Question about Spark Plugs BR4HS Plug 10/BX #3322
Mitsubishi eclipse 2006 gt
Where are they and should be changed at 120,000miles?
  • 2,272 Answers
They are sort of "buried" in the motor, and they do not need to be changed unless they tell you so. Here's how they "talk". You will get noticeably less gas mileage, and the motor will not run smoothly as it used to. If, however, the motor is running (smoothly) the same as it was a year ago, leave well enough alone.
Be blessed.
Posted on May 22, 2013
How to Change an EGR Valve on a 2008 Mitsubishi Eclipse GT?
I, feel sorry for you, after reading your problem, but don't worry you visit the Reliable-Store they will help you for sure.
Best Manuals
Oct 14, 2016 | 2008 Mitsubishi Eclipse GT
How do you change the km/h to mph on a 2006 Mitsubishi eclipse
Not your question, but you might like to have this:
http://tearstone.com/2006-eclipse-factory-service-manual
Supposedly the owners manual (perhaps you have it) tells you how to change the speedometer.. it involves turning the car off and holding a button on the dash in and turning the ignition on and continue holding the button for > 5 seconds
Aug 06, 2015 | Mitsubishi Cars & Trucks
Where is the o2 sensor located on a 2006 mitsubishi eclipse gt 3.8v6 sensor 1 bank 1
Hi, your Eclipse is like Mitsubishi 380 V6. Bank 1 Exhaust is toward the radiator & sensor 2 would be attached to the exhaust pipe after your Catalytic converter. That is the second Oxygen Sensor on the front exhaust pipe which would be under the motor toward the muffler.
You can take a look at your exhaust pipe right it before it goes into your catalytic converter. Thats the approximate location of a great many o 2 sensors
Jun 19, 2011 | Mitsubishi Eclipse Cars & Trucks
Hi, I need help, the check engine light came on, It recently had service done, what can it be, the car is in perfect condition and well care. Eclipse GT 2006. Thanks
have someone to hook up a diagnostic code tester , to see if the computer has picked up any problems in the system, you can have this procedure done free at auto zone.
May 11, 2011 | 2006 Mitsubishi Eclipse
Change a crankshaft position sensor on a 2000 eclipse
Is this a V6 or 4cyl???>>>(V6) This requires removing the Harmonic balancer (crankshaft pulley). Remove (R) front wheel, remove engine splash Guard, Remove crank pulley, remove lower timing belt cover. The Crank sensor is located behind the crank shaft pulley!! I highly recommend having this done by a certified tech, requires special tools. Hopefully this helps!!
Mar 11, 2010 | 2000 Mitsubishi Eclipse
Will 2005 brake rotors fit on a 2006 mitsubishi eclipse GT?
They should be able to look at the part numbers for the 2005 and the 2006 and if they are the same you are good to go. If they are not the same don't do it. Have them order in the right parts or go to another store. Brakes to important to be messing around with
Feb 20, 2010 | 2006 Mitsubishi Eclipse
Does a 2006 mitsubishi eclipse have a fuse for tho
no.....only the head unit is fused which would mean no sound at all if the fuse was blown
Nov 09, 2009 | 2006 Mitsubishi Eclipse
Spark Plugs BR4HS  Plug 10/BX #3322 Logo
Top Ngk Vehicle Parts & Accessories Experts
Ian Kime
Ian Kime
steve morris
steve morris
Are you a Ngk Vehicle Part and Accessory Expert? Answer questions, earn points and help others
