Mod operation in fx-83gt plus
How to perform mod operation using fx-83gt plus calculator,, I used to do using the PC calculator which is very easy eg:10 MOD 19 = 10 I want to perform the same task using a calculator but I don't know how to do it please hlep
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Office Equip... Master
  • 102,366 Answers
Like many other Casio calculators, the fx-83GT Plus doesn't provide the modulus function. You have to do it the hard way.
To calculate 19 MOD 10 (which is 9, not 10 as you state in your question), first divide 19 by 10 and note the integer portion of the result (in this case, 1). Then subtract from 19 the product of 10 and the result of the first step. The result of the subtraction is the modulus. 19 - (1*10) = 9.
Posted on May 10, 2013
SOURCE: m mod n in Casio fx991MS
there is one button ab/c beneath CALC... if u want to calculate 7 mod 4 then... u should press 7 then ab/c 4 and equal to
1, 3 ,4 which is 4*1=4 and 7-4=3 remainder...
Posted on Jun 29, 2009
wilsonp195
  • 3 Answers
SOURCE: I am using FX-83GT calculator when I divide a few
Try using the S<>D(above the orange DEL button) button after you've obtained your result..
Posted on Aug 22, 2010
  • 3 Answers
SOURCE: hello there. I'm having some
try changing you calculator to Degrees it should be the original setting, this can be done usually by removing the batteries or hitting a clear all memory on calc and it should be set to degrees. The reason you are getting "0.4553" is because it is in the radian mode (usually seen as RAD) so easy fix its not your calc its just an operator error.
Posted on Dec 07, 2010
Testimonial: "tnks a lot! "
  • 102366 Answers
SOURCE: As the Casio FX-991es Plus got a modular function
It's a bit convoluted, and it only works for integers, but here's one way. Press MODE 4 to switch to BASE-N (integer) mode. If the screen doesn't read "Dec" then press the x^2 key. Now, to calculate a mod b, calculate a-a/b*b. No shortcuts, no rearranging. That's a minus a divided by b times b. You have to enter both numbers twice, but you will get the modulus.
Press MODE 1 to return to your previously scheduled calculations.
Posted on May 11, 2011
  • 7993 Answers
SOURCE: I have a casio fx-83gt
The computational mode of your calculator is set to VERIFY. Change it to the general COMPUTATIONAL mode. Press MODE 1 (COMP).
Posted on Jun 06, 2011
How to solve quadratic equation on fx-83gt plus
It will help to read the manual of the calculator. As you can see from the screen capture below, the FX-83 GT PLUS ( which has more features than the FX-83 GT( does not have a solve mode or an Equation mode. So, you cannot solve equations on the calculator.
May 24, 2014 | Office Equipment & Supplies
Can you do the highest common factor on an fx-83GT PLUS casio calculator
The calculator has no application that will find the highest common divisor (or HCF) but that should not be difficult to do by hand.
Decompose the first number in prime factors. If a prime factor is repeated use the exponent notation: That helps
Decompose the second number in prime factors too, using the exponent notation.
Now look at the two decompositions. If a prime factor is present in both decomposition it must be in the HCD /HCF, with the smallest of the two exponents. Do that for all prime factors
Example;
(2^5)*3*(5^4)(7^3)*11
(2^3)*(5^6)*(11^2)*7
The prime factors that are present in both decompositions are
2, 5, 7, and 11
From the two decompositions select the smallest power of each
2^3, 5^4, 7, 11
The highest common divisor/Highest common factor is
(2^3)*(5^4)*7*11
Mar 27, 2014 | Casio Office Equipment & Supplies
Is there a verify mode on the CASIO fx-991es plus calculator?
You should try to explore the calculator to find its capabilities. You can also read the manual. Everything is in it.
Press the Mode button, then the down arrow key. On the second page of the mode list you find 2:Verif
Mar 23, 2014 | Casio Brand New-Fx-991es Plus - Scientific...
Casio fx-83GT-plus how to convert binary to hexadecimal
Sorry to be the carrier of bad news but the Casio FX-83 GT Plus does not have a baseN calculation mode. You cannot do any arithmetic in binary, octal or hexadecimal numeration.
Oct 06, 2013 | Casio Office Equipment & Supplies
Casio fx-83GT plus how to convert binary to hex
I have just changed from using a Casio fx-83MS to a fx-83GT Plus. Is there a way of displaying a comma between every third whole number?
I do not think that Casio scientific calculators have the possibility to separate thousands, millions etc. The Sharp have that feature.
Sep 15, 2013 | Casio Office Equipment & Supplies
Casio fx-83GT PLUS gives wrong values for logs
Are you using the right type of logarithms? The calculator provides for two types: common (base 10) and natural (base e).
Could you post an example or two, with the answers you get and the expected answers?
Apr 15, 2013 | Casio FX83ES Scientific Calculator
Can't change from standard form on my casio fx-83gt plus
There is only one key to toggle between display formats: the S<>D key. Pressing the key repeatedly will cycle through all available display formats.
May 23, 2012 | Casio FX300WPlus Scientific Calculator
M mod n in Casio fx991MS
Jun 29, 2009 | Casio FX-115MS Plus Calculator
977 people viewed this question
jasbo
jasbo
