Question about Psi Blue Max 2200 High Pressure Gas Power Washer
Parts 25 feet of hose
What is the lineal ft of a counter top 25 ft long by 3 wide?
Lineal feet are straight line feet.
You answered your own question.
25 feet.
Square feet are the surface area.
25 feet X 3 feet are 75 square feet.
Apr 18, 2017 | Cars & Trucks
I AM LOOKING TO BUY A NEW REFRIGERATOR AND NEED TO KNOW THE CUBIC FEET OF KENMORE MODEL 106 59592990
25 cubic feet
Here is a link to the owner's manual:
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Refrigerator-Parts/user-manuals/manual-downloads/Model-10659592990/0582/0165000?modelNumber=10659592990&diagramPageId=&documentId=
Dec 01, 2014 | Kenmore Refrigerators
What is the cubic feet equal to 30" x 25" ?
You need three dimensions for a volume.
30 inches by 25 inches is 750 square inches or about 5.21 square feet.
Sep 14, 2014 | Office Equipment & Supplies
What is 25 linear feet in square feet
That depends on the length and width.
24 feet 11 inches by 1 inch is about 2.01 square feet.
24 feet by 1 feet is 25 square feet.
20 feet by 5 feet is 100 square feet.
12.5 feet by 12.5 feet is 156.25 square feet.
Sep 08, 2014 | Office Equipment & Supplies
What size hose can I use when vacuuming the pool If I use a Intex 4000 gallon pump on my 18' x 48" pool?
you can use the standard 2" hose. i would get one atleast 20-25 feet long though
May 20, 2010 | Intex 4000 GPH Filter Pump
The pressure in the tank is fine but the pressure at the output, even when the knob is opened all the way, is only 50 pounds.
how long is your hose ? you loose pressure if your hose is longer than 25 feet.the way to fix this and compensate for air loss is to raise tank pressure.first make sure there is no obstruction in the hose.
Jan 07, 2010 | Porter Cable 18 - Gauge Brad Nailer and...
I need the instruction manual for a Sears submersible pump model M4D02B-01. I would like to use it to pull water from a lake and about 25 feet in elevation. It is rated at 230 volts but I currently only...
Assuming that your Sears submersible pump Model
M4DO2B-01 can pump water at more than 25 feet
elevation. You can run it even without a manual. Just connect your discharge hose up to the point of discharge. Use a 220/110 volts transformer with a rating of at least 3KVA. Connect your 110 volt line to 110 outlet of the transformer and the submersible pump to 220 outlet of the transformer. This 3KVA transformer can handle up to 1HP pump.Send your
e-mail for further assistance.
Jul 07, 2009 | Plumbing
Spray gun question
For the most efficient use of the gun, always make a careful check that all parts are the proper size and type, and are in perfect working order before operating. The following items can serve as a checklist: Manifolds and Regulators: The CFM capacity should be at least one and one half (1.5) times the total capacity required by the equipment. A separate regulator should control the atomizing air and all gauges should be readable and in good working condition. Moisture and Oil Traps: In order to assure the least amount of contamination of the Gel coat, moisture and oil traps should be installed and drained daily (minimum) on all air lines at the spray booth. Traps must be installed on the lines at least 25 feet away from the air compressor. Quick Disconnects: Quick disconnects are not recommended for airless or high pressure systems, and may reduce the volume of air and fluids passing through them. If they are used, they should be the largest size available. Hoses: Hoses are used only for delivering air from a regulator on a main air line and fluids from the fluid pump to the gun. The standard hose length is 25 feet and should never exceed 50 feet. Hose capacity should match the volume delivery and pressure demanded by the gun when the trigger is pulled. Hoses must be capable of delivering the material at the volume and pressure rates dictated by the gun. There will always be a pressure drop from one end of the hose to the other.
Aug 27, 2008 | Badger Basket Starter Spray Gun Hobby Set
I ned a new hose 25 feet
Most repair shops have bulk hose, non-electric, that you can buy by the foot.
Apr 14, 2008 | Vacuums
Psi Blue Max 2200 High Pressure Gas Power Washer Logo
23 people viewed this question
Top Psi Garden Experts
John Trevino
fordexpert
Jay Finke
Jay Finke
Are you a Psi Garden Expert? Answer questions, earn points and help others
