Question about NetGear Computers & Internet
Frontier Modem Router
I just got my frontier router in the mail today and it connects to my computer when i have it plugged up to it but i cant get the wifi to work.
  • NetGear Master
  • 2,219 Answers
You need to set up the Wi-Fi on both the router and the PC.
It will default to the Ethernet connection, so don't forget to remove the cable if testing for wireless mode.
Posted on Mar 09, 2015
  • 556 Answers
SOURCE: DSL modem and Linksys Wireless Router not working together anymore
if i were to guess you are probably a PPPoE user with a dynamic IP address.
possible config
Posted on Dec 18, 2007
  • 49 Answers
SOURCE: cant connect router & dsl modem, cant aquire ip address
Try typing another website on the address bar.
Try checking on your router advaced setting make sure that Mac filtering is off under network filter.
Make sure all other settting on the advaced setting are also in default setting.
Posted on Jan 10, 2009
SOURCE: D-Link Wireless Router WBR-1310, Version A1
I had the same problem.
Make sure you turn off all the security with the software in package then slowly turn it all back on, on piece at a time. For whatever reason, it comes with MAC address filtering already turned on, which makes it impossible to see if you don't have the right info put in to the computer that the router was configured with.
Posted on Feb 27, 2009
gurutim
  • 68 Answers
SOURCE: Dlink WBR 1310 not connecting to a MAC(Apple) network
With power on, push & HOLD reset button on rear of router for at least 10 secs - then release. UNplug power to the cable modem while you're doing all this. Then, plug power to modem back in, and try router connect to computer again.
Please let me know - and if you wouldn't mind, please take the time to rate my response to you.
Thank you and good luck.
gurutim
Posted on Mar 22, 2009
  • 476 Answers
SOURCE: Cannot connect my Dell Inspiron 1012 to my wireless router
what model of DLink do you have and what operating system are you using?
I have a sample of a router set up in my tips and tricks I think youll find very helpful,
http://www.fixya.com/support/r4582466-set_up_speed_touch_5x6v6_broadband_modem
or
try download the info you need from
www.dlink.co.nz
www.dlink.com
its not going to be to hard to fix,
have you tried running a network wizard setup yet?
Hope this helps,MISTERDJ
Posted on May 27, 2010
Frontier dsl modem settings
Is the XP machine on SP3? If not, install the updates. Can you at least see the wireless network? Are the router and the PC using the same type of wireless? (I imagine your new router is Wireless N and your old PC is running B or G)
Oct 31, 2013 | Computers & Internet
I lost my land line service after installing a netgear modem/router to my network with frontier internet and phone package.
Frontier has to install a device at the interface to allow sharing of your land line and your computer. I had the same problem with Verizon until they made a service call and fixed it
Jan 23, 2013 | NetGear Computers & Internet
I have frontier services with a net gear modem/router i was told by xbox live to get a d-link router an it would help my problem with running 2 xbox 360 with no lag whats so ever but dont know what im...
well, unless the D-link is also a modem/router, I don't see how ADDING the D-link router to a lagging network will reduce said lag. They probably wanted you to REPLACE the current router with that one.....
will "frontier service" allow that router to be set in a "modem-only" setting ? You'll have to get with them on that. as for the D-link, there are manuals as well as an Online Emulator that simulates the Router interface so you can see how to set it up....BEFORE you set it up !
[PS: tracking-down lag problems can be tricky....you should be experiencing bad lag with all sites for it to be your hardware....
Tallon41
Sep 05, 2012 | D-Link DIR-665 Xtreme N 450 Gigabit Router...
Frontier decided our router was the problem after repeatedly losing our DSL connection on home computer. Modem tested fine, and works fine when used directly with computer. But router isn't that old, and...
The fastest way to confirm this is to buy a new router and see if you have the same issues. If you continue to have the same issues, you may need to have your ISP come out and check the wiring in your house. If the issue goes away, then I would keep the new router in place.
Thank you.
Feb 01, 2011 | Linksys Wireless-G WRT54G Router
I can connect to the router on both of my computers and my ps3 but i cant connect to ther internet. also if i plug my modem into the router and then plug my computer into the router i cant connect that...
I think you will need to reconfigure the router.
You can access the Internet when you connect the computer to the modem. That means the modem is working fine.
Connect the modem to the Internet port on the router and computer to port 1 on the router. Press and hold the reset button on the rotuer for 30 seconds. Release the reset button and wait for 30 seconds. Power cycle the router and reconfigure it.
Follow this link to reconfigure the router.
Jan 17, 2011 | Linksys Wireless-G WRT54GS Router...
My router won't establish an internet connection to my new network (Frontier)
re you trying to set up the router.
You can do it manually without the CD.
Make sure that your computer is able to go online through the modem.
If your computer is not able to go online through the modem then you will need to call ISP first.
If your computer is able to go online through the modem
then you need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for step by step by instructions
Jul 20, 2010 | Linksys Wireless-G WRT54G Router
Actiontec GT 704 WG Verizon to Frontier
You will have to contact Frontier and give them the Mac address of the equipment and they will tell you if it will work or not ( and they will also need to put it in their system)
May 28, 2009 | Actiontec GT704WG Wireless Router...
Security code
if you are using a siemens 4100 modem alone.. siemens 4100 modem has no wireless capabilty unless there is a wireless router plugged in..
if you already have a wireless router.. the SECURITY CODE shud be provided by your wireless provider
REMEMBER: SIEMENS SPEEDSTREAM is not wireless capable
Jun 26, 2008 | Siemens SpeedStream Modem (4100) (SS4100)
I have a DSL router provided by frontier. I am trying to make my desktop wireless. I believe that my DSL router functions as a modem also. I purchased a Linksys wireless broadband router. I can't not...
Your router should just be that, a router. Your connection is probably like fibernet the modem is actually on the outside of the house. This may help or may not but I have a linksys wired router that works very well but you have to go to their website in order to set up the router. You may need to look through your papers and find the web address to connect to the right site.
Apr 17, 2008 | Computers & Internet
Speedstream 6520 wireless gateway not working
I deal with these routers on a daily basis w/ Frontier. Likley the radio is getting hott and its starting to burn out.. Put your hand on the radio, see if its running rather hott. If it is, unplugg it for an hour. If your a frontier customer, call tech support, get it replaced!
Nov 11, 2007 | Computers & Internet
Computers & Internet Logo
115 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
