Question about Measuring Tools & Sensors
Robinair 34200 When I pull vaccum systems runs for 3-5 mins and say's fails high pressure help! Phil
mhkamran
  • 180 Answers
SOURCE: Model Robinair 34700 Series 21699
Please do the following 1# Check your machine ISV tank liquid line quick connector.it's seems to be very tight,open little & try to charging.2# Rebuild charging solenoid.
Posted on Jun 25, 2009
mhkamran
  • 180 Answers
SOURCE: ROBINAIR 34700Z ALWAYS FAILS VACUUM CHECK AND
Please check the following: Low side manifold gauge is going to -13"HG while you recover refrigerant from the vehicle.If low side gauge not rich to that lavel then vacuum sensor will detect pressuer &
it will stop you to make vacuum until you fix the problem.If it happen you may nee to rebuild/replace one or more of this solenoid.1#Vacuum solenoid 2# Recover solenoid.3# Recycle solenoid.Also check Low/High side small solenoids ( In the small block assy.)
If all of this solenoids working properly then check Vacuum pump capacitor & vacuum sensor.Hope this will help you to solve your problem.
Posted on Apr 09, 2010
mhkamran
  • 180 Answers
SOURCE: The high pressure unit is disabled in my Robinair
This is a common problrm of Robinair 34700Z / 347002k & 347112k series machine.so don't worry just do the following :- 1# Verify the ISV tank is not overfilled.if full,remove refrigerant manually from tank. 2# Verify if there is high pressure in the tank.Purge excess air from the tank manually.( Open air purge hose from the tank,then press tank valve as needed) 3#Check the high pressure switch for proper operation,if not then replace high pressure switch.Hope this will solve your problem, if so please vot for it
Posted on Jan 04, 2011
mhkamran
  • 180 Answers
SOURCE: Robinair cooltech 34788 displaced high
You Have to replace the PCB Relay Board
Posted on May 17, 2011
mhkamran
  • 180 Answers
SOURCE: I'm Archie i've a Robinair
This is a common problem of Model: 34788, 34788-I, 34988, AC34788, GE48800 etc.
You need to replace air purge solenoid (Air purge solenoid located on top of the ISV tank, if you open front panel cover then you can see it on top of the tank).
After doing above stapes and your problem still exist then you have to replace PCB relay board. Just claim for warranty (Air purge solenoid and PCB relay board) from where you bought the machine.
Hope this will help to solve your problem, if so please vote for it for farther help! Good luck
How to fix High pressure message error.
Seems to blockage in the inlet or pressure switch
Jul 01, 2016 | Robinair Cooltech 34788 R134a Automatic...
Robinair 34788 will not charge properly
I would be very careful releasing refrigerant from the liquid side of the tank as suggested earlier. Knowingly releasing R134 into the atmosphere carries very large fines if you get caught and is very environmentally irresponsible.
Jan 20, 2012 | Robinair Cool Tech 34700Z Recovery,...
The high pressure unit is disabled in my Robinair Cooltech 34700z wat could be the problem?
Jan 04, 2011 | Robinair Cool Tech 34700Z Recovery,...
My machine says high pressure unit disabled and will not let me advance
May 27, 2010 | Robinair Cool Tech 34700Z Recovery,...
My 34700Z is not discharge low side existing pressure, wen i select vaccum the low side hose have pressure and stop to make vaccum
Please Check the following 1# Check ISV tank may overfill,if so manually discharge extra pressure from the tank.2#Check High & Low side small recover solenoid (in small manifole assy.) it's may neet to rebuild.3# Check Recover/Vacuum/charging (in main manifold assy.)solenoid,rebuild if need.4# Check ISV tank liquid hose is connected properly & make sure it's not too much tight OR loss.5# Check high side coupler is opening properly.Hope this will help you to solve the problem.
Apr 13, 2010 | Robinair Cool Tech 34700Z Recovery,...
Reads high pressure unit dissabled
Feb 05, 2010 | Robinair Cool Tech 34700Z Recovery,...
Can you use this pump to vaccum r-22 systems the robinair vaccummaster 6cfm
Yes you can,as long as you have fresh oil & it'll pull the system below 500 microns,you shouldn't have a problem.
Jan 09, 2010 | Robinair 6 Cfm 2 Stage Vacuum Pump, R 12/R...
My robinair isn't working and shows high pressure
This is a common problrm of Robinair 34700Z series machine.so don't worry just do the following :- 1# Verify the ISV tank is not overfilled.if full,remove refrigerant from tank. 2# Verify if there is high pressure in the tank.Purge excess air from the tank manually.( Open air purge hose from the tank,then press tank valve as needed) 3#Check the high pressure switch for proper operation,if not then replace high pressure switch.Hope this will solve your problem.
Jul 12, 2009 | Heating & Cooling
Robinair 34788 not pulling a vacuum
It's seems to be problem with your unit relay board,vacuum pump or pressure transducer.Most of Robin air 34788 machine having same problem.You can try as follows 1# Open vacuum pump oil filling cap to release extra pressure from pump.2# Replace new relay board & follow the on screen message(do not skip any option).3# Check pressure transducer is working properly.I hope this will help you.
Jun 06, 2009 | Robinair Cool Tech 34700Z Recovery,...
Measuring Tools & Sensors Logo
62 people viewed this question
Top Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
