Question about Sharp AR-M237 Copier
Cover door spring replacement
The spring popped off the upper right side cover door. How do I put it back? I have the spring. It is a Sharp Copier AR-M237. thanks!
    Guru:
  • Sharp Expert
  • 106 Answers
It helps to have a small tool called a spring hook. Other than that it will function if you tape the cover closed.
blog.equipmybiz.com
Posted on Jul 02, 2013
SOURCE: how do I change the drum on a Sharp AR-M237?
Hi, i assume you have a drum to replace it with?. Can't really clean them as they are very sensitive. Why does it need changing, your copy quality is effected?. It is a faily straight forward procedure.
Let me Know
Andy
Posted on Mar 04, 2008
  • 148 Answers
SOURCE: F2-02 error on Sharp AR-M237
on this code you may have to clean out the developing unit and start with fresh developer. Make sure the developer unit is not leaking from one of the bearings. You may need a tech for this one...
Posted on May 26, 2008
Bubbabear64
  • 2794 Answers
SOURCE: IP Address on a Sharp AR-M237
The easy way to do it is to set the copier up for AUTO DHCP.  That way the copier will connect to the router and assign a free IP address to the copier.
Then go into internet explorer and type in the ip address of the copier.  If you can get a control panel screen of the copier to appear.  It worked.
Once you get the IP address, take it off of AUTO DHCP and type in the IP address that the router assigned to the copier.
Posted on Oct 16, 2008
Sharp Tech
  • 63 Answers
SOURCE: Sharp AR-M237 EXPANSION MEMORY 8MB: AR-MM9 installation procedure
You are needing the installation manual for this. Please contact me so I can e-mail you the pages that you need. administrator@aokoffice.com
Posted on Oct 15, 2009
  • 17 Answers
SOURCE: my copier is SHARP AR-M237 will be to change the
your toner should be AR-270NT or AR-310NT. Try cleaning off the brass colored contacts in the plug on the back of the toner cartridge. The toner may also be faulty (try another) Also the contacts inside the copier may need to be cleaned by your copier technician.
Posted on Nov 21, 2009
Sharp AR-M550N close the upper left side cover
Close the lower left side cover error :
this problem is for under the left door
for fix this problem push the all part on left side
under the door is important
mehdi ebrahimi iran,karaj
Oct 19, 2012 | Sharp AR-M550N Copier
Sharp r520kst door won't stay shut
If the door will not stay closed it is the spring inside door, or the small plastic piece that holds the spring which is attached to the $80.00 piece called outer door.
To fix it, it is EASY and you do not have to even take the inside cover all the way off. Just remove the three sides of cover by gently slipping a plastic putty knife around rim to release the clips. Then attach the spring to the small hole below where the plastic piece used to be, which is located in the metal on the glass frame piece, use tweezers, hold the other end of spring as you place spring onto plastic door latch and set into place!
Snap the inside cover back on and YAY! FINI!
Aug 20, 2012 | Sharp Microwave Ovens
The mullion is broken in my Lg refrigerator
I have a related question. My lower spring broke and I have the replacement spring. How do I put it into both plastic fittings at the same time. One arm on the spring goes on mullion while the other arm goes into a fitting on the door. Please help!
Aug 15, 2012 | LG 4-door French Door Refrigerator...
Where do i find the drum in Cannon c3380
Open front cover on the upper right side there is a cover no screws just press down on the top of this cover whilst pulling and it will pop off, you will need to open the left door, now under the cover that you removed is a single screw remove this then do the same on the top right side of the copier. press in the black lock under the cover you removed this will enable you to turn the lever 180 degrees. this unlocks drum carriage, you can now slide carriage towards you as far as it will go. now press white button on top of carriage to open top cover, this will reveal the four drums(cyan,magenta,yellow and black) on each drum you will find a slide lock insure that this is in the open position before removing drum. and remember to lock when a new drum is inserted. (failure to do this will cause expensive damage to copier). reverse procedure to restore copier. there is no need to perform any setup procedure as a new drum will do this automatically, however its a good idea to run auto-gradation after replacement of drum/s.
Jan 18, 2012 | Canon C3380i Color Copier
Error code e007 on canon imagerunner 210s
that is code for damaged fixing film u will need a technician to replace the fixing film. or replace fixing unit( for that, open the front cover; open screw of down left side small cover, remove cover; detach connection on the upper left side.remove earthing screws and in the upper centre, fixing unit mounting screw. release feeder leaver oin right side.open left door, slide out fixing unit replace with a new one and revert whole process.)
Feb 07, 2011 | Canon imageRUNNER 210S Copier
My copier is showing CH what do i do to it
CH are in two forms steady and blinking CH. Steady CH is associated with door switch for either front cover or side cover. Make sure that the front cover and the right side cover are closed properly.Secondly, Blinking CH
is associated with the toner cartridge or the developer unit not being sensed by the machine. Make sure that the developer unit is well locked in the machine. Pull out the toner cartridge and insert back with some force into the machine, it should clear this sign. If it does not, replace a new cartridge Sharp AR016FT. Let me know if any further clarification/ assistance is required.
Good Luck!
Appreciate generously, if the solution could have been of any help!
CreativeTECH
Dec 22, 2010 | Sharp AR-5316 Advanced Digital Imager...
My sharp ar-5316e error code CH please help me
Hope you are fine, ch are in two forms steady one and the blinking ch.
Steady CH
This is associated with door switch for either front cover or side cover. Check that the front cover of the copier and the right side is well closed.
Blinking CH
This is associated with the toner cartridge or the developer unit not being sensed by the machine. Make sure that the developer unit is well locked in the machine. Pull out the toner cartridge and insert back with some force into the machine, it should clear this sign. If it does not, replace a new cartridge Sharp Ar016ft and you are done. Good luck.
Nov 23, 2010 | Sharp AR-5316 Advanced Digital Imager...
Cuisinart grind and brew pot - door holding filter pops open during grinding/brewing.
There is a little cover over a spring. The loops of the spring go inside the screw that holds the cover. The spring ends are against the wall and a small pin connected to the button on the side. Keeps the button locked. Cleaning out dried coffee in the are may help and pam spray may keep it from sticking.
Oct 26, 2010 | Cuisinart Grind and Brew 10 Cup Coffee...
Canon2018
Send the e-mail, and ill send it to you.
But shortly:
Remove left door on copier.( Remove plastic cover left from the door ( 3 screws ), disconnect the wires if you have duplex, unscrew the screw on black plastic tape, with pliers pull up the metal pin wich acts as upper hinge.)
When you removed the door, from left side beaneth the fixing assy you will see smal black cover with one screw, remove it so that you can disconnect the connector of fixing film assy, from the right side of fixing assy, remove the cover ( that is the cover wich is long and covers the door locking mechanism - two screws ) Disconnect the 3 conectors. Unscrew the scres that holds fixing assy left side and right side.
Pull towards the fixing assy.
Dismantle it how you see it, but you need to remove the green handle, and remove the axis that have on both side plastic pressure realese pins.
Pls. rate
May 13, 2010 | Canon Office Equipment & Supplies
Right-side cover will not close, springs are disconnected.
Normally the right cover hooks break off and causes the door not to close.There is square holes in front and back of the right cover that you can use to hook the spings again.
Apr 27, 2009 | Canon PC-920 Black and White Copier
Sharp AR-M237 Copier Logo
49 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
