Question about Flotec Pump FP4032-10MK
Not putting out enough pressure or flow to pop up sprinkler heads
I have a multizone sprinkler system with 4 heads per zone. I pump from a lake with water level about 10 to 15 ft below the pump inlet. I just got a new shallow well FP4032 and plumbed it in and it pumps water just fine, just not enough at any pressure to pop up the sprinklers. They just bubble water in the ground. Is there a way to increase the pressure and/or flow to correct this problem? Or do I need a different pump, like a sprinkler pump. I do not have a pressure gauge on the line, so I am not sure what pressure it is putting out. Thanks, Don
    New Friend:
  • 11 Answers
Have you fixed this problem?
Q? Did you replace an existing pump. And what was the model and did it work.
Q? If its the same size as the fp4032, has anything else changed? Is there a filter that needs checking.
hydraulically to work it out I need the distance from pump to water, height and size of pipe. Distance you are pumping too, height and size of pipe. And what the "four heads are"? Nozzle size etc. To work out a flow/pressure rate.
Posted on Jun 11, 2013
Healeyman
  • 1198 Answers
SOURCE: shallow well pump made by wayne well is 22 feet deep pump runs no
Inspect the jet thru the suction pipe or the removable plug if the pipe isn't inline with the center of the impeller. The jet is very small, and easy to get something stuck in there. Then prime and leave the pressure pipe closest to the outlet slightly loose to let air out. Once you get good pressure you can tighten the pipe. Sometimes you have to prime more than once to get all the air out of the well pipe.
Posted on Apr 05, 2009
SOURCE: Watering system pump cycling off and on rapidly. .
Still need help. No responses!
Posted on Jun 30, 2009
2coolrick
  • 560 Answers
SOURCE: I have a FP 4022-10...it is relatively new but
If you can meet your needs with the pressure you have now, reduce the pressure cut off switch pressure until it shuts off. Your housing is probabbly sealed to the motor. Try shocking it with a rubber mallet to break the seal.
Posted on Jun 03, 2010
packrat1948
  • 528 Answers
SOURCE: I have a flotec 1
I am going to take a stab at this it sounds like the bladder has gone bad it the expantion tank. Try letting some air out of the bladder tank and see if you get any water if you do then the bladder has gone bad the tank will need replaced. After the replacement turn the limit switch back to normal settings. You can also tap on the tank to see if it is full of water.
Posted on Feb 09, 2011
  • 520 Answers
SOURCE: Just completed installation of new
i believe you have it wired wrong, i dont have enough info here to tell you what you did wrong. look at your instructions again and double check everything. you may have damaged the pump motor. basic wire hook up is black to black and white to white and green to a ground. black is your hot (load)
white is your neutral. thats about all i can tell you from the info you gave
Posted on Feb 21, 2011
My sprinkler head is stuck spaying in one spot and I can't figure out how to adjust the range and distance of it.
Sounds like you have a bucket impact sprinkler. These are problematic as they tend to beat themselves into non-operation from the moving parts involved and the impacts. They stop turning for a number of reasons, low water pressure, dirt and debris filling the bucket impeding rotation, plants covering the sprinkler etc. If no debris is found and others continue to work on same zone the water pressure is probably unchanged it may just be tired. I suggest replacing it using a pop-up rotor preferably a Hunter PGP-ADJ or PGJ-ADJ Rotor as rotors have only 1 moving part a gear which is sealed inside the sprinkler making them very dependable.
May 14, 2014 | Orbit Sprinkler System Super-jet 3-inch...
One zone has low pressure
Try getting information from the manufacturer.
Apr 12, 2014 | Garden
Sprinkler system pump pressure too high?
You just need to make better glue joints in the plastic pipe.
Use blue glue. It has primer built in and is one step. If you are using clear PVC cement and no primer it will not bond.
If you use purple primer and clear cement you need to put the cement on over the primer while it is still wet. If you allow the primer to dry it makes it worse.
Dec 30, 2017 | Water Source Plumbing
Not enough flow and pressure to run sprinkler system
pressure in centrifugal pumps depends on the number of impellers in the pump housing, the clearance of the impellers to the housing and the power of the motor to drive the impeller/s
volume flow is also important as a pump without a high output will not produce pressure
check the jet size at the foot valve that is used to help lift water to the pump
It is a jet pump and will have a smaller line back to the foot valve for that purpose
next wil jet pumps if there is too much flow to the outlet , the pressure required to help lift the water to the pump is reduced and the volume is also reduced
you indicate 4 sprinkler heads per zone but how many zones are operating at one time
check the expected delivered volume for the new pump against delivered volume of the old pump as a starter to find the reason for the poor performance of the new pump
check also the rpms of each pump as that also has a bearing on volume produced
Mar 26, 2017 | Flotec Pump FP4032-10MK
Can you use a draper submersible pump for a garden irrigation system to use with several sprinklers, does it provide enough water pressure on the outlet?
Here's how to tell.
Connect a tee to the outlet of the pump.
Install a pressure gauge in the tee.
Install a valve after the gauge.
Open the valve and start the pump.
Once water flows, close the valve slowly until you get 50 psi on the gauge.
Have a 5 gallon bucket nearby and measure how long it takes to fill the bucket at 50 psi.
If it fills the bucket in 30 seconds, you can attach heads to the pump that combined consume 10 gallons per minute.
Let me know how you do.
Gary
May 29, 2011 | Garden
I have low water pressure on my rainbird sprinkler system. how can i adjust it?
There are several ways to adjust water pressure on sprinkler systems. First you have to determine if there is a problem with the sprinkler system itself. Things to look for:
1.) make sure that all valves including the main are all the way open.
2.) Inspect the sprinkler heads for clogging. Sediment and debris can also clog your sprinkler heads. Some debris removal may be required.
3.) You make have too many sprinklers operating by one valve. You may need to divide a zone and add another valve to increase water pressure.
4.) If all else fails. You can install a breather intake cap to allow air into your sprinkler system thus increasing GPM (gallon per minute)flow.
5.) one of the biggest mistakes that peopel make is that they undersize the water pipe size to save money. Typically you want to use 3/4" PVC pipe for your main runs and tee into 1/2" PVC for your sprinkler heads.
Good luck. I hope this helps.
Jul 20, 2010 | Rain Bird Hardware & Accessories
I have a FP 4022-10...it is relatively new but will not generate enough pressure to actuate power cutoff, so the pump runs till I unplug it. I have verified that the line to the lake is clear (water...
Jun 03, 2010 | Flotec Corrosion Resistant Shallow Well...
I have 1 and 1/2 horsepower sprinkler pump that wont prime. As soon as the end piece fills, it will empty if I open the end to the sprinkler.
I don't know what is your system set up. However, the system set up should be the following;
1. Your 1-1/2HP sprinkler pump must be installed at
a fix location nearest the water source. (Complete
with power and plumbing lines.)
2. At the end of the suction line is a vertical check
valve with strainer.
3. The suction pipeline must be connected to the
suction port of the pump.
4. At the discharge port, a flow control valve tee must
be installed. The flow control valve tee top is
covered with a plug, which serves as the priming
port when opened.
5. After the flow control valve, connect a short nipple
so that you can put a gate valve to stop the water
flow or allow the water to flow. You may connect
a pressure tank at this point or you may connect
the pressure hose going to the sprinkler.
6. To prime the pump, open the plug at the flow
control top. Fill it full with water, replace the
priming port plug.
7. Turn the flow control valve to full closed position.
8. From full close position, switch the power on.
9. The pump now run on and off due the pressure
switch setting. Slowly open the flow control valve
such that the water pressure remains steady.
10. Take note of the pressure.
11. Shut the power off, and connect the sprinkler
pump hose.
12. Put the power back on, and allow the pump to
run with the sprinkler.
Under this set up, you can run the sprinklers when your pump is running. Hope this will solve problem.
Dec 08, 2009 | Plumbing
Sprinkler head does not spray water
Make sure when you pull the head to ck the screen you turn the system on and blow out the line, then run a hose through the head to make sure it isn't plugged up anyway. Depending on the head and the cost of a new one will dictate cleaning or replacement.
Oct 04, 2009 | Garden
Flotec Pump FP4032-10MK Logo
129 people viewed this question
Top Flotec Plumbing Experts
john h
Andrew Bugbee
Are you a Flotec Plumbing Expert? Answer questions, earn points and help others
