Question about LG 32LG30 32 in. LCD HDTV
Lg 32ld330 ta
I have been told that the panel is bad and the TV cannot be repaired. It is only 3 years old. What can I do?
SOURCE: LG plasma tv
Most likely it's the PDP panel wires failure. It won't cost you more to repair then to buy a new one.
Posted on Apr 28, 2008
  • 67 Answers
SOURCE: Picture distorted with images and outlines
Unfortunately this is an unrepairable problem called screen burn.
This happens commonly with old displays and can only be fixed by replacement.
More information can be found here: http://en.wikipedia.org/wiki/Screen_burn-in
Posted on Mar 27, 2010
Testimonial: "thanks a lot, quick response and straight to the point"
  • 5 Answers
SOURCE: LG tv sound quit - will it work if I add external speaker system
Maybe!! It depends on where the audio sys failed. If it failed at the output drive, then you can take the audio off at the audio output jack and input it to your stereo system where there is an audio input. You'll need a cable with RCA jacks on it for this.
If your system is muted for some reason, this may not work.
Posted on Jun 18, 2010
  • 8457 Answers
SOURCE: lg tv takes a long time to turn on. Flat panel 32"
Power supply board have those parts call capacitors are dying,have leakages gases capacitors parts.Take the tv aparts.The power supply board,that the board,where the power a/c cord plug into it.U know basic electronic,have all the tools?know basic soldering?Searches the power supply board for those dying capacitors,that have leakages of gases going to dead capacitors.These dying capacitors on the power supply board alway bulges up on it tops or puffing up on it tops.These dying capacitors,must be replaced.The tv power will power up as normal and faster.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Posted on Aug 04, 2010
  • 8909 Answers
SOURCE: don't have a manual -
If you were to log on to the manufacturer's web site, I think you will be pleasantly surprised as usually one is able to download, by model number, Customer Instruction Manuals, list of Dealers as required.
Just Google the manufacturer's name and follow the links. Make certain you are directed to the manufacturer's web site as some search engines direct you to other sites and they charge for the information that is normally free of charge.
I hope this helps.
Posted on Nov 07, 2010
I NEED AN LG INSTRUCTION MANUAL FOR MODEL 42PC7RVH-TA. I NEED TO TUNE MY TV
LG 42PC7RVH-TA
Hello Joyce,
Service manual site (below)
Personally I'd try talking with the shopjimmy.com folks
"tune" has such an ominous sound when talking of
Plasma sets...
42PC7RVH-TA
Download lg 42pc7rvh 42pc7rvh ta plasma tv service manual
Dec 11, 2016 | LG Televison & Video
Can i use chromecast on this model tv LG 42px3rvc-ta
Ought to work with HDMI. Suggest to try before buying or have a Return policy.
Most HDMI displays work with Chromecast, but not all will allow full Chromecast controls (HDMI-CEC for games, media functions with TV remote, etc.) If all of the HDMI ports on your display are in use, consider getting anHDMI Switcher
See Chromecast compatible televisions
When you see the model LG 43PX3RVA (nearest to your model) it is listed as '480p and incompatible. however the detail inside lists
Westinghouse LTV-46w1 HD
Apr 09, 2016 | LG Televison & Video
No picture and only sound
the problem of your plasma will be in hardware
you must contact to a led or plasma repairer otherwise its not possible
Oct 10, 2014 | Televison & Video
Wont turn on
If parts are unavailable because your unit is too old, then all you can do is buy a replacement unit.
Nov 10, 2013 | LG Televison & Video
Tv lg 32ld330 enciende con sonido y sin brillo
Mi tv lcd es marca LG modelo 32LD330, al encenderlo se escucha y cambia de canal pero el video lo emite a mitad no da la imagen completa que puede ser?
Aug 18, 2012 | Televison & Video
Top of screen had 2 6'' lines across top of the screen,then it went all distorted and shut itself off. the unti is a 50'' lg model 50pg25 and is only 9mths old what caused this and is it upgradeable to the...
You can't upgrade a panel tv, plasma or LCD.You may have had a plasma panel failure,I sell LG tv's and for the panel to go bad is rare but I have had it happen approx.6 times in the past 5 years.I highly recommend contacting LG"s customer service they will stand behind the panel and get you going again.Good luck!
Nov 22, 2009 | LG 50PX5D 50 in. Plasma HDTV
Philips plasma tv vertical black stripe
Hi
If there is no picture behind the stripe and the edges are well-defined, then one of the display driver ICs has failed. Philips displays can be made by several manufacturers - usually Samsung. The ICs are bonded to the flexible ribbon in most cases, and replacement is an expensive specialist job - and in many cases is simply not possible.
A shadow on the picture is much better - usually due to interference.
Glyn
Jul 22, 2008 | Televison & Video
LG rear projector tv
Someting does not fit in here. The model 42LC2D is a plasma model and it has no lamp inside. Every part is covered by the warranty on this model.
Jan 03, 2008 | LG 42LC2D 42 in. LCD HDTV
LG 32LG30 32 in. LCD HDTV Logo
24 people viewed this question
Computer Repairing
Computer Repairing
