Question about Refrigerators
Stopped working for no reason
Refrigerator simply stopped working without warning. It's only two years old, and looks as good as it did when it was purchased. Could this be a simple fix (like a fuse or something)?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 31 Answers
Light on? Do the fans run?
Posted on May 14, 2013
  • 146 Answers
SOURCE: refrigerator stopped cooling
The most common problems for refers not cooling is a condenser fan motor (the one that cools the compressor) is out. This can be caused by either a mouse has tried to jump trough the fan and it came on or a loss of grease or oil. There is no way to oil them so they have to be replaced. That is the problem especially if you unplugged the refer and it worked for a while then quit. If the fan doesn't cool the compressor it will overheat and shut down coming on intermittently then shutting off again. As for the refer that still doesn't cool when everything else does you may have an burnt overload also. Check the compressor area for burnt or stalled components ex. fan motor, relay, overload. If your compressor is out plan on spending from $300.00 to $500.00. But check the suggested components first. And beware there are appliance shops out there that will find one of these problems and give you an estimate for a compressor. Find someone reputable.
Posted on Dec 18, 2007
SOURCE: GE Side by Side stopped cooling
This sounds like the defrost heater is bad or dead. The refrigerator will not cool because frost is building up on the evaporator coils in the freezer section and the fan can no longer push air past the coils. You will find that the freezer will build up with frost.
If you are brave enough, remove the cover in the freezer and you will see the coils are completely covered with frost (ICE). At this point with the refrigerator unplugged ( remove food). get a hair dryer or heat gun and melt all the frost. You will notice a heating element ( looks like a tubed light) -element will looked burnt out.
Replacing it at this point is easy. Before you start though, try to get the manual for your system and call around for a local appliance parts store to see if the part is readily available.
Posted on Dec 22, 2007
sdmc73
  • 121 Answers
SOURCE: in door ice dispenser does not work but the water dispenser does.
the module on the icemaker may be bad or the emitter-recever
Posted on Nov 29, 2008
  • 33 Answers
check to make sure there is water or ice in your ice maker tray. If none then problem is usually a water supply issue to the ice maker. Behind the frig are the water supply inlet valves. One is for the water dispenser in the door. THe other is for the ice maker. However when one goes bad they both are replaced as one unit. Also Check position of fingers in ice maker. If not in a vertical position then try to reset the ice maker unit and worse comes to worse, replace it with a new one.
Posted on Nov 30, 2008
SOURCE: I have a GE side
Well, the solution to this problem was posted in this thread
http://www.fixya.com/support/t1295372-ge_profile_ref_ice_despenser_motor_not
It seems that the bulb in the front panel is pulling to much current as it ages and it makes the control panel in not work properly. Removing the bulb will fix the problem - just fixed mine.
Also seems to match your symptoms (works sometimes and then not others - bulb current is inconstent, light dims when dispense lever pressed - again wrong current draw).
Good luck
Posted on Apr 19, 2009
A while back the refrigerator was freezing everything even though it was set on low. Even the veggies in the veggies drawers would freeze. Now, it stopped doing that but once in a while it will start...
Hi, There can be many reasons why your refrigerator is freezingyour food. To see what could be happening and to figure out how to possibly fixyour problem. Take a look at this tip which contains many of the causes andsolutions to fix the problems.
Refrigeratoris Too Cold and Freezing Food
heatman101
Jul 26, 2011 | Magic Chef CTB1722 Top Freezer...
Amp stopped working one day for no reason. Been running it the same way for a year and a half just fine about half gain not too loud the day it stopped. inside looks fine, however i took a multimeter to...
i would be more inclined to think the Amp is pooped and chances that a cold solder joint or a blown power capasiter right on the circut board and even if you took it apart it could be very hard to find if you don't know what you are looking for,the hot and cold of the seasons really mess up car electronics chances are its time to upgrade to a better amp spend the bucks you won't be dissapointed cheers and good luck
Jul 11, 2011 | Lanzar VIBE276 Car Audio Amplifier
Hello. I have a side by side refrigerator MSD25...
The answer to these questions lies in the way the freezer/fridge combo works. The freezer is where the cooling coils are located. Then air is moved over the coils and circulated through the fridge side by a small blower or fan. The problem arises when the air is not circulated for some reason.
The reasons the air is not moving is usually two reasons
The fan or blower has failed.
The coil is covered over with ice and blocks the air flow.
The first reason is pretty simple to fix, you simply replace the air circulator and things are good again.
The second reason can be more difficult.
1. The timing device that runs the defrost cycle of the refrigerator is defective.
2. The heater coil that melts the water is shorted or not working
Usually the first thing to check is the heater coil. If there is resistance through the coil then most likely it is still good.
The timing device can be an advanced defrost control board or a mechanical timing device.
If the heater coil checks out to be good then the problem should be the timer.
For most situations, unplugging the refrigerator and allowing it to defrost on it's own will get you going temporarily, till parts can be shipped to you. That will melt the ice and give you a few days or a couple of weeks till it ices up to the point where it will not work again.
So you can see here, the problem can usually be traced to one of three things.
The fan or blower
The timer device
The electric heater coil
By methodically checking these parts you can isolate your problem and fix it.
Take care....
Jun 24, 2011 | Maytag MSD2542VE Side by Side Refrigerator
RANGEMASTER FRIDGE /FREEZER WATER FILTER WARNING LIGHT
Hi i have a rangemaster s x s fridge freezer and the ice maker has stopped and now the whole fridge freezer has stopped. its 2 years old and out of warrenty can anyone help please with a suggestions as to whats wrong.
Sep 18, 2009 | GE PDS22LBN Bottom Freezer French Door...
Fridge freezer has stopped working
. The most common problem is a bad start relay on the compressor. In rare cases the compressor may be bad. If you are mechanically inclined you can replace the relay yourself for less than 50 dollars. You will need model and serial number off of the unit and order the part by those numbers. if the compressor is bad you will need to hire a good service company
Jul 01, 2009 | Hotpoint FFA70 Bottom Freezer Refrigerator
Watner dispenser gradually stopped working (slow flow to begin with)
you need to change the water filter, usually around $35.00.
May 23, 2009 | Maytag MSD2758GEW
Water stopped dispensing, still makes ice
Yes Teri, you can.
What has most likely stopped the water is that it has frozen in the line coming into the back of the freezer section. You simply need to turn the box off and do a good cleaning. during the time that the box is off, the water line will have time to thaw. Put everything back together, turn the box back on and give it a try.
May 25, 2008 | Amana SXD524VW Side by Side Refrigerator
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
