Question about Baby Gear
Polychem pc 102
The table strapper straps once or twice then it will not strap doesnt make a weld or nothing but you dont put anything in it will strap evertime
  • 6 Answers
SOURCE: relacing straps
try looking on the website
from the picture it looks like the eddie bauer 3 in 1 car seat
http://www.coscojuvenile.com/instructions/
here is the link for the web site, just imput your model or product code and you will be able to download the instruction manual
Posted on Nov 02, 2007
  • 5 Answers
SOURCE: Carsear Straps
I believe page 3 is what ur looking for. I have done this SOO many times, they get soo dirty soo quick!! Good luck and be safe!!
http://www.elitecarseats.com/assets/product_files/instructions/Eddie-Bauer/EddieBauer_3in1_manual.pdf
Posted on Nov 20, 2007
SOURCE: carseat harness straps
You have to unloop the straps from the gold metal bar. This will allow the straps to be free so you can feed them thru the holes and re-feed them into the proper height hold. You will than noticed that there are loops at the very end of the straps which you can loop back onto the gold metal bar.
Posted on Dec 01, 2007
  • 4 Answers
SOURCE: Putting carseat back together after washing..
Here's a manual:
http://www.coscojuvenile.com/usa/eng/DJGFiles/ProductDocuments/43583614D.pdf
Hope this helps!
Posted on Jul 01, 2009
  • 50 Answers
SOURCE: i need to put the shlder/lap strap back in
the center of the belt will be under the seat coming up through the holes, place the two clips on the strap followed by the chest clip, then the neck protector pads. Push the ends of the strap through the two top holes. Route it down over the metal but under the plastic (on the back side) and attach both ends to the metal adjuster underneath. The receiver clip, you just turn 90 degrees and push through desired hole until the end catches.
Posted on Jan 24, 2010
I have a Nixon Time Teller P Matte white watch , how do you get the discolouration out of the watches strap
take the strap off the watch and soak it for 10mins or more in "oxy" washing stain remover
dont take it back to the pool
if it doesnt work then contact the maker or look for a replacement strap ...
Jan 03, 2015 | Nixon The Time Teller P - One Size - Matte...
Changing the gas tank
Drive the gas out of it til near empty than underneth the vehicle will be two straps across the tank, unscrew the straps and its out but first disconnect the tanks hoses amd wires too.. you will need some sockets and a screwdriver.. Take your time and make sure you dont force anything in or out of place if it doesnt fit and requires unusual force you effed up somewhere
May 02, 2012 | 1999 Nissan Maxima
Rear gas tank strap bolt spin's but doesn't come out.
Bad news! Either threads are stripped, or where bolt screws in, the nut that is sometimes spot welded to hold bolt has come loose and is turning with your bolt. I would cut head off bolt, remove strap, and remove tank. Then you can see what you are dealing with. Use a little ingenuity to figure a way to make the strap hold good, when you put it back together. Good luck. If threads are stripped, and you don't want to have it tapped for new threads, try a smaller (high-grade) bolt with a nut to try and draw the strap up tight.
Oct 30, 2011 | 1999 Chevrolet Blazer
Changing gasoline pump but tank screws lose but dont come out , they keep turning..its a Bonneville 1995...does it have a bult on top...how do I take tank down??
The nuts on top are usually held with a weld, but not uncommon for them to break loose and spin. Should be 2 straps, and one bolt at one end of each. You may have to get wrench, or vise grips up in there to stop nut from turning. Lots of penetrating spray on them, they will probably be pretty rusted at the threads.
Dec 24, 2009 | 1995 Pontiac Bonneville
I have a 93 dodge dakota,i'm trying to find the ground strap.
on some it goes from motor to firewall or motor to the frame.. you have to have a good eye for it is easily overlooked...good luck
Nov 17, 2009 | 1993 Dodge Dakota
Graco nautilus 3 in 1 car seat need help with strap installation
Yeah its a bit tricky. ON the fron of the car seat there is a strap that goes intot he seat and has a button to lossen it. Press it down to lossen that strap then flip seat over and on the bottom you will find other end of the same strap and it has a brass t-fitting. Take it and pull it up the back side of seat and the shoulder straps fit into the brass fitting then tighten by pulling strap in front of chair.
HAve fun ;)
May 08, 2009 | Graco Nautilus 3-in 1 Car Seat
Ataching neck strap
Put the unit on a table with the eyepiece up. Put the small loop of the wrist strap through the place provided under the eyepiece. (small slot with a pin) Put the rest of the strap through the small loop and pull tight. That's it........
mtg
Jan 28, 2009 | Bushnell SCOUT 1000 Rangefinder
Garmin 405 pair to wrong HRM
I Have had the same problem couple of times (and forgotten each time how I solved it). I figured it out just now and this is what I did.
1) turn on unit and put on heart monitor (make sure battery is good and wet heart strap)
2) using the mode button navigate the menus to: Settings: General: Accessories: Heart Rate Monitor
3) Once in the Heart Rate Monitor option make sure "Yes" is selected and then use the arrow buttons to highlight "Restart Scan" . Press the enter button to rescan for your heart monitor. (I had to rescan twice)
Go back to the main monitor screen to see if you are recieving heart rate signals.
I am not sure why a manual rescan needs to be done every time but it would be nice if Garmin fixed this issues in a unit software update (my unit has software version 2.80)
Jan 04, 2009 | GPS
Directions
First put all the clips together and pull the whole thing over head till you get the hang of which straps go where. Than sit down on the a couch or a bed NO CHAIRS. Now you place your baby inside make sure the straps are loose I unclip one side or just the top once the baby is in and you secure the straps and clips and all of yours a set. Make sure the pastic peice in back is between your shoulder blades or you will have a lot of pain in your lower back. Now you stand slowly making sure nothing is sliding out or the baby is falling once all straps are secure and your comfortable with the placing you are ready to go.
Jan 13, 2008 | Infantino Bandana Baby Sling/Wrap
Baby Gear Logo
123 people viewed this question
Top Baby Gear Experts
Jennifer Rock
Jennifer Rock
Douglas Dinnebeil
Douglas Dinnebeil
Are you a Baby Gear Expert? Answer questions, earn points and help others
