Question about Sony Ericsson Xperia Arc S LT18i
Loosing mobile I loose my mobile xperia arc S LT1 8i,I just want to block so no one can use anymoore please help me.
How to see tamil email
Do a search for a Tamil font for android. I believe this is one:
https://play.google.com/store/apps/details?id=com.KM.TF.DN&hl=en
Oct 09, 2016 | Sony Ericsson Xperia Arc Xperia Arc LT15i...
I trun off the mobile then i turn on it, the screen was SONY after that becomes XPERIA and still . help :(
Can you try to perform a software/firmwware repair using PC Companion to see if ot helps.
Connect your phone to the PC via the USB cable
The repair option on PC Companion (Support Zone --> Update --> Repair).
http://www.sonyericsson.com/cws/support/mobilephones/downloads/subject/pccompanion/xperiaarc?cc=au&l...
Please backup your phone data and settings before proceeding.
If it is NOT TURNING ON,.. PLEASE try:
1.Go to PC companion -> Sony Update Service and select phone update without connecting your phone.
2. Select your device and download the update (DONOT CONNECT PHONE)
3. When the download completes it will prompt for connecting you phone.
4. Before that phone must be switched OFF (donot turn on).
JUST PRESS DOWN THE VOLUME DOWN KEY AND CONNECT THE USB CABLE.
5. The Phone's LED will glow green and the update for phone will start.
6. After the update completes you will get the phone as an fresh new Operating System.
(WARNING - YOU WILL LOOSE ALL YOUR DATAS AND GET A FRESH START)
Jun 16, 2015 | Sony Ericsson Xperia Arc S
Connect mobile usb
You will need some software to make your PC a device that connects to the Internet, or local hotspots and a plan from your wireless provider to use it.
Oct 31, 2013 | Sony Ericsson Xperia Arc S LT18i
My sony ericsson xperia arc s lt15i is restarting continuously after trun on bluetooth how can i solve this?
Looks like your bluetooth apps might be causing the issue. Try to reset to factory settings. You will loose everything but it "might " solve the problem. If not, then it's the bluetooth module who's dead.
Cheers
Oct 19, 2013 | Cell Phones
Arc s xperia can not end the call
There is a small pointer in the front side of your phone (looks like front camera,but its actually not :-( ). This is actually proximity sensor. While you are on call and talking without headphone, it senses the distance between phone and your ear, and quickly disables the screen light with a black screen. It saves battery and also avoids unnecessary touch of your skin while on call. Please make sure theres nothing (phone cover) is blocking that sensor point.
If anything permanently blocking the censor it will never allow you to operate the phone while on call.
Good luck.
Aritra
Feb 27, 2013 | Sony Ericsson Xperia Arc S
Un plug the charger set off
the charger could be faulty,
the arc xperia has a known fault the logic board inside dies, the way around this is to call up the company you got your mobile phone from and see if they can replace it.
Aug 18, 2012 | Sony Ericsson Xperia Lt15i Arc Lcd Screen...
Forgot my password to get into my sony ericsson lt18i
my phone model : sony ericsson xperia lt18i arc s white i am forget password.i want to give soft reset.
Jul 11, 2012 | Sony Ericsson Xperia Arc S LT18i
Terminal Block
terminal was loose started arcing like a welder causing heat to melt the block
Apr 09, 2010 | Ovens
Sony Ericsson Xperia Arc S LT18i Logo
69 people viewed this question
Top Sony Computers & Internet Experts
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
