytag Dryers
Roper elec dryer
You will need to enter the model number stamped on the manufacturers product information data tag, located on the unit, and not in the User’s Manual. to access your product information.
Here are some common solutions to help resolve the issue with your appliance.
Clicking on the underlined links will take you directly to that page.
Very rarely, a voltage issue could cause this symptom, but you should rule out the other possibilities first, unless you have a volt-ohm meter, then a quick check of the voltage MAY rule out these other issues.
This could be a motor or drive system issue. To test for a motor problem, you will need to remove the drum belt. See exploded view diagram link below, for disassembly.
http://www.repairclinic.com/0100_16.asp
If the motor fails to start, replace the motor, See link below.
http://www.repairclinic.com/SmartSearch/SSPartDetail.aspx?PartID=2584&PPStack=1
If the motor starts, then you will have to look for:
1. Blower obstruction
2. Rear drum rollers.
3. Idler pulley
4. Drum belt, See link below
http://www.repairclinic.com/SmartSearch/SSPartDetail.aspx?PartID=587636&PPStack=1
5. Front tub glide bearing and seal assembly. See link below.
http://www.repairclinic.com/SmartSearch/SSPartDetail.aspx?PartID=2702&PPStack=1
Thank you,
Dave E. (Illeagle)
Jul 11, 2008 | Roper RES7646KQ Electric Dryer
Trying to put belt back on dryer have know diagram
Follow the link to the belt diagram page and it will show you how to route the drum belt for your particular dryer.
http://www.repairclinic.com/0079.asp#DiagramK
Jun 08, 2008 | Roper Dryers
Hotpoint NVL333EY Electric Dryer Logo
75 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
