Question about HP 15.6" Compaq Presario CQ58-A10NR Laptop PC with AMD E1-1200
I think I have a virus
I was going to download the latest minecraft snapshot and launcher from www.minecraftforumn.com, and it started to download,then it rerouted me to lesstabs.com some survey, so I promptly closed google chrome, it crashed and said chrome cannot be closed while downloading so I made it stop downloading. I went to open "MnecraftDev" the snapshot and them Microsoft windows stopped responding. Then my computer restarted and started to turn on, stayed on the loading screen for like 20 minutes then said something like preparing automatic repairs, or something. Then went to a lit up black screen. I have Mcafee Security and it didn't warn me of a problem
  • 25 more comments
  • Hank Jenkins May 11, 2013
    It won't turn n, how do I boot into safe mode?
  • max carson
    max carson May 11, 2013
    This will help:http://windows.microsoft.com/en-us/windo...
    So I've tried booting in safe mode a couple times now, if goes into automatic repair and then just illuminated black screen
  • max carson
    First unplug, remove battery, leave battery out, plug in, try the Safe Mode with Networking. If it fails, unplug, repeat, it's important to unplug after each attempt. Plug in, with one hand/finger push the on button, with the other, immediately start tapping F-8 repeatedly until you get to the menu, select SAFE MODE with NETWORKING. Post results.
  • Hank Jenkins May 13, 2013
    Tapping f8 puts into automatic repair immeaditly
  • max carson
    max carson May 13, 2013
    It's should bring up a Boot Menu? Pull the AC plug, remove battery, leave battery out until you have completed this procedure. After each attempt unplug, plug in. Plug in, use this procedure to Boot to Safe Mode with Networking:http://www.ehow.com/how_5117212_boot-com...
  • max carson
    You mat have to do a Full Factory Recovery, if you have a Recovery Partition. What happens if you leave Repairs running?
    I don't know what a recovery partition is, but I left it plugged in to "repair itself" and it just did a loop... It started off as if it would start, then went to saying the automatic repair thing, going black for an hour or two, then looping
    Does being on windows 8 make a difference?
  • max carson
    Did it come with Windows 8? Or was it installed/Upgraded?
    It came installed
  • Hank Jenkins May 18, 2013
    ....Max?...
  • max carson
    max carson May 18, 2013
    Yes.
    Does it being windows 8. Pre-installed change anything?
  • max carson
    yes and No, it should have a Recovery Partition if the OS is pre-installed. I would not count on the repair to do anything at this point. Here is the Win 8 RESTORE procedure, remember: REMOVE BATTERY, LEAVE BATTERY OUT, and UNPLUG after each attempt to RESTORE or Boot to Safe Mode:http://www.bleepingcomputer.com/tutorial... Use F-8 to boot to Safe Mode with Networking, or, F-12 to do a System Restore to a date before this issue. You must push the on/off button with one finger and with the other simultaneously and immediately start tapping and alternating F-8 to F12 , F-8 to F12. Over and over until you get a response. If it fails, UNPLUG, plug in, try again.
  • max carson
    When the computer gets in Auto Repair do you every get a "Couldn't repair" screen that gives you Advanced option? If so, chose Advanced Options, Restore
    It only ever said. Your pc ran into a problem we will collect some data and restart for you
    Ohhhh soo close I almost got it once I think I got it to the boot menu, it said os boot something and was beeping like mad and had multiple options, but I haven't been able to get it back
    What do I press
  • Hank Jenkins May 19, 2013
    Max, what is a Hard Disk Short DST failure?
  • max carson
    max carson May 19, 2013
    You can find all the info here:http://www.bleepingcomputer.com/tutorial... This will explain the DSThttp://www.ehow.com/info_12133492_laptop...
    Okay, we'll I don't know how to restore from my position because the screen won't come on, but what is an EFI file?
  • max carson
    Curiously your HP model with Windows 7 support? You say ir came with Windows 8 installed? Out of the box? New? Is it 32 or 64bit Win8?
  • max carson
    http://h10025.www1.hp.com/ewfrf/wc/docum...
    It came out of the box on win8 it was the Black Friday 179$ laptop last year
    I don't know what bit
  • max carson
    Perhaps it wold be wise totake it to a Qualified Computer Tech, try CompUSA, or similar Computer store. You may be in over your head. Consider replacing Win 8 with Win 7. If you have owned Windows based computers before you will find Win 7 a bit easier to use. If it's under warranty, return it to the store you purchase it from. Usually they will give you a break on repair, replace, or options.
  • HP Master
  • 7,627 Answers
I would download freeware MALWAREBYTES: http://www.filehippo.com/download_malwarebytes_anti_malware/ In Safe Mode with Networking if necessary. In the install UNCHECK the Trial Pro Version, you want the freeware version, run a FULL scan, delete ALL results, reboot normally. I use AVAST FREE 8.0.1489: http://www.fixya.com/answer/answerpageslideview.aspx?ctg=8&thid=18108057 Haven had a Virus in years. Give it a try, it's always rated high in Anti Virus and it's free! First, of course, you have to remove McAfee with the McAfee removal Tool found on the McAfee website.
Posted on May 10, 2013
Testimonial: "Booting in safe mode won't work"
  • 1 more comment
    Oops wrong place, I can't boot it in safe mode
  • Hank Jenkins May 26, 2013
    Max, if you still on this problem, will a win8 repair disc help me?
  • max carson
    max carson May 27, 2013
    Give it a try, it can't hurt.
5 Suggested Answers
  • 16 Answers
SOURCE: black/GREY screen with light spots screen
Try reinstalling the gpu driver. If the problem still persists, the screen may be going out.
Posted on Apr 17, 2008
contest25
  • 115 Answers
SOURCE: HP Pavilion laptop restarts during welcome screen
Do the power drain
step1. Remove battery and ac adapter
step2. Hold on to power switch for 30secs-1mint
step3. Put back the battery and ac adapter
step4. Start the laptop as usual
IT SUD BOOT PERFECTLY
after doing this also if the symptoms are same
i apologise to tell u ...its gonna be Motherboard probs which is common nowadays in Most of the HP LAPTOP
Posted on Feb 25, 2009
  • 156 Answers
SOURCE: display driver stopped responding
For this issue , You need to boot in safe mode by tapping F8 key and go to safe mode with networking (As internet works in this mode). Try installing the Driver again from the following website "http://www.nvidia.com/object/geforce_notebook_winxp_179.48_beta.html"
OR click on the following link
javascript:%20checkAgreement('http://www.nvidia.com/content/DriverDownload/download_confirmation.asp?kw=&url=http://us.download.nvidia.com/Windows/179.48/179.48_notebook_winxp_32bit_beta.exe');
Hope it works.
Cheers
Posted on May 19, 2009
SOURCE: Acer Aspire 5515 stopped responding and will only
i have an acer aspire 5515. i used the laptop last and had no problems, woke up this morning and when i turned it on it started on and from there it kept going back and forth to the empowering and mircrosoft corporation. i tried f8 an safe mode and its still doing the same thing
Posted on Nov 29, 2009
How do I update minecraft
There are 6 steps:
1.Open the Minecraft launcher.
2.Select your default profile in the profile window.
3.Make sure the text to the side reads "Ready to download and play version (current version here)".
4. Click on the Play button.
5. Wait for the update to download and install.
6. Enjoy your updated Minecraft!
AK
Jul 15, 2014 | Computers & Internet
"minecraft mods for 1.7.2"
I've seen many of these mods type things for android apps. I usually check out for them on daily basis... Full Version Apk Apps Hacks Data Files MODs Obb Download is the best one and always works for me...hope it helps :)
Oct 26, 2013 | Kaltner.net Minecraft Mobile Admin
Can't change minecraft pe skin
You cannot change minecraft pe skins yet.
Sep 22, 2013 | Kaltner.net Minecraft Mobile Admin
How to update minecraft
Go to "Minecraft Launcher" and check in the Force Update Box.
May 16, 2013 | Computers & Internet
How do i download minecraft
SWEET! I JUST received no card code free Minecraft http://minecraftcode.me/
Jul 11, 2012 | Morovision Mvpamv7403p Mv740 Weapon Sight...
How do i get minecraft for free and a good version
search 'MinecraftSP' its single player only, and you can play it without buying the game, I downloaded it off MPGH.
Jun 06, 2011 | Video Game Consoles & Games
HP 15.6" Compaq Presario CQ58-A10NR Laptop PC with AMD E1-1200 Logo
149 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
