Question about Toshiba TDP-SP1 DLP Projector
Lamp reset reset lamp time
Reset lamp time
The lamp time is the time counted after the last resetting. It is shown in the OPTION menu as the usage time of the lamp. Pressing the RESET button on the remote control or the ? button of the projector displays a dialog. To reset the lamp time, select the RESET using the ? button. RESET ? CANCEL • Please reset the lamp time only when you have replaced the lamp, for a suitable indication about the lamp.
May 13, 2015 | Hitachi CP-X505 Projector
Replaced XD300U projector lamp. Need to know how to reset lamp timer. Won,t turn on because lamp timer has expired to 0. Needs to be reset. Lost our manual. Please help.
"Reset the lamp counter
i. Press and hold Exit on the projector
for 3 seconds to display the total used
lamp time.
ii. Press Menu on the projector or on
the remote control to access the lamp
hour timer. An adjustment message
will appear.
iii. Press or to reset lamp hours
and press EXIT to leave."
Apr 21, 2008 | Televison & Video
How to reset mitsubishi VLT-XD221LP projector lamp reset Kumar Salem
Reset of the lamp operation time
1,Connect with the Power cord, and turn the power on.
2,with a signal supplied to the projector.
3,Menu--INSTALLATION--LAMP TIME RESET-and press
ENTER button to reset lamp operation time.
any questions, feel free to contact me
We supply original projector lamp,bulb,accessories,Lcd panel,Lens,DMD chip,color wheel,motherboard,powersupply,ballast... with high quality and competitive price.
have a nice day!
Jerry,Lampdeng Limited
Oct 07, 2013 | Mitsubishi VLT-XD221LP Replacement Lamp...
I need to reset lamp timer
Here is the procedure for reseting the lamp.
It can be found at:
http://fixyourdlp.com/blog/wp-content/uploads/2007/09/panasonic-tyla1000-lamp-instructions.pdf
Be sure the power cord is plugged
into a properly grounded wall outlet.
Then, press the POWER button on the
projection display or the remote control
to turn the unit on.
Warning:
Perform lamp time reset only when the lamp has
been replaced.
When lamp time reset is finished, the LAMP indicator goes out.p re placement,z
While pressing the VOL- button on
the projection display, hold down the
PIP or SPLIT button on the remote
control at same time for more than
5 seconds.
LSQC0334 C
LAMP TIME WAS
RESET TO 0.
END
Apr 29, 2009 | Panasonic PT-43LC14 43" Rear Projection...
After replacing the lamp in an XD480U projector, what are the 2 buttons needed when pushing the power button, to reset the Interval of lamp replacement time? The buttons to choose from are: Auto position...
To reset the lamp operation time on a Mitsbishi XD480U:
Plug in the power cord, turn on the lamp, and press the Left Arrow button, Right Arrow button, and POWER buttons on the control panel ALL AT THE SAME TIME, holding them all down for about three seconds.
Notes:
•Unless these three buttons are pressed at the same time, the lamp operation time isn't reset.
• Make sure that the STATUS indicator is lit twice and the lamp operation time is reset successfully.
• The projector doesn't turn on if the lamp cover isn't attached securely.
• Be sure to reset the lamp operation time whenever you replace the lamp.
• Do not reset the lamp operation time unless you replace the lamp.
Dec 17, 2008 | Mitsubishi XD480U Multimedia Projector
What 2 buttons other than the Power button
Notes:
Indicator lights on, no function, no fan, no lamp
Press the MENU button to display the "MAIN MENU", and then select "OPTION".
Press the ENTER button to display the "OPTION" menu, and then select "LAMP RUNTIME".
Press and hold the ENTER button for approximately 3 seconds.
The "LAMP RUNTIME" will change to "TIME RESET [POWER OFF]".
Turn off the power and disconnect the power cord.
This will reset the cumulative usage time for the lamp unit to "0".
Oct 11, 2008 | Panasonic PT-LB20U Multimedia Projector
How to check for lamp life of my mitsubishi multimedia Projector xd 450u (DLP)
This should work:
How to reset the operation time meter
Plug in the power cord, switch on the projector, and
reset lamp time by pressing the (left and right arrow) and POWER buttons on the control panel simultaneously.
Important:
• If the 3 buttons was not pressed at the same time,
the lamp time may not be reset.
• Please confirm the TEMP indicator illuminates
about 2 seconds and the lamp time has been
reset.
• The projector will not turn on if you do not secure
the lamp lid.
• You must reset the operation time meter after you
replace the lamp.
• Do not reset the operation time meter unless the
lamp has been replaced.
Jul 14, 2008 | Office Equipment & Supplies
Directions for lamp time reset
Lamp Time Reset Procedure:
Be sure to reset the Lamp time to "0" after replacing the new
Lamp.
1. Plug in the AC Cord, and turn on the power by pressing the
POWER button.
2. Press and hold the VOLUME DOWN button on the unit and
the SPLIT key on the remote together for over 5 seconds
in power on condition.
When the reset is finished, the display will indicate that the lamp hrs have been reset to 0 and the LAMP LED goes out.
Jun 17, 2008 | Panasonic PT-61LCX65 61" Rear Projection...
Replaced lamp, reset LCD - still displaying replace lamp
You must normally use the remote control to reset the lamp time. If you do that through the menu options and reset lamp hours, it should be OK.
Mar 24, 2008 | Sony VPL PX11 Multimedia Projector
Toshiba TDP-SP1 DLP Projector Logo
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
