Question about Stanley Professional Backpack Poly 4-Gallon Sprayer #61804
Parts sprayer stanley
When i try to pump-up stanley 4gal pro sprayer it will not build up any persure and bubbles come out of the bottom of the bottle in side the tank. how can i fix this
    New Friend:
I would like the answer yo that question
Posted on Aug 03, 2013
2 Suggested Answers
  • 438 Answers
SOURCE: Stanley 61804N Professional Backpack Poly
Doc,
Yes, please replace the seal.
Posted on Mar 05, 2011
I put a new diaphram in the pump and now the pump handle doesn't pump on the proper time of the stroke. It is like it is pumping on the backstroke.How do I get the proper timing back
Hi Donald
Not knowing the details of your pump I can only start by asking one question....
Is it possible to install the new diaphragm upside down?
Reply as a comment to this post to let me know what you find.
Cheers
Feb 26, 2016 | Solo 475 - 4Gal Backpack Sprayer
Ring doesnt keep air
Put some Ivory dish soap, about a tablespoon, in a quart bottle with a sprayer, and fill the ring with air.
Then start spraying the soap solution all over that ring. When you see "Bubbles" appearing, that is where the leak is. Patch it. Fill with air & repeat. If no more bubbles, you have fixed it.
Apr 06, 2014 | Intex Easy Set Pool 15x36
I need a new rubber seal for the plunger piston on my stanley backpack sprayer. Where can I get one of these? Is there a web site for ordering these parts?
Drive out to the country side and look for a ACE or TrueValue hardware store. Bring your sprayer with you. They will likely have the right part for you in stock.
Sep 09, 2011 | Stanley Professional Backpack Poly...
My sprayer is new, but does not keep the pressure, any idea's? It's a 2 gal, pump up type sprayer.
Check under the lid/cover for a rubber gasket. This may have gotten unseated when putting the sprayer top on. It must form a tight seal around the lip of the sprayer top in order to keep the pressure. Alternative: Put water in the sprayer leaving some air on top to build pressure. Put a few drops of dish soap inside and gently stir. Put the cover on, and tilt the sprayer to coat all areas at the top. Start pumping and see where the bubbles come out---there is your leak. If it is near where the sprayer hose enters, and it is a permanent mount, you may have a bad seal. If the sprayer hose unscrews, you may need a new rubber washer inside. If bubbles come out of the wand, or other plastic seams, you may have a crack in the plastic. Depending on the location, you could epoxy over the crack to seal it permanently. Good luck.
Aug 11, 2011 | Roundup 2 Gallon Pro Garden Poly Tank Pump...
My ChapinSpray N Go sprayer won't build air pressure in the tank when I pump the sprayer
Sounds like a faulty seal to me. Submerge the container in water and pump, bubbles will rise from the seal. Easy to fix, I had a look and you can pick up a seal replacement kit for this model at Amazon.com for under $12.00. You should also find them at any reperitable hardware store. Hope this helps :)
Feb 03, 2011 | Chapin 2 Gallon Spray N Go Pump Free...
I have a Stanly backpack sprayer pro 61804n and need a repair manual. Were could I find one. Thank You, Chuck
The picture looks a lot like a Solo sprayer I have. I wouldn't be surprised if Solo made them for Stanley. Do a search for Solo sprayers. They have a site. My sprayer is a Solo 425
Jun 21, 2010 | Stanley Professional Backpack Poly...
MY STANLEY 61804 DOES NOT PUMP. THE PUMP HANDLE JUST POPS STRAIGHT DOWN EVERY TIME i TRY TO PUMP IT. ONLY USED 3 X. wHATS THE PROBLEM ???
the darker Seal has come off the plunger at the bottom of the unit , easy 5 min fix , just unscrew the allen keys at the bootonm take off the cover and remove the plunger , you'll see the plunger seal still inside you can fish it out with an allen key or similar tool clip it on again and reassemble
Oct 29, 2009 | Stanley Professional Backpack Poly...
Stanley Professional Backpack Poly 4-Gallon Sprayer #61804 Logo
502 people viewed this question
Top Stanley Garden Experts
Dennis Key
Dennis Key
Jim Goldsmith
Jim Goldsmith
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Stanley Garden Expert? Answer questions, earn points and help others
