Question about Philips 32PFL5332D 32 in. LCD Television
TV when you plug power cord to DCcurrent ; the fuseblows out;
    Top Expert:
  • Philips Master
  • 74,136 Answers
There is a direct short circuit be any of the internal circuit boards. The TV need a thorough checkup. If you wish to get more details, surf the following link. There are over two thousand and four hundred posts. All are related to television and other domestic electronic equipment service help. You can get a solution there. Type in the brand name to your device to its search box, can be located at the top right of the display window. It will make search easy. More than Nine Lakh viewers cannot be wrong.
Posted on May 11, 2013
HI NEED HELP? TV WONT TURN ON?
Unplug the power cord from your TV. Wait 30 seconds, then plug it back in. Plug the power cord into a different power outlet or power strip. If possible, try a different TV power cord.
Apr 13, 2017 | Televison & Video
Why wont my lg 50 plasma tv turn
Perhaps replace your power cord. Borrow power cord from repair shop. If it works it's the cord. Also if the TV is plugged into power bar make sure the power bar hasn't been inadvertently turned off.
Oct 07, 2015 | LG Televison & Video
Tv come with no sound or pict.
Check whether the product is turned on.
Try another channel. The problem may be with the broadcast.
Is the power cord inserted into wall power outlet?
Check your antenna direction and/or location.
Test the wall power outlet, plug another product's power cord into the outlet where the product's power cord was plugged in.
If these tips don't work, you can also try to power cycle the TV. Turn the TV off and unplug it for about a minute. Plug it back in and power it back on to reset the settings back to factory default.
Oct 18, 2013 | LG 32LG30 32 in. LCD HDTV
Fuse for power doorlock keep blowing when i push lock but not when i push unlock
You have a ground either in the switch or in the wire going to the lock solenoid.
when you push the button to unlock power goes thru the wire and the solenoid
then to ground on the other wire that is grounded. when you push the button to
unlock, power is reversed, and goes to the grounded wire then poof-- the fuse
blows.
Nov 08, 2012 | 1995-1997 Chevy 1500 Truck Ignition...
The power went off at my house due to an overload and when the breaker was turned back on, the tv had no power, no green or orange light. I unplugged the power cord and plugged it in later and the tv...
The power supply board is dead,that the board where the power cord plug into it.Take ur tv aparts,replaced the power supply board,ur tv should work again.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
May 23, 2010 | Vizio L32 32 in. LCD HDTV
My power cord fell off. Took off the back of the
there is a small board with a small transformer . the plug is located next to that small transformer. if the cord originally came from the right hand side if you are looking at tv from the back. the plug is on that right board. if the tv cord came from the left side, the plug is located on the main board in the front of tv. the plug in both situations are the same, it is white in color and has 2 or three pins sticking straight up.
Nov 15, 2009 | Sony KV-32FS13 TV
Can you help me find a pwer cord for my 32''flat screen (Proton)
Unless this set is really oddball, it probably has the same type power cord connector used on computers and so many other electronic appliances. If this is the case, you can use a standard computer power cord as a replacement. The computer cord is a three-wire plug with a ground pin and the TV probably only had a two-prong plug, but the cord will still fit. Your electric outlet should be the three-prong type (if it's not, get it replaced!) so the plug will fit.
If the connector in the set is really different, you can check online by doing a Google search for replacement parts for you TV.
Nov 21, 2008 | Proton MM2701VT 27" TV
Philips 32PFL5332D 32 in. LCD Television Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
