Question about Vehicle Parts & Accessories
1999 toyota corolla
Battery tests out fine. Car makes a rapid click when I turn the key.
  • Anonymous Mar 24, 2014
    could it be a fuse
    need some help
    Problem Solver:
  • 12 Answers
I had this problem with a 98 civic once. Try tightening the battery connections and see if it makes any difference.
Posted on May 10, 2013
  • Andre May 11, 2013
    I wish I would have tried this first. I did wiggle the cables before but it didn't make a difference at the time. I'm almost 99% sure it's the battery terminals. All this after I bought and installed a brand new starter. Lol
How to install a starter on a 2006 toyota corolla?
They only have 2 bolts holding them in. Unbolt/unclip the wires from the starter and then remove those 2 bolts. Replacing it is the same process in reverse.
Jun 25, 2013 | 2006 Toyota Corolla
BATTERY WONT TURN OVER MAKING A CLICKING SOUND
A single click when you turn the key to the crank position usually indicates a bad starter. A rapid clicking noise usually indicates a dead battery. If you hear a click and everything goes dead there is a bad connection at the battery.
Dec 28, 2011 | 1999 Toyota RAV4
My 2007 corolla won't start. When I turn the key in the ignition the starter makes a rapid clicking noise. I?ve tried putting the car in neutral and starting it that way, but had no luck. I?ve also tried...
1st check the main cable to the starter make sure it is clean and tight, disconnect battery first, after that there should be a small wire going to the starter jump that small connector to the main battery cable on the starter (IGNITION OFF) if it cranks you have a wiring or ignition switch problem if not Starter time just make sure you get a very good quality starter some cheap and even lifetime starters are so poorly made that even after you replace them you still have a problem only a bad noise coming from the new starter you just put in.
Oct 14, 2010 | Toyota Corolla Cars & Trucks
On my 1998 Toyota Corolla, after it starts and runs fine..you turn the key off and it will not start again without a jump. After a quick jump it starts right away. The battery is only a year old. Is it the...
Check for loose battery terminals. Car will not start without jump because battery is not connected properly. Starter is probably good or car would not start with or without jump. If alternator is bad and not producing current, car would die after running a short while as battery would out of juice and without alternator current the car would die - so probably alternator is good. If connections are all good, get a voltmeter and test the battery voltage - it should be over 12.75 volts. If not, battery is not holding charge.
Nov 16, 2009 | 1998 Toyota Corolla
1999 toyota corolla. Car would not shut off went
I assume the car is a petrol! to stop a petrol engine the ignition needs to be shut down! if there is over run happening there are a few reasons for this. There is a problem with ignition mudule! spark plugs coked up! or the cylinders are coked.
If the car is a Diesel model then the reason for this happening is the shut off valve on the fuel pump is at fault.
Hope this helps.
Oct 31, 2009 | 1999 Toyota Corolla
1992 Toyota Corolla does not turn over. No click.
may be it is the ignition switch. don't turn it on fully. try to rotate the key half-way. trouble with the contacts of the switch.
Aug 12, 2009 | 1992 Toyota Corolla
1998 Celica engine won't start, rapid clicking audible
sounds like you are on the right track, the battery you have in it has done well to last that long but it sounds like a fell cells have decided to call it quits
May 26, 2009 | 1998 Toyota Celica
Vehicle Parts & Accessories Logo
46 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
