Question about Hayward Pool & Spa
Changed from model B227se to UST1072 and having issues
The old pool motor for a hayward superpump model#B227SE serial #bx3-18 with a rectangle housing seized up. so i am replacing with a AOsmith UST1072. Both 3/4 hp motors. every site says this is the proper motor swap. but i replaced everything and now when i hit the power switch, it hums and i have to tap it with a mallet to get it to start. Cant hardly believe the capacity would be bad brand new out of the box. Also when it does start, you can hear the metal piece (i think its called a centrifugal)in the back of the motor click against a white plastic piece that is connected to 2 thin copper pieces that touch when the white plastic piece moves up. And it ran for about 1 sec without water in the trap (because it sucked it all out) and it started to smoke a little. its not seized up or anything and there are no obstructions to keep it from turning properly. Didn't know what else to do. any help would be greatly appreciated. ive looked everywhere thanks
  • 1 more comment
  • shamrock24 May 13, 2013
    after going out and purchasing a Multimeter and checking the volatage going to the motor from the wall switch and it is 220v. But my the issue is that there is a black plastic bolt that you can move up or down and it will say either 115v or 230v. and when it is on 115v it will at least attempt to do something, but on 220v setting it just sets there and does nothing. I have taken pictures of the old motor and new motor and do not know if it is wired up for 220v. the directions on the actual motor are VERY vague.
  • shamrock24 May 15, 2013
    well i'm giving up, having a pool company come over to check it out. noticed that nothing on here was much help. But thanks for trying. Ill let everyone know what the deal was when i find out in case anyone else has the same issue
  • shamrock24 May 22, 2013
    called the pool company and they said the new motor was bad....so awaiting a new motor and hopefully this is the issue
    New Friend:
  • 77 Answers
Check your supply voltage. Most new ao smiths come prewired for 220v. If you are running 120 volt supply, There will be a problem in motor starting. It will make unusual noise and most likely shut down shortly.
Posted on May 11, 2013
  • shamrock24 May 11, 2013
    i had a feeling that this would be the issue. i am running 120v. I have only ran the motor for about 3 seconds continuously because i'm afraid of burning the motor up. (no water in the pool currently)I know it is supposed to say on the label how to switch over to the 120v, but the only thing i can make any sense of is there is a plastic bolt that i have to switch from 220v to 120v....would you know if i have to do any rewiring? thank you very much for the response
  • 198 Answers
SOURCE: 1 HP electric motor hums but not turning.
check for a re-set button somewhere on the motor housing.
Posted on May 04, 2010
smartr10U
  • 1305 Answers
SOURCE: HAYWARD SUPERPUMP SHUT OFF PUMP TO BUMP EC65 D. E.
There may debris that has passed by the strainer basket and jammed the pump. I've personally got the world's worse pool... it's right next to a deadora tree with small pine type needles...they always get by the strainer basket and sometimes lodge in the pump.
To remedy the this, I take the protective cap off the exposed end of the motor and turn the shaft back and forth with a crescent wrench.
This frees the shaft up, then turn the switch on. You may need to do this a few times.
Also, with the pump off, remove the strainer and reach into the intake and see if anything is lodged in the opening... feel around with your finger to see if you can feel any debris.
If this doesn't solve it, you'll need to unbolt the motor with the pump impeller free from the basket housing. Once free clean the intake and surrounding area of all debris.
Being careful with the o-rings, reinstall. that should get you up and running...
let me know how it goes...
K
Posted on Jul 10, 2009
john224
  • 1378 Answers
SOURCE: Low/High Switch wiring for Hayward Superpump
I do not read anywhere that you have a 230V DPDT switch which you will need in order to select the high or low speed. You will have 6 terminalas on the switch. Line connections usually go to the middle set. Put put sides of one pole to the common terminal and put one of the other posts to the hi and the other to the low terminal. I prefer to use am on-off-on switch so the switch in the middle turns off the pump. Flip it one way for hi and the other for low. If you post your stock number from the two-speed motor I could give you a more accurate diagram if you need it. Generally, 1 is common, 2 hi and 3/4 low.
Posted on Apr 26, 2010
  • 8404 Answers
SOURCE: A. O. Smith 1 1/2 hp. motor Type SP. Humms then
You have a failing start/run capacitor. Take the motor to your pool supply place for repair.
Posted on Aug 04, 2010
  • 640 Answers
SOURCE: Model SP15921TLNP 1HP pool pump.
Are you sure it has a capacitor. I say this because capacitance motors tend to be fan motors. If there is an integral capacitor you should be able to find its size on the label plate for the motor.
Most motors are not capacitance though.
Posted on Jul 08, 2011
Overheating hayward super pump
Superpumps have been a workhorse in the industry for decades. Your results are highly unusual. The motors that run these pumps have bee manufactured by Century/Magnetek and A.O. Smith for the past 20+ years. These same motors power the vast majority of pumps built by a wide range of pool pump manufacturers. (They are not Hayward specific)
You may want to get a second opinion from another electrician, or call out a pool pro to check out the installation to see what could be causing these frequent failures. This is WAY abnormal.
Jul 03, 2013 | Pool & Spa
My Hayward superpump has a crack in the pump filter basket housing. I cannot afford to replace my pump at this time. Is there a patch or epoxy that will seal the crack? Hopeful!!
I would recommend a product called "Pool Putty". We use it all the time for quick repairs at my pool company. It is a 2-part epoxy that hardens like concrete. It might get you through the rest of the season.
Jun 15, 2011 | Hayward EC-40 DE Pool Filter with pump
On the haywood superpump model c48l2n134b1 i have 2 wires to wire on L1an L2 witch wire goes were
Either wire can go to either line as long as it is only one line lead to each post. Rotation is fixed and unlike a three-phase motor, reversing the two wires does NOT reverse the motor rotation.
John
Dec 07, 2010 | Hayward Super Pump 1 1/2 - Hp for In...
I just installed a New 1 hp Hayward Super Pump. The electrical service is a 20amp GFCI breaker> Old pump was a plug in connection, re-used the existing wiring. I changed the internal connection on the...
I see what you said ... still I want to say the following: It is to your benefit to keep the motor at 220 VAC ... Since you want to run it on 120 (I presume the motor is internally wired for 120 now - right?) did you change the white wire in your pannel to the neutral bus making the line 120? Also check the motor that it is wired for 120. It sounds to me like you did the line but not the load.
If the line and the load are both correct the next thing to check would be the start capacitor. It should be good since this is a new motor ... but it is not running. Have it checked.
May 24, 2010 | Hayward SUPERPUMP 2.0 HP, 115/230V
How do i take apart a hayward superpump 115/230V serial number c48l2n134b1?
i have a hayward 3/4 hp model c48l2n134b1 motor when i turn it on runs fine heats up and shuts off smells like somthing is burning
May 22, 2010 | Hayward SUPERPUMP 2.0 HP, 115/230V
Two hot wires one ground
I'm wondering...you say 120v on white, I want you to check 'between' the white and black for 120 volts. I think you may have 240 volts. Check it...
Jul 22, 2009 | Hayward SUPERPUMP 2.0 HP, 115/230V
Wiring Hayward pool pump
John what you have is a 240 volt motor on that pump. It will not connect to a 120 volt cord. You'll have to get a different pump.
Sirwriter
May 15, 2009 | Hayward SUPERPUMP 2.0 HP, 115/230V
My hayward superpump for the pool in leaking
normally this is not a crack in the housing. It is usually a shaft seal.
David
May 14, 2009 | Hayward 3/4hp Super Pump Inground Pool...
Pool & Spa Logo
102 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
